Question about Refrigerators
Fridge Freezer VCN6185B Fridge section freezing up.
Could it be temp sensor? If so how do I fit it.
22yooper
  • 828 Answers
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
  • 29 Answers
SOURCE: Our beko frost free fridge
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Posted on Aug 13, 2008
docjohn174
  • 943 Answers
SOURCE: My Bosch Fridge Freezer Model
Hi thanks for the question. I would pull fridge away from the wall . remove back panel . clean all coils . thanks the appliance doc
Posted on Oct 06, 2008
  • 6 Answers
SOURCE: Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Posted on Jan 18, 2009
  • 159 Answers
SOURCE: Fridge is cold and freezing up no matter what the temp control is set, and freezer is also overly cold freezing even stored liquor
it sounds like the thermostat. but check the defrosthing element also
Posted on May 16, 2009
Why are vegetables freezing in crisper?
There is a control on refrigerator that controls the amount of cold air that is directed from freezer to refrigerator section. Locate that control and lower the amount of cold air going into refrig.
Oct 07, 2015 | Samsung RF265AA Bottom Freezer French Door...
Food freezing in crispers in ge bottom freezer fridge
Check to see if the fan is working...put a thermometer in the refrigerator and make sure the temps are between 33-41 degrees F.
Dec 18, 2013 | GE Refrigerators
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Miela fridge freezer freezes food in the fridge
Most likely reason is fridge evaporator sensor faulty. The sensor is screwed to the back wall of the fridge behind bracket next to light and has a green band near the end . The sensor come as a repair kit (part no. 7323301). Just follow instructions in the packet.It is quite straight forward
Jul 24, 2010 | Miele KFN8762SDED Bottom Freezer...
Fridge section is too cold causing food to freeze
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 03, 2009 | Refrigerators
My performa refrigerator,on top,of unit is freezing all the food .where should the dial be set?
The fridge section shouldn't ever freeze anything.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 02, 2009 | Maytag Performa PAV2200
Fridge section freezes
I would need a model number to even try. Several different ones will probably work.
There are other reasons for the fridge to freeze. The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Does the compressor ever cut off? How about when you turn the freezer temp control to the warmer side.
Aug 18, 2009 | Refrigerators
Things freezes up in the refrigerator section of the home frige
If fridge is freezing, check the door seal on the freezer part. Make sure it is completely sealed, The freezer can leak air, allowing motor to pump freon continuously to fridge.
If the seal looks ok, try turning down fridge temp. If you have done this already, than I would look into having thermostat or thermometer sensor replaced.
Jun 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
FRIDGE COMPARTMENT FREEZING
i had the same problem the sensor starts at the back of the pcb and snakes its way dow the back of the fridge into the freezer conpartment i ordered a new sensor thinking it was a temp sensor but turned out to be a defrost sensor compleat and utter hassel to fit due to the expanding foam i had to eventualy cut the block off that conects to the pcb and then reconecting it once i got the cable through the foam first 2 days seamed to work fine while there was nothing in it as soon as i put food in it again the fridge started to freeze everything again then about a week later it still ices up at the back the fridge but doesnt seam to freeze the food so much now so still unsure about it all
btw it was the exact same model and before i changed the sensor the light and the super light used to flash on and off
Dec 02, 2008 | Hoover HCA390FFK Bottom Freezer...
Ffa70 hotpoint fridge freezer
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
