Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Fabric softner won't drain. I have a front load gallery series that is two years old. Pump clogs all the time. I clean the tray where the detergent/softener goes in but it gets mold all the time. I have tried to clorox it and clean it and let it air dry after washing. I am disappointed with the machine. Clothes come out smelling like mildew.
  • 58 Answers
Dispensing issues can usually be sourced to the dispenser valve. Replacement of the valve should solve your issue. ... Hope this helps... Bill
Posted on May 18, 2009
The fabric softner reivore wont take in/ empty the fabric softner
I had this problem also. I pulled the drawer out, then removed the softener assembly. (the blue piece) In the front there is a hole that lets the softener liquid drain into the funnel to go into the machine. It was clogged with a little bit of dried up softener liquid. Cleared that and it worked fine. We've had the washer for 3 years and have had to do this several times. Seems to be a problem.
Oct 08, 2009 | GE WBVH6240F Front Load Washer
My washer wont drain out the fabric softner just adds water to it. cleaned the part where i put the softner thinking it was clogged but still happening.
Usually, the softener syphons out from the tray. The tray will have a tube, the tube will have a cap. Water filling the tray forces the liquid around the cap and tube. The falling water (now inside the tube) creates a vacuum-syphon effect.
Pull the tray, remove the cap, clean and try again. Provided the water's getting there, this should help.
Regards! --W/D--
Jul 14, 2009 | Frigidaire ATF6000ES Front Load Washer
My neptune washer will not drain the fabric softner container
This is joyce
I have advice for you check the siphon cap to see if its twisted reposition cap.
thanks
joyce
Jan 17, 2009 | Maytag MAH6500 Neptune Front Loading...
Kenmore 44082 washer won't take in fabric softener
Remove hoses from fill valve, clean screens inside fill valve, if this does not fix problem, replace valve.
Jan 17, 2009 | Kenmore 44102 Front Load Washer
Tray that holds fabric softner does not drain
I have had three sepaerate service calls and one independant analysis about this problem. For the whirlpool duet washer - this is a design flaw - nothing else - please notice that when you take the detergent tray completely out (and turn it upside down) a piece of plastic falls out but even if you put it back correctly the water only flows out into the washer - either washing everything away or leaving it behind - I have been told there is no fix.
Aug 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Eco Care Front load washer:Fabric softner clog
pull drawer out press down on tab rear left side and slide drawer out
Jun 04, 2008 | Kenmore 44832 Front Load Washer
Fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Oct 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidare Front Load Washer dispenser drawer wont drain.
I think you have something stuck in the fill hose.. Remove the top two or three screws in the back.. then pull out the hose that goes to the tub. I bet you will have something in there.. most common is the inside liner to a bleach cap..let me knowif this it it... krazytech
Sep 08, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washer not always draining
It sounds like you have a couple of things going on here. First of all, the most common problems associated with a poor drain on a washer is due to clogs in the pump and/or drain hose. But first, make sure you don't have your drain hose shoved down in the drain standpipe too far. If you don't leave an air gap for the drain hose, this will often cause poor drainage problems and/or siphoning of the water as it tries to fill (this may be a cause for your soapy clothes, too). The drain hose should rest inside the standpipe so that pipe is not sealed and the hose is not sitting in the drain trap. You can check your drainage also by connecting a wet/dry shop vac to the drain hose and try to pull water through it from the machine. There will be some residual water that remains in the tub after washing. Just follow these simple steps: 1. Unplug machine. 2. Remove the lower kick plate under the door. There will be a screw in the bottom corners of the panel holding it on. 3. Find the drain pump. It will be on the right-hand side and is usually white in color. The drain hose from the bottom of the tub will be connected to it. 4. Remove drain hose from standpipe and connect a wet/dry shop vac (if you have one) to the end of it. 5. Turn vacuum on and watch the drain hoses from the tub and from the pump. If the hoses collapse, you have a clog somewhere. 6. Remove the drain hose leading to the pump. Check the impeller area of the pump for debris. This is usually where coins, clothing labels and other items get caught. 7. Clean out the pump and drain hoses. 8. When finished, reconnect any drain hoses that you previously removed making sure you get a good seal with the hose clamp BEFORE you fill the machine. If you notice a leak during fill, hit the "CANCEL" button to stop. Make sure you place the drain hose back in the standpipe too. Now...dispenser problems are usually the result of fabric softener and mildew. If you remove the dispenser tray from the machine and look inside the compartment on the front of the washer, you will notice a series of small holes in the overhead portion of the cavity. This is where water gets dispensed into the tray and flushes softener, bleach and detergent into your wash. If these holes get clogged, the tray will not dispense properly. Take a rag and clean this area thoroughly using some hot water. The water will need to be warm enough the melt any fabric softener residue that may have accumulated over time. Next, clean the area really good with some bleach solution to get rid of any mildew. You may have to use something to clear all the holes of debris. Often fabric softener is the culprit and it cakes the holes up. A simple wiping down with a rag may not be enough to do it. A cotton swap of tooth pick works great at cleaning these holes. This is also a good time to take the dispenser tray and soak it in some hot water in the kitchen sink to clean it out as well. Good luck to you and let me know if you find this advice helpful.
Aug 13, 2007 | Kenmore 43142 Front Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
211 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
