Question about Canon Office Equipment & Supplies
Canon f158200 shows no sign of life when power button pressed. Used another working power cable in case fuse in plug blown blown
No sign of life at all when power button pressed
  • 324 Answers
SOURCE: fujitsu laptop
Kev,
This seems to be a common problem. Remove and reseat the memory modules. If that doesn't do it, remove the hard drive and all but one memory module and try to bring it up. If this works, add the other memory module and see if the whole thing doesn't come up. If not, get back to me for more ideas.
Thanks!
Ron-
Posted on Nov 26, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Dimension 4 microwave model
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
Posted on Aug 03, 2008
SOURCE: Miele Washing Machine - Novotronic W827
Give the door a firm push shut (even if it appears shut already). There is a safety mechanism that stops the door opening when drum is turning and it gets its knickers in a twist sometimes. Happened to me twice in the last 5 years and can never remember how to fix so end up ringing Miele support who are always helpful. Next time I'll look here first!
Posted on Nov 05, 2008
  • 73 Answers
SOURCE: Jamo Sub300. No power. No lights
Well it would void the warrantee, but you can take the back panel off and the power supply will only have two leads (3 if grounded) in from the plug, and out to the crossover. It sounds as if you are correct that the power supply is bad.
Charles
Posted on Jan 05, 2009
  • 28 Answers
SOURCE: CP685AVR/BF685 Power Contro.
It is likely the battery. These batteries are designed to last 3-6 years in a UPS. The good news is that if it is the battery, it is completely user replaceable and you'll have a Cyber Power unit that works just like new with a new battery. What may have happened is that the battery was weak, and you may have had a slight dip in the AC power. This caused the Cyberpower unit to switch over to the weak battery which couldn't handle the load. The unit then turned off. When you press the "ON" button, the unit will go through a self-test that checks all of the components and the unit will not turn on and be functional unless all of the components come back with a PASS, including the battery. If possible, test the battery with a voltmeter, it should read around 13.5, but not lower than 11.5v DC. However, with the unit over 3 years old, it almost certainly the battery. Here's a link to a replacement battery for the CP685AVR: http://www.batteryinternational.com/cyber-power-cp685avr-ups-battery-ups-batteries-f1.html
Hope this helps.
Posted on Jul 01, 2009
I have Toshiba Satellite A200-1CC. It wont give a sign of life when the power button is pressed. AC power cord with jack are okay, Wall power cords are new. It won't fill the baterry, but when the bat
first try to check if your toshiba is still part of the warranty. if this is good, much better to go to the service center and they will replace the battery pack of your laptop.
Dec 15, 2011 | Toshiba Computers & Internet
It wont start i press the power button and it jus make a click sound, but it doesn't turn on
I have the same problem. Worked for 10 minutes and then turned off and every button just makes a clicking noise - no lights or other sign of life. Solution anyone?
Dec 17, 2010 | Panasonic SCBT330 Theater System
My A6110 suddenly quit working.. It shows no sign of life when I press the power button even when I am connected to wall.
The power adapter could be faulty or the power socket on the laptop could be faulty.
Please click on this link and follow my instructions to determine the fault and possible fix :-
http://www.fixya.com/support/r4799950-laptop_battery_power_supply_problems
Jun 11, 2010 | Fujitsu LifeBook A6110 Notebook
My 2414 won't start up ?help i press the power button the fan starts then with no sign of life.
may be your battery is down
some case you need to recharge it
or other worst case scenario may be your laptop is dead
Sep 25, 2009 | Packard Bell Computers & Internet
Oil reset
Courtesy of http://synthetic-direct.ca
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the Message Center, press the SET UP control to access the System Check mode. Press and release the RESET button to display “OIL LIFE % HOLD RESET NEW” is displayed. Press and hold the RESET button for 2 seconds until “IF NEW OIL HOLD RESET” is displayed. Press and hold RESET button until “OIL LIFE SET TO 100%” is displayed
Jul 21, 2009 | 2006 Ford Explorer
My shutter will not open. The power button presses in and nothing happens. I have since got a new battery that was the problem, shutter still will not open. Camera is not operative, please...
Can you get any signs of life? playback pictures etc? Try pressing the playback button instead of the power button. If camera display works then press the picture button and see if the camera will switch over and the lens extends. Also check if the tab on the battery door is not broken. This operates a micro switch to cut off power
Jun 19, 2009 | Fuji J150w Digital Camera
HP notebook will not restart after closing cover overnight
Think it went into hibernation. Unplug from a/c adaptor, and remove the battery. Let it sit for 2 or 3 minutes, then plug in a/c adaptor and turn the unit on. It should reboot like new.
Mar 16, 2009 | HP Pavilion dv6000z Notebook
Asus NRL-LS P4 MB power on issue
unplug the power wait for 30 secs, then plug in and retry
Dec 27, 2006 | HP (311185-001) Motherboard
67 people viewed this question
old marine
old marine
