Question about Cycling
Wahoo rflkt won't pair with my iphone - Cycling
Lost pairing of iPhone 5 to Panasonic kW tg7841. iPhone will not pair.
I recommend turning the Panasonic back to pairing mode. It probably came with instructions on how to do it.
Jan 28, 2015 | Apple iPhone 5
Connecting iPhone 5 to ANT+ devices
The Viiiiva Heart Rate Strap is an ANT+ to iPhone Bridge, along with the Wahoo RFLKT+ Bike Computer, personally I think I'd find the strap more useful.
Nov 11, 2013 | Apple iPhone Cell Phones
IPhone pairs up to radio but won't conect
Try toggling airplane mode on and off. If the issue persists try resetting all settings and network settings in Settings>general>reset. If the issue persists from there make sure that the device supports the iPhone. After confirming the compatibility, try backing up the device and restoring it as new through iTunes. Make sure to setup the device AS NEW, NOT FROM A BACKUP. You want to make sure you isolate the issue by setting up as new to know if it is hardware related or software related. If the restore as new fails you should contact Apple or reseller for a replacement if within the warranty period. Good luck
Aug 20, 2013 | Cell Phones
Dolphin bluetooth won't pair with iPhone 5
Clear the memory on the Dolphin by pressing the CALL and END buttons together for about 5 seconds. The 'clearing memory' message will be heard followed by "Memory cleared".
now pair your phone using 0000 or 1234 as the pass key.
Feb 25, 2013 | Dolphin Radio Communications
I told my Iphone to forget a bluetooth device, how do I get it back because it won't pick it up on my phone anymore?
First thing you need to do is to go into your Bluetooth settings and make sure that your phone is set up to pair with a device. Next, make sure that the device your are pairing to your iPhone, is in pairing mode. After both of these steps are complete, the phone should recognize the device and you can complete the pairing process. Hope this helps!
Jan 12, 2013 | Apple iPhone Smartphone
After the latest iPhone 3 update it won't pair with my 2005 RL.
i've had the same problems in the past with an old HTC and my blackberrys Acura tells me the phones aren't compatible. One will find the other and not pair so i started making the car and the device search at the same time, after 4 or 5 tries consecutive tries at that they have all finally paired. -My current Blackberry needed an update for this to work.
Mar 30, 2012 | 2005 Acura RL
My iPhone 4s won't pair with this kit hkt 300 by
Hi
I have just paired my Iphone 5 with the Hkt300.
I used the code 0000 while holding down the button on the car set.
Have fun
John
Nov 04, 2011 | Samsung Radio Communications
I have an Akona Wahoo scuba mask and the strap has broken. Can I get a replacement?
Most any scuba shop will have replacement mask straps.
They are very common replacement.
Dec 01, 2009 | Akona Wahoo Junior Mask
Cycling Logo
73 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
