Question about Samsung Plasma LCD TV Remote Control BN59-01012A Supplied with models: B1930HD B2230HD B2430HD FX2490HD LE19C450 LE22C450E1W LE22C451E2W LE26C450 LE26C450E1W LE32C450E LE32C450E1W PS42C430A1W PS42C450B PS42C450B1W PS42C450B1WXXU PS50C430A1W PS50C450B PS5
I have no picture but its changing channels like crazy
Picture has gone but its going through all the channels like crazy, and wont stop until power is turned of
2 Suggested Answers
  • 15 Answers
SOURCE: i have a problem with my samsung tv
It probably is the Keyboard on the side. I've had this quite a few times. Simply pull off the back and unplug the side keyboard. It should be the last board in a chain of wires coming from the main to the IR sensor then finally keyboard. Unplug the keyboard and then plug TV back in and see if it stops, if so that was your problem, if not it will likely be your main board then. The TV usually can operate without the key board you will just have to use the remote for everything, but the keyboard is generally pretty cheap like $15.
Posted on Feb 18, 2010
My lg42lg30 tv wont turn off and the meno icons are going crazy cannot control it
Sounds like you have a main board issue. But if you can post a picture that would help confirm if it is the main Board. please respond to this same post for assistance.
Jan 03, 2013 | LG Televison & Video
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
The buttons on top of mt tv go crazy the flip channels automatically and turn volume up and down automatically
I have had this problem on this same model (F32650) and I discovered that what is happening is that dust and debris are causing the microswitches in the panel to short, therefore the channel starts changing and wont stop or the volume changes etc...
Get some electronic switch cleaner and (with the power off of course!) spray into the crevaces around each button and press each button a few times and then power the unit back on and it should be fine.
May 08, 2009 | RCA F32650 32" TV
Mitsubishi WS-65611 tv channels cannot stop scrolling
Check to make sure the channel down button is not stuck. If it is not the button is probably defective. Mits has had a lot of problems with the buttons.
Jan 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Tv remote sensor gone crazy
bad switches behind front control buttons
Oct 27, 2008 | Sony KV-27FS12 27" TV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
Jan 27, 2008 | ESA ET413E 13" TV
AUTO PROGRAMMING T.V.
Your TV is in Showroom Mode - to change:
Menu>Picture>Mode>Power up>Home
Then go back and autosearch channels.
Jan 10, 2008 | Olevia LT42HVi 42 in. LCD Television
Cannot operate tv manually or with remote
may have a corrupted eeprom which means you`ll have to call a tech, one thing you can try is;
Un-plug the tv`s AC power cord, wait 30 seconds, plug back in and pray, this will set re-set the micro to the default mode which may have gotten glitched by a power surge, hope it works for you.
Nov 30, 2007 | RCA P52926 52" Rear Projection Television
Samsung Plasma LCD TV Remote Control BN59-01012A Supplied with models: B1930HD B2230HD B2430HD FX2490HD LE19C450 LE22C450E1W LE22C451E2W LE26C450 LE26C450E1W LE32C450E LE32C450E1W PS42C430A1W PS42C450B PS42C450B1W PS42C450B1WXXU PS50C430A1W PS50C450B PS5 Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
