Question about Lasonic Ghetto Blaster i931 Boombox
Lasonic I931bt speakers not working
Once I have connected the power I don't get any sound from the speakers
2 Suggested Answers
SOURCE: user manual lasonic I931bt radio
Got my ghetto blaster in today was supper exited. The left the tweeter and sub work only. No sound coming from right side... Wtf? I was gonna take it apart but the back says DO NOT OPEN SHOCK HAZARD..... That's scary.
Posted on Jan 19, 2013
I plug in my lasonic blaster g31 when I put up the volume it turn off what is it
From the description the audio outputs are cutting out due to bad connections, or semiconductor failure. Check to make sure there are no shorts in the speaker wiring, if no change! take it back to the place of purchase for exchange or repair.
Jul 07, 2012 | Lasonic Ghetto Blaster i931 Boombox
Sound comes out of left channel only in my Lasonic L-30K boombox
Check the speaker wire for proper contact, swap speakers around to rule out the speaker, if okay suspect the left audio output chip.
Jun 15, 2012 | Lasonic L-30K Cassette Boombox
Lasonic VP-02SBK (2 GB) MP3 Player I I don't have
Hi dimaz027...
Go to the following webpage and download your drivers
Please take time to rate me
http://lasonicstore.com/t-faq.aspx
Aug 14, 2011 | Lasonic VP-02SBK (2 GB) MP3 Player
I have lasonic mp-04gs, i don't know how to change the time or download of my pc and many other things help?
Hi, I think you need to update the software on MP3 player. Or try using windows media player (WMP) . I use it and it works fine. Good luck
Jun 13, 2011 | Lasonic MP3 Player
Speaker wires are pluged in on my dell inspiron 530 but not working help
    • 1 Make sure that your computer and speakers are plugged in, have power and are turned on. If the speakers are plugged in but don't appear to have any power, plug them into a different outlet. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
    • 2 Retest the sound. If you still don't have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8-inch TRS cable) is plugged into the green audio output jack on the PC.
    • 3 If you're using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you're using outlet-powered speakers and have a working set handy, replace the suspected non-working speakers with the working pair to test.
    • 4 Navigate to the Microsoft Fix It troubleshooter (windows.Microsoft.com/en-US/windows/help/no-sound-in-windows) to automatically detect and fix sound playback or hardware problems. If that doesn't work, proceed with the next step.
    • 5 If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. Check the system BIOS to determine whether you have inadvertently disabled your on-board sound.
    • 6 Navigate to the "Start" menu and select the "Control Panel" and "Sounds and Audio Devices." Then click the "Volume" tab. If everything is grayed out, proceed to Step 7. If the "Mute" box is checked, uncheck it. In "Device Volume," make sure that your volume level is set to a comfortable volume level for your speakers.
    • 7 Click the "Sounds" tab. Under "Sound Scheme," determine whether "No Sounds" is selected. If it is, click "Sound Schemes." A drop-down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. The sounds will be indicated by a small "Speaker" icon located next to them. Left-click the sound once, then click the "Play" button. If you still don't hear sound, proceed with the next step.
    • 8 Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
    • 9 If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Fix this by reinstalling the appropriate drivers. Do this by navigating to the "Start" menu and right-clicking "Computer." Then select "Properties" from the drop-down menu. Click the "Hardware" tab and then click the "Device Manager" button. The Device Manager will open.
    • 10 Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers." If a red X appears, right-click the device with the X and select "Enable" from the pop-up menu. Test your sound at this point. If a yellow question mark appears, right-click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Next, click the "Roll Back Driver" button to roll back to the previous drivers that were functioning correctly. Restart your computer when prompted.
    • 11 As a last resort, you can uninstall and reinstall the device. To do this, right-click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If you still don't hear any sound from your computer speakers, contact a qualified computer technician.
Nov 14, 2010 | Dell Inspiron 530s Desktop Computer
I have just turned on my brand new lasonic i+931 boombox. I plugged it in and it automatically turned on, made a loud humming noise and then within seconds turned itself off. I was thinking maybe a fuse...
same happened to me. it might be the battery circuit or the batteries many times fall out of place so they dnt work. call lasonic or send it back for a new one for free like mine
Jul 16, 2009 | Lasonic Ghetto Blaster i931 Boombox
Pioneer SA 9800 Ampliffier Output transistor going off frequently
I assume these are the complimentary pair that drive the speakers. On one of the speaker. You know I think you have a short in the speaker that it drives. Speaker can fuction even if there was a problem with it. I think what happened is when the original transistors shorted out it overloaded the speaker, but not to a point where it is burnt. There is nothing that can overload a power transistor except the speakers, I design a lot of amplifiers, the base input can overload it if you put dc in there, but that would make a the sound all distorted, I assume the sound seem fine. Solution is try connecting a known good speaker and I bet it wont burn out anymore. Even if the speaker look fine don't trust it.
Jun 30, 2009 | Lasonic TRC-931 Cassette Boombox
Problem with Lasonic i pod ghetto blaster
Happened to me, and a very common problem. on the top left of the battery compartment, there is a U shaped connector meant to hook up with the + battery on that side. it's too low, so the circuit doesnt complete. Use some aluminum foil or copper wire to make the U connect with that battery and it should work.
Jun 16, 2009 | Lasonic Ghetto Blaster i931 Boombox
Lasonic Ghetto Blaster i931 Boombox Logo
88 people viewed this question
Top Lasonic Audio Players & Recorders Experts
stynger007
Level 1 Expert
Joseph Hoffmann
Are you a Lasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
