Question about Breville Irons
How to open to fill water in breville travel light spray iron
SOURCE: Breville steam glide 2200w iron
Hello, dont know if you still have no instruction book for this iron, i have the same iron and found the instruction booklet on there website. go to breville website, and irons and download.
Posted on Jan 16, 2008
johnny5846
  • 379 Answers
SOURCE: steamxpress 620 filling in water
http://www.useandcaremanuals.com/pdf/S600Series536.pdf
as i suspected , i looked at your user guide here , its like any other iron , when its standing upright , there is a hole sorta on the top pour water in there and a site glass in the handle area will show you how much is in there . hope that a fix ya .
Posted on Jan 02, 2009
SOURCE: water spray not working
I got a thin needle and gently made a hole through the centre of the nozzle - where the water would usually come out. That cleaned the scum build up out of it and it's working fine again. My nozzle does seem to look like its going into the iron but perhaps it's to get the correct angle of spray onto the clothes.
Posted on Mar 15, 2010
heatman101
  • 43501 Answers
SOURCE: water in iron box
Yes... you can use it dry...
Cleaning a Steam Iron White Scale and Brown Water
http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown
heatman101
Posted on Jul 14, 2010
bob_computer
  • 3153 Answers
SOURCE: My Breville Jet Select Iron
Almost all iron instructions suggest using a DE-SCALE once in a while.
Depending on your water type (hard/soft) would give you a guide as to how frequent.
Most supermarkets carry some form of descale liquid
in canada CLR is a good choice
many big box stores also carry it in the appliance areas.
you dont need much and as little as 250Ml will see you for a long time.
I prefer to descale items with a full load of water at the hottest setting
Allow for addition of at least 10% descale
let it sit for about 20 minutes then pour the water out and rinse out well to remove any debris
I often do that twice in case of stubborn deposits.
If yopu ever descal a kettle or tea maker, coffe maker then rense out extra well with cold water to make sure you remove all trace of the descale.
Posted on Mar 02, 2011
Digital settings flashing
Breville VIN170 Extreme Steam Digital Steam Generator Iron, unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on.
Below is a link to the user manual for the Iron
http://www.breville.co.uk/downloads/dl/file/id/378/steam_generator_iron_vin170_instruction_book.pdf
Hope this helps, if you require any further assistance please contact me.
Oct 18, 2014 | Breville Vin170 Extreme Steam Digital...
Filter light flashing what do I need to do no manual available
Aug 07, 2013 | Breville Vin170 Extreme Steam Digital...
Breville TECHnique VIN158
if the iron use electronic control, will be a little difficult to adapt or reset .However i recommend follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Jun 11, 2013 | Irons
Breville VIN 214 iron leaking - can anyone help please
  1. Unplug the iron.
  4. God bless you
Apr 04, 2013 | Black & Decker Prestige X805 Iron
My iron is getting hot but giving no steam can anyone advise
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jan 31, 2013 | Breville Vin227 Extreme Steam Steam...
How long should we wait before the iron is ready for use and producing steam
As soon as you lay your iron down to start ironing. It give off steam every little bit, it's not constant. If you want constant steam, fill a spray bottle with water and spray it lightly before ironing. Hope that helps.
Oct 18, 2011 | Irons
Iron getting power light on but not heating up and dripping water
I have a Breville Iron 2200W it went into auto shut down and now i can't get it to work
Jun 30, 2011 | Breville Irons
How do you reset the water filter light when you put in new filter on Breville Steam Generator please
Ok, had this too. Done some research and it looks like you have to unplug the iron from the mains , keep both the power and steam level buttons depressed and then plug in and switch on.
Chris.
Feb 12, 2011 | Breville Irons
Bosh sensixx B25L iron spraying brown water
I have a bosch sensixx b25l and it has started spraying brown water all over the clothes how do I descale it please
Feb 22, 2010 | Bosch Irons
I cant figure out how to put the water INTO the iron
Looking at the front of the iron there is a spray nozzle and right above it there is a spot that opens to fill with water.
Feb 23, 2009 | Black & Decker Steam Xpress AS250 Iron...
Irons Logo
27 people viewed this question
Top Breville Irons Experts
Are you a Breville Iron Expert? Answer questions, earn points and help others
