Question about Coleman Mach III Air Conditioner
Coleman rv rooftop unit, fan runs in on but in auto nothing works
Old coleman rv unit. Hooked up new mechanical heat/cool thermostat and wired to ceiling unit, and I can get the fan to run in on but not in auto and cool with temperture on lowest setting. The terminal strip on the ceiling unit has a "R" "W" "Y" "G" "F" "F". I have the R,W and G hooked up right now and just the fan runs only in "on" position. What is the "F" terminal is that the common ? I'm only interested in the air working not the heat. please help
    President:
  • 3,433 Answers
R = HOT 12V
W= WHT- GND
Y = YELLOW / POSSIBLE THERMOSTAT
G= GRND FOR THERMOSTAT
f = FAN
F=FAN
aSSUMING THIS IS A TWLVE VOLT SYTEM- The two f's Would be fan control intake and exhaust - fan direction
White is always ground and so is green.. green is more of a static ground where white is a load grnd.
Red is always hot. in low voltage
I hope this helped. No instructions in kit?
Posted on May 18, 2009
  • Ned C Cook
    Ned C Cook May 24, 2009
    If I may? On RV issues , camping World Stores cater to the RV crowd and are excellant at assisting and advising. They may even provide a copy of the wiring diagram for you. Good Luck.
I have a Coleman mach RV roof Ac with a fan and separate Furnace unit. None of the units will turn on.The AC did work along with the fan. Now nothing works. All of the fuses are good
Check the plug end of the Power cord for a broken wire. If you can test the cord for continuity with an ohm meter do that first. Most likely you can get a replacement plug. You'll need to cut the old one off and strip the wires back to connect the new plug.
Feb 09, 2017 | Coleman Heating & Cooling
Fan wont run on auto
Make sure your tstat is programmed for electric, not gas. Or in the settings you want that the TSTAT CONTROLS THE FAN.
May 23, 2017 | Dometic Rooftop RV Air Conditioner
Dometic roof ac will not cycle
check wiring and dip switches make sure fan on auto
Jun 14, 2012 | Dometic Rooftop RV Air Conditioner
I have a 13500 btu ac dometic penguin model on pan that is old and would like to replace with 15000 btu ac of any other manufacturer or another dometic what are my options ..I do not have ducts and do not...
Your choices are another Dometic or a Coleman
I prefer the Coleman But the amount of extra cooling you will get by stepping up to a 15K unit will probability not be worth the added cost
Mar 11, 2010 | Dometic Rooftop RV Air Conditioner
Coleman Mach III Air Conditioner Logo
442 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
