Question about Vtech Sit to Stand Alphabet Train
The hitch on our Vtech alphabet train was put in upside down, can it be removed and put in the right way?
How do I remove rear bumper to allow tow bar to be fitted
Trailer Hitch Installation 2012 Nissan Juke Hidden Hitch
click on link,,,,video shows you do not need to remove bumper if u buy the right hitch
Mar 18, 2015 | 2012 Nissan Juke
How do I get the VTech Learning Lodge Navigator back on my computer without the disc?
You might go to the following (VTech) link, select your specific product from the alphabetical tab for the downloadable manual (also here) and look for 'factory reset' in same manual. Hope this helps!
Electronic Learning Toys ' Best Learning Toys ' VTech America LINK:
http://www.vtechkids.com/support/product_manuals/A
Nov 10, 2014 | Toys
Is there a reset button on the cube?
Unfortunately, the cube does not have a reset button. The way to reboot it is to remove the batteries and put them back in.
Jun 29, 2013 | Vtech Alphabet Activity Cube
I have a Vtech DECT 6.0 cordless phone. I have lost the owners manual, where can I download another one, and how do I retrieve messages remotely? Thanks
You can get the vtech Dect user manual from here http://phone.manualsonline.com/manuals/mfg/vtech_communications/vtech_communications_cordless_telephone_product_list.html
Go to this site and below " vtech Coedless Telephone Manuals" click 'D' in the alphabetic order, scroll down the list until you see the model number of your phone.
If this solution was helpful please rate and leave a comment. thank you!
Jun 09, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Can I or how can if possible return the Pride Lift Chair to normal seating position manually.Thank you.btrapp@sasktel.net
The easiest way to do this is to tip the chair forward so that the top of the chair and the arms are on the floor. The weight of the chair will be off the lift frame in this position. Look at the motor and you will see it connected to the frame with 2 hitch pins.
It is easiest to remove the top hitch pin which will now be on the bottom because the chair is upside down. Pull the clip (looks like half of a paper clip) from the pin that goes through the square chair frame and motor round tube. Pull out the pin by lifting the bottom of the motor slightly(now at the top because the chair is upside down)with your left hand and pulling the pin out with your right hand. Find the two nylon washers that have fallen out when you do this.
Swing the motor tube out of the way toward the front of the chair. Hold on to the pin, clip, and 2 nylon washers for re-assembly. Hope this helps.
Dec 26, 2010 | Pride Mobility Products Casual CL30KD Lift...
Acer wireless keyboard kg-0917 right side of keyboard stuck on numbers
On that keyboard, the numpad is integrated into the alphabetical keys on the right side of the keyboard. You have to fit Fn + NumLk in order to turn the NumLock off and make it work normally again.
Feb 20, 2010 | Acer Wireless WIL-152 91.84R07.152...
Tyco trains are set up have power but trains will not move
Check the engine and transformer by taking the two wires from the transformer and, while holding the engine upside down put on wire against one side wheels and the other wire on the other sides wheels...that will tell you if the engine is at fault.
Jan 28, 2010 | Tyco Ho Vintage Wm Flat Car W/ Tractors...
View is upside down
Yes-- all astronomical telescope are upside down--
NO --- UP or DOWN in outer space! Reversing the image just introduces more "glass" into the optical train.
Mar 15, 2009 | Citiwell International Orbitor 5500...
Right door handle upside down pinches fingers. how to remove and flip?
mirellis, grab the handle with both hands and push in and up. The handle will slide off the retainer clips. To put them back on, line up the clip holes push in and pull down. I never tried flipping them, but you will find out real fast. This is for the GS6NBEXRL model that was posted, Catriver.
Nov 30, 2007 | Whirlpool GS6NBEXRL Side by Side...
Polaroid screen is playng upside dwn and
Thank you! Mine went upside down while kids were watching...I could not figure out how to fix...this worked great! Many, many thanks.
Dec 07, 2006 | Polaroid PDM-0723 Portable DVD Player
Vtech Sit to Stand Alphabet Train Logo
21 people viewed this question
Top Vtech Toys Experts
relojmesa
cloudranger
Level 1 Expert
Are you a Vtech Toy Expert? Answer questions, earn points and help others
