Question about Calypso Watches
Want to know how to adjust settings on a calypso chrono watch
Want to know which combination of the set, mode, adj and light buttons to press to adjust the settings on the watch
5 Suggested Answers
SOURCE: columbia watch - set time
Hope this helps!
I found it finally!!!
Good luck, I hope this helps you!!!
Columbia by Fossil Customer Service Contact
Contact this seller Phone: 800-449-3056
Posted on Jan 11, 2008
  • 73 Answers
SOURCE: Setting time on Watch
go to this website follow the instructions for finding your particular watch module located on the back of your watch and enter it in the space provided. This will lead you to a place where you can download your manual and learn how to set your particular watch. here is the link to follow and please leave feed back if it was helpful. http://world.casio.com/wat/download/en/manual/
Posted on Feb 04, 2008
SOURCE: aquatech watch
press mode button 3 times untill you get into the time set mode - press lap/reset twice until the hours start to blink.
press start/stop and cycle thru all the modes depending what time you want to set - it will go thru 1, 2, 3, etc thru 24 H then 1, 2, 3, etc thru 12 A then 1, 2, 3, etc thru 12 P - depending on thte time you want to set the A is for AM and the P is for PM
hope this helps
jeff
Posted on Oct 14, 2008
SOURCE: How do I adjust date of my watch bought from GAP
Here is the manual from GAP customer service.
Dear gap.com Customer,
Thank you for your email regarding the Sporty Printed Watch user
instructions. Please accept our apologies that no directions were
received with your order.
The instructions are as follows:
Button Functions:
A. Light
B. Mode
C. Start
D. Reset
Standard Time Adjustment:
1. To set the time, press the Mode button three times (The seconds and
the word Tuesday should start flashing).
2. If the seconds position shows less than 30 seconds, pressing the
Start button will reset the seconds to 00. If the seconds position shows
more than 30 seconds, pressing the Start button will reset the seconds
to 00 and the minutes will increase by 1.
3. Press the Reset button until the area you want to change starts
flashing (i.e., second, minute, hour, day, month, and weekend. Press
Start button once for per unit increment, press and hold for 3 seconds
for speedy advance.
4. At completion, press Mode button to resume standard time display.
To reset the Alarm:
Press the B: Mode button until you reach the alarm.
Press the D: Restart button.
Press the C: Restart button to get back to the time
Posted on Dec 13, 2008
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
I have 1 sonata super fibre watch analog+digital i dont know how to set time in it
If its a super fibre 3 series with 4 butons ( set, adj, mode, light)
Just keep the set button pressed for about 5 seconds, then use mode to select next( date, time, year etc) and adj to change the respective data. Then press Set once and its done.
Cheers
Nov 18, 2012 | Watches
Bottom right button is light, not EI. top left is adj button left is mode top right is st/stp. I can't set time and date and can't turn off my alarm
hi..
El stands for
To set the time
  1. Press and hold [ Adj button ] till the digits on screen starts blink.
  2. Now Press [ Mode Button ] repetitively to cycle through Hour -> minute -> Seconds
  3. Press [ ST/STP button ] to adjust the value. Each press will increase the value.
  4. Press [ Adj Button ] again to save the changes
To set the alarm
  1. Press [ MODE Button] till it displays Alarm Time.
  2. Repeat steps 1 to step 4 as described in 'To set the time'
  3. Different watches have different procedures to active the alarm. Common method is pressing a button briefly.
    Since model of watch is not specified, Try pressing [Adj Button] or [ST/STP Button].
Mar 18, 2011 | Watches
I need to know how to set this watch. My daughter lost the directions. It says SHP3167 on the back. Can you help me?
Generally digital watches all set about the same.
I believe your watch is a Sharp digital alarm/chrono by the number you give.
Hold down the start/stop button in the right corner until the display begins to flash. Once the display flashes you can go through the fields to be set by pressing the mode button.
Some digitals use a different combination but are all about the same.
Sep 15, 2009 | Watches
How do you set time on the Armitron Women's Sport Large Digital Pink Resin Strap Watch #456963PNK+
Here is what I found....
Hi, I have a 40/6753 and here is what I found to set the watch
................Adj......................Start/Stop
...............Mode
.............................EL
Press and Hold down the MODE button until the display starts to flash that you are Adjusting the alarm. If you need to adjust the alarm here ya go :)
Press the mode button again and it switches from adjusting the ALARM to adjusting the TIME.
At this point the display will be flashing the seconds. Press the ADJ button and it will switch to Adjusting the Minutes. Press the AdJ button to advance the minutes.
Pressing the Start/Stop will switch to Adjusting the Hour. Again pressing the ADJ button will advance the Hour until you get to the correct one.
Once correct press the Start/Stop to switch to Adjusting the DATE. Press the ADJ to advance Month and Day.
Pressing the Start/Stop will finally switch to Adjusting the DAY OF THE WEEK. (little circle to the left hand side). Again, pressing the ADJ will advance the Day until correct.
This took me an hour just pressing buttons until I could figure this out. I hope this helps everyone.
Joe
Posted by: Joe From Oregon on February 04, 2008 at 09:39 PM
Aug 24, 2009 | Armitron Watches
Need instructions for Timex 1440 Sport watch
TIME AND DATE
CHRONOGRAPH
4. Press ADJUST to view lap time. Press again to sesume lap timing.
Nov 22, 2008 | Timex 1440 Nylon watch
I think I figured it out: (Start + Reset) = toggle alarm on/off ("ALM" will display in upper left corner when alarm is on. (press Mode once) will bring you in chrono mode, where "start" button starts and stops the chrono, and "reset" button resets it back to zero (press Mode once more) will bring you to setting of time for alarm. Set the "hour" value by pressing "start" repeatedly, then press "reset" and set the "minute" value by pressing "start" repeatedly (press Mode once more) will bring you to setting of time for actual time. Reset the "Seconds" value to zero by pressing "start" button once, then press "reset" and set the "minute" value by pressing "start" repeatedly, then press "reset" and set the "hour" value by pressing "start" repeatedly (if it shows "H" in upper right corner, time will be displayed euro-style 0:00-23:59, if it shows "A" time will be displayed 12am/12pm), then press "reset" and set the "day of month" value by pressing "start" repeatedly, then press "reset" and set the "month" value (1-12) by pressing "start" repeatedly, then press "reset" and set the "day of week" value (Su-Sa) by pressing "start" repeatedly (press Mode once more) voila!
Nov 12, 2008 | Watches
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Armitron WR165 watch - changing time
When you're in the regular time mode press "set". The secons should blink. Pressing "mode" brings you to the hour spot (hour should blink). Press "adj" to change the hour. To set the min., press "mode" again and the min. spot should blink press "adj" to change. Keep pressing "mode" then "adj" until all necessary time components are set correctly. Press "set" to get to regular time mode.
Aug 15, 2008 | Watches
Watches Logo
703 people viewed this question
Top Calypso Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Calypso Watch Expert? Answer questions, earn points and help others
