Question about Sharp MD-MS702 Personal MiniDisc Player
How to recover the TOC - Sharp MD-MS702 Personal MiniDisc Player
I've been sent a recently recorded 80 minute Sony Minidisc - but when I attempt to play it, a 'TOC Error' message is displayed. I suspect the disc was ejected from the machine immediately after...
Your diagnosis is likely correct and yes, you can save the data by a process known as TOC cloning.
Depending upon the make and model of your MD recorder(s) you may have to obtain a TOC-cloning friendly model, but every single piece of MD equipment I own has come for free via FreeCycle or Gumtree so you shouldn't have any problems in that respect. If you need one in a hurry then they're usually dirt-cheap on ebay.
I don't wish to plagiarise, nor is there any point in re-inventing the wheel, so if you click here you'll see detailed instructions.
Good luck. Sorry for the long delay in posting an answer,I have only returned to FixYa last week after a long absence and this section isn't often monitored by others as questions are rare now that it's obsolete technology.
May 13, 2011 | Audio Players & Recorders
My MD-MS702 gave me very good service. Unfortunately it was not used for five to six years and now when i switch it on after full battery charging I get TOC error on all of my recorded discs. SOS, as I am...
According to you You don't have use your disk play for a huge time, so that it may damaged or lens became dirty.
You can clear the lens with lens cleaner (clear the optical head).
check the battery was properly charged or working.
Check the disk moved properly.
To prevent the disk erase or damage slide the accidental erase prevention tab.
You can show it to the Technician.
Jan 06, 2011 | Audio Players & Recorders
Problem with Finalizing Disc
When you insert the disc what does the recorder display after it examines it (Reading TOC)? - CDR, TOC, CDR-W, NO TOC?
It should know the disc is not finalized and let you either record more on it or finalize it.
If not, and you need to recover the 4 tracks try loading the disc on a DVD player. My old Pioneer will read unfinalized CDR-A's so I can digitally copy what's on them back to another CDR-A.
Apr 13, 2010 | Tascam CC-222mkIII CD Player / Recorder
My dvd player won't read copied dvd movies but willl read store bought dvd movies in the device manage is says "unable to recover TOC error 0x13570001
one answer is to format the movies after you record them on dvd player. They would then be more likely to be read by the pioneer dvr.
Mar 01, 2010 | Pioneer DVR-107D DVD±RW Burner
Sony mdm-x4 when I load a disc it shows me blank disc, before that TOC reading. how can I get my record back?
You cannot remove power from a minidisc player after you are done recording as it updates the TOC when you power down. If you had switch set to timer "REC" and power up the unit it should update the TOC, otherwise all is lost.
Jan 22, 2010 | Audio Players & Recorders
Table of Contents TOC 4 appears with heading numbers in bold which I don't want. TOC 1, TOC 2, TOC 3 & TOC 5 are all okay
You can easily modify the formatting for a TOC. You will need to replace the current TOC - I'm assuming you are using the built-in reference to create your TOC.
Select Insert / Reference / Index and Tables. Click on the "Table of Contents" tab.
Click on <Modify>. Click on "TOC 3". Click on <Modify>. Click on the Bold icon to unselect the Bold attribute. Click on <OK> three times.
Sep 08, 2009 | Microsoft Word 2003 for PC
TOC ERRORa
When you FINISH recording, the Minidisc recorder Writes the TOC (Table of Contents) - so you see it flashing TOC or Update when you finish recording - you need to Leave POWER ON and have the unit on for about 30 seconds for it to finish this. IF you don't, the unit doesn't know where to find the files since there is no TOC. Try a Sony home unit - you might get one more shot at it working with that.
Aug 19, 2009 | Sharp MD-MS702 Personal MiniDisc Player
Spontaneous MD erasure
Well, depending how the content was recorded, there may be a slim chance to recover the audio. To me it looks like TOC was not written successfully, effectively deleting the TOC.
You can try TOC cloning with this 'blank' MD using another MD player, but your track markers will be lost during the cloning. If it works, at best you will end up with ONE long track. Then you can edit and reset your track markers.
It may be also be a good idea, to try the JE440 carefully with junk content to make sure it still works ok when writing TOC. You may have an intermittent problem too. I'd be very careful editing MD in this unit until it has been confirmed the TOC writing works ok. You may want to check the over-write head assembly and the cable that connects it. Sometimes these cables develop hairline cracks causing intermittend write action.
Check out www.minidisc.org forum for TOC cloning.
Good luck recovering your audio.
Mar 16, 2009 | Sony MDS-JE440 Mini Disc Player
Sharp MD-MS702 Personal MiniDisc Player Logo
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
