Question about Coby MP-610 MP3 Player
Cord jerked out. No sound. I tried reset, but no success.
I was using my Coby and the cord jerked out as it got caught on something, so I put the cord back in and now it has no sound. I am planning on running in the morning, so I am devastated that I will need to run without my MP3. I don't know if I can do it! Help!
I am very disappointed in Coby that you do not have assistance that does not cost $20. The booklet says to not take it back but to call for support. If Coby's policies are like this, I don't know that I will purchase anything else from this company.
Thanks, but no thanks.
Posted on May 18, 2009
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Sep 17, 2016 | Bissell Vacuums
My Toro mower won't start. The cord will not allow me to pull it out all the way. It seems to be caught on something.
Disassemble the starting mechanism and remove the snag in the line that is preventing you from pulling cord all the way out. Till you do that, you will be pounding salt.
Nov 01, 2015 | Toro Garden
Coby kyros MID 7022 wont unlock main screen....swiping only meets halfway then screen goes black..help?
ok try the reset button plug the power cord before you start. look where is the reset and use a small point toothpick .
Nov 03, 2013 | Coby Kyros 7" Touchscreen Tablet
Sony walkman nwze365 poor sound quality when plugged into home stereo or portable player
Maybe you are using the headphone jack on your Walkman to connect to your home stereo. Not good. I prefer a LINE OUT connector and for $130 you would expect to find one. My experience has been that some have it, some don't.
Apr 03, 2017 | Sony Audio Players & Recorders
Need to replace the pull cord assembly, because something that tension the spring is missing. Tried substitute cord but found after reassembly there was no tention on the cord something is missing.
When the cord breaks, the internal spring will completely unwind. You have to re-tension the spring, then attach the cord and wind it onto the spool while holding the spool against tension. Finally, feed the end of the cord out through the cord port and tie the handle while still holding tension. A small pair of Vise Grip pliers will hold the cord while dealing with the handle. It's about like setting a trap without getting your fingers caught. Hope this helps!
Jun 07, 2010 | Craftsman sears 18" Chain Saw Chain (...
Air conditioner has no power at all to turn it on
No, I doubt its a problem with the plug. I don't want to direct you into the wiring so lets try this . Rotate the thermostat control or if buttons alternately press the on and off buttons several times. If its a dial turn turn it several times then stop at lowest temp setting. Do the same to all the controls. This helps to clean the contacts on the controls. I don't know of any air conditioner that has a reset or breaker incorporated in its electrical.Takthere is any humming. The Fan should at least turn. If not, then someone will need to check to see where the power ends. Try the control cleaning a few times. Let me know if you will please. One more thing, Pull on the power cord and see if it is securely held in place, if not, Look closely where it passes through the cabinet to detect if the cord was pulled on. then check for any signs of kinking or crimping. The power cord itself may have been damaged somehow. Make sure all the prongs are tight . It has happened wher the cord on a unit being carried got caught on something and having hands full, It was jerked on to free it. Can't rule that out.. Good luck and stay in touch.
May 22, 2009 | Haier HWR08XC7 Air Conditioner
The cord to my Poulin chainsaw is sticking
To traxtor06
Your problem sounds like a broken starter spring. If the spring is broken it will slip allowing the tension to be released and not fully retract the rope.
Mar 27, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
My Poulan chain saw has a sticking pull cord....r
Check the flywheel and flywheel key. It sounds like the timing is off.
No screen display while DVD plays
optic lense reader are dirty need cd cleaner
Jan 03, 2008 | Coby TF-DVD7005 Portable DVD Player
Coby MP-610  MP3 Player Logo
56 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
