PA amp + speakers
Hello, I have a small carlsbro pa + speakers. The problem is - all i'm getting from the rear speaker outputs (4 ohms min) is constant white noise?
I have checked the speakers with a different amp, they are fine. Plus I have tried the mono output on the front panel, this works too.
The noise happens even when all the volume dials, includind the main volume are turned to 0. I have also tried different cables, no success.
 I notice when I turn off the power switch, as the power fades I can hear my mp3 player working for a split second.
I have just opened it up and all the soldering looks good.
Any suggestions
regards Matt
    Problem Solver:
  • 19 Answers
Well I do not know what your knowlage of amps is but take an ohm meter and check all your Cap's that sit on the output stage of your Power Ic's. The noice your are getting is ripple from the AC side. When you switch of the amp there is no power and no ripple so all you here is the correct DC power that is going thru to your Power Ic's. that power is supplied by the Cap's that is busy discharging. You will find your problem there.
Posted on Jun 02, 2008
  • 682 Answers
Remove every sound input one by one until you find the one who make the trouble.if this procedure failed sent it to sevice center to fix it.
Posted on Mar 11, 2008
How do I plug mixer into pa speakers, monitors, instruments
Without knowing what make and model of the gear you're looking to connect, I can't give you a definitive answer. However, in general, if you have a powered PA mixer, meaning it has both a mixer section and a power amp section in a single box, the main speaker outputs will be on the rear panel of the box and marked as such. There will also be a jack for monitors, but some mixers have an amp for monitors, some just have an output for the monitor mix, but not an amp for them, and on some you can switch the main outputs to feed either a Left and a Right speaker, or a front mono speaker and a montior speaker. Instruments will go into the individual channel inputs.
Feb 08, 2015 | Music
How use pa system
All the 8 ohm's means is that you need to use an 8 ohm speaker for optimum performance. That is what the radio is set up for. Most small PA speakers for auto etc, are 8 ohm's.
Jun 02, 2014 | Uniden Radio Communications
4-8 ohm output
it is load resistance. set the amplifier switch to the resistance ( X amount ohms) to match your speakers. Although running 4 ohm speakers at the 8 ohm setting is louder, it will hurt your amp
most home/semi pro speakers are 8 ohm, while car speakers are 4 ohm. If you are doing a multi speaker pa/intercom install use your formula to calculate total load is 2 8 ohm speakers in parallel are four ohms . express them as fractions and add the denominator ie:8/1 +8/1 = 8/2 or 4/1 or 4. now connect that in series (add the top numbers)with another 2 speakers in parallel and you get back to 8 ohm load. repeat the same process over and over and you can hook up to 32 speakers to the amp without needing the 70 volt tap. hope this helped.
Mar 18, 2014 | TOA Electronics A912MK2 Amplifier
per fcc rules (laws)? you cannot put an amp on a cb. max output 4 amps. you should be able to put a pa speaker using the pa output jack. take your radio back for warranty.
May 19, 2013 | Cobra 19 DX IV CB Radio
Connect a mic mixer to a powered mixer
What kind of output does the mini mixer have? If may not have enough to input your Carlsbro PA
Nov 16, 2011 | Radio Communications
Put new pa speakers in church 2 1000 watt tied 2gether and 2 300 watt. tied 2gether. the pa amp only has 250 watts with 6 mics connected and a cd player which plays fine. every time the mics are used if...
You have to check the ohms of the speakers all spekers should be 8 Ohms or above. if not it will overload the amplifier at high level. The minium ohms impedence of the amplifier is 4 ohms. If you connect two 8 ohms speakers together then the effective ohms will be 4 OHMS then the amp will handle the speakers. If you connect two 4 ohms spekers together then the effective ohms will be 2 Ohms, this will overload the amplifier. You will be able to connect two 8 ohms speaker to left channel or right channel of the amplifier. Check the speaker spesifiction to know its ohms. Make sure all the speakers have an impedence of 8 OHMS or above
Aug 19, 2011 | Radio Shack 250 Watt PA Amplifier...
I have a TOA 301 15W amp and a Bose 151 environmental speaker(40w 4 ohms). I do not have a manual for the amp and wish to connect the speaker as a small PA . My concern is that the output I think I should...
Don't worry about the 7.7 volts. Just connect between COM and 4 ohms and you'll be fine. I didn't find a 301 part number related to a 15w amplifier, but I did find a BG series (115 130) of 15 watt amps manual
May 08, 2011 | TOA Electronics Audio Players & Recorders
I have a 1200watt amp that's only providing 300watt output with 8ohm Behringer B212 speakers. Is there a resolution and what would it be?
I'd need to know more about the amp, but don't forget, amps are rated as their max power...
So lets take a 300W/channel stereo amp at 8 ohms.
Ok, it's stereo, so there's 600W
But the amp is capable of 4 ohm loads...well, now you can deliver 600W/channel, for a total of 1200W
In this scenario, your amp is doing exactly what it was designed to do with those speakers.
If you wanted to get the full 1200W out of the amp, you'd have to hook up 2 more speakers in parallel to the ones already there. This drops the impedance to 4 ohms per channel = 600W / channel.
Yes, the power is split among the apeakers...300W per speaker into 4 speakers = 1200W
so any way you look at it, there's your 1200W
Feb 27, 2011 | Behringer B212 600watt, 2-Way PA Speaker
I have been using two Peavey Pro 15 Mk ii 300 Watt Passive 15" Speakers with two additional speakers on the output side and i notice one of the peavey speakes wasnt working! i then realised i had the...
Passive speakers with 1/4 inch jacks do not define either as input as they are wired in parallel...
Assuming the speakers you added were each no less than 8 ohms this should NOT have overloaded your amp.If you have no sound you have probably blown your amp some way.
Note some amps can be blown if they are on and EITHER side of the speaker cable touches a ground. If the amp is running and a 1/4 inch plug is pulled, it shorts and can blow the amp.
Jan 17, 2011 | Peavey PR15 400w PA Speakers
Can I use my amp with PA speakers?
Yes, but stay within the "ohms" limit of the amp.(probably 4 ohm or greater)
Jun 09, 2009 | Samson Servo 170 Amplifier
202 people viewed this question
