Question about PC Connection Antenna Cable LMR400 Wire with Male ''N'' Connectors, Normal Polarity, 75ft (LMR400NN75)
Can I use lmr-400 for my tv antenna? wireless  company left lmr-400 in my house and on my tv mast when I changed ISPs.  Can I use the lmr-400 instead of the rg-6 for better performance?  My total run is about 50-60 feet from the antenna to the antenna preamp. john
  • 92 Answers
Yes you can...
Because it still to be a Coaxial cable, so the signal will pass throw. You will notice no diference, but it will do the job.
Regards
Posted on Jun 24, 2009
Where is the power antenna motor located for a 1992 buick regal?
I have not owned a buick for years. However, the one I did have trouble with the power antenna motor was located directly under the antenna. It was in the rear fender housing. I have to remove the trunk lining on the side of the fender. It was mounted a bracket. It was easy to replace as it all comes as a complete assembly. Hope that helped
Feb 21, 2012 | 1992 Buick Regal
I have color on all but 1 TV station. That staion has color on other TV's in my house. Any sugestions?
Ur tvs in ur house it is getting a paid tvs incomming broadcasting tv signals like a cables or a satalites dishes companies?Yes,than that incomming broadcasting wire that plug into ur tv Ant. input port hole might have some kind of signals interference at that channel frequencies,call ur cables tvs or satalites tvs companies providers for an answers and get their field Tech. to come out and check it out.If all ur tvs in the house are analoge tvs and u are using a DTV signal through a DTV converter box to getting a Free over the air DTV air to recieving tv broadcasting tv channels stations only than tries it with another antenna signals sources like a better antenna design like a portable digital antena or good roof antenna should solved this problems.
Oct 03, 2011 | Philips Magnavox 20MS3442 20" TV
How do you replace the atenna mast for 2005 sierra.
How do I install a new antenna on my GMC 05 2500 Sierra. I have to replace the base because it broke off. I've taken the dash off. But cannot seem to fish wire through the firewall.
Nov 26, 2010 | 2005 GMC Sierra
Does the antenae go down or come off so I can go through a car wash? Or will it be OK?
You can unscrew the mast from the mount. The mount is right on top of the fender. http://www.aliexpress.com/product-gs/234605996-Car-antenna-mast-wholesalers.html
That site shows the antenna mast, and the lower left portion of the picture shows the end that screws into the antenna mount.
Oct 05, 2010 | 2001 Dodge Grand Caravan
How do you replace a 1989 caprice electric antenna?
Remove right side trunk panel inner liner,remove outside mast jamb nut with needle nose or lock ring pliers. Remove motor mounting bolts,remove drain and electrical connector.If you are just servicing the cable mast kit,open/split the motor drive housing and remove a small section of broken cable which will cause the antenna not to go all the way down if left there.
Jul 19, 2009 | Chevrolet Caprice Classic Cars & Trucks
Antenna mast broken
    Give these instructions a shot. Might be too generic but might be enough to get you going. Removing Original Antenna
  1. Step 1 Activate the antenna switch to the up position.
  2. Step 2 Using the wrench or needle-nose pliers, loosen and remove the original retaining nut on the base of the antenna mast.
  3. Step 3 Gain access to the underside of the area where the antenna is located.
  4. Step 4 Remove the bracket or brace that is below the hole and holding the antenna in place.
  5. Step 5 Remove the mast.
  6. Step 6 Find the motor that controls the antenna mast. Generally, power antennas will have a constant 12-volt lead and a ground lead. The ground lead will be grounded to the panel next to the motor.
  7. Step 7 Remove the ground lead from the panel.
  8. Step 8 Pull out the antenna coaxial cable.
  9. Step 9 Unplug the coaxial from the extension coaxial cable.
  10. Step 10 Remove the original antenna coaxial cable. Note the route the cable follows.
    Installing the New Power Antenna
  11. Step 1 Inspect the fender area where the antenna mast will be mounted for rust.
  12. Step 2 Clean the area before installing the new antenna.
  13. Step 3 Plug the new antenna coaxial cable to the extension coaxial cable. (On some General Motors and Ford cars you may need an adapter to mate the 2 cables together. Car audio retail stores sell such an adapter.)
  14. Step 4 Plug the new antenna's coaxial cable into the radio's chassis antenna jack if there is no extension coaxial cable. Tie or tape the string you put on the extension cable to the new antenna coaxial cable. This assures that the 2 cables stay together as you route them to the antenna mount in the fender.
  15. Step 5 Connect the power lead of the antenna to the power antenna lead on the radio.
  16. Step 6 Connect the 12-volt constant lead to the antenna to a 12-volt source or to the ignition switch.
  17. Step 7 Direct the new antenna cable via the same route followed by the original antenna cable on up to the hole in the fender in which the mast will be mounted.
  18. Step 8 Ground the ground lead from the motor to a clean metal surface on the metal panel near the mount.
  19. Step 9 Insert the mast into the hole. Face the serrated side of the plastic cable on the bottom of the mast toward the motor side. The plastic cable can be inserted freely to about 12 inches and will stop.
  20. Step 10 Turn on antenna switch to down position until the plastic cable goes down and catches into the gear mechanism of the drum housing. If the plastic cable does not gear into the mechanism, twist the cable slightly until the cable contacts into the gear mechanism while the motor is in operation.
  21. Step 11 Stop the motor after the cable goes into the housing 12 to 25 inches.
  22. Step 12 Secure the bracket or strap to the bottom of the antenna mast and to the metal fender.
  23. Step 13 Replace the retainer nut to the base of the antenna mast and secure tightly.
  24. Step 14 Replace the panel that covers the antenna mount area.
May 13, 2009 | 1993 Chevrolet Corvette
I can hear the sound of the motor but the retractable antenna of the car radio do not work.
Try removing the motor and replacing. But before that try to see if it will come apart and check to see if parts inside are loose or striped.
Apr 09, 2009 | 1996 Toyota Camry
Saab 9-3 convertable antenna will not go up. there is a clickng sound when the engine is turned off and on at the antenna.
antenna mast is no good.. you can buy a mast and have it installed or buy a used antenna and have it installed im sure Elite foreign auto parts has only saab parts.. tested and used,
Feb 17, 2009 | 2003 Saab 9-3
Installation of vt holden commodore aerial rope and mast
You access the ariel via the left hand wheel arch.
1. Remove left wheel mud guard. It is held in with a bunch of press studs which can be difficult to remove. I found pulling on the plastic mud guard whilst turning the screw helped.
2. unbolt the electric ariel assembly. There is an earth strap that needs to be unscrewed as well.
You should be able to get the ariel out far enough to work on it.
3. Remove chrome plated nut to top end of mast tube.
4. With great anger and force, remove the dead ariel and drive cable from the mast.
It's difficult to get the mast to work unless it's earthed properly.
5. Get you hand inside the wall and remove the ariel face plate. Swear if you have to.
6. Put the ariel mast assembly back into the wall and hook it all up minus the new ariel.
7. Switch your radio on, then put the new ariel into the mast. Gears facing the rear of the car. Switch the radio off, it should retract. If not you may need to push it in a little further.
8. Remove the ariel mast again and slip the chrome nut to top end of mast tube and tighten securely.
9. Ask the spouse to close up whilst you have a beer.
Apr 03, 2008 | Car Audio & Video
Remote Antenna
I suggest LMR-400 cable, but generally most any coax cable will do. As far as your connectors, I suggest visiting RadioShack or The Source for these, remove your existing antenna and bring it with you to determine what N-Connectors you will need.
Jan 30, 2008 | Actiontec (5GE583000-01) Router
Computers & Internet Logo
172 people viewed this question
Top PC Connection Computers & Internet Experts
David Payne
David Payne
Are you a PC Connection Computer and Internet Expert? Answer questions, earn points and help others
