Question about Sharp MD-MS702 Personal MiniDisc Player
An almost new MN702 left unused for years conclude its display routine with TOC ERRORa. Should I through it away? Thanks.
The recorder was perfectly preserved
2 Suggested Answers
TOLhamRadio
  • 509 Answers
SOURCE: TOC ERRORa
When you FINISH recording, the Minidisc recorder Writes the TOC (Table of Contents) - so you see it flashing TOC or Update when you finish recording - you need to Leave POWER ON and have the unit on for about 30 seconds for it to finish this. IF you don't, the unit doesn't know where to find the files since there is no TOC. Try a Sony home unit - you might get one more shot at it working with that.
Posted on Aug 28, 2009
I am getting a TOC error on the left drive with new laser.
Table of Contents errors can be the result of bad compact disk, bad laser or the head cannot get into position to read the TOC, Make sure that the new laser is aligned correctly and that the head has no obstructions at either end of the rails. Last but not least you may want to make sure the laser is working and you can check that by using a camera like the one on your cell phone, With the cover off, insert a cd in the drive and have your camera pointed at the area of the laser. You should see the laser light on your camera.
Feb 20, 2016 | Harman Kardon CDR2 2-Disc CD Recorder
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
When I try to play my sharp MD-MT15 midi dish player, it did not play. It say TOC ERRORa. Please some one help me to fix it. Thank you very much!!!
That's an ancient player!
Try using a different disc. Try using the external power supply.
User manual http://www.minidisc.org/part_Sharp_MD-MT15+MT16+MT20.html
Mar 26, 2012 | Audio Players & Recorders
How i can fix TOC ERRORa
Table of Contents errors usually happen if you lose power before the disc is 'finalized' when recording. You cannot unplug the unit before it is done with a disc, or remove it until it is done finalizing. You will see "TOC" flash when you are done recording. When it stops, then you are all set. Try a fresh disc and see if that works.
My MD-MS702 gave me very good service. Unfortunately it was not used for five to six years and now when i switch it on after full battery charging I get TOC error on all of my recorded discs. SOS, as I am...
According to you You don't have use your disk play for a huge time, so that it may damaged or lens became dirty.
You can clear the lens with lens cleaner (clear the optical head).
check the battery was properly charged or working.
Check the disk moved properly.
To prevent the disk erase or damage slide the accidental erase prevention tab.
You can show it to the Technician.
Jan 06, 2011 | Audio Players & Recorders
Kenwood MD plays ok but recordings fail to play; U TOC error?
Without a decent Table Of Contents, your MiniDisc will NOT work, as you've found out. Does it matter what brand of MD you use? I would record it at "1X" and NOT 4x speed too. Try erasing a blank minidisc first and then shut off the unit and then turn it back on and see if the TOC works. Try adding a title, then turn it off and back on. Then try the CD to MD.
Jan 16, 2010 | Audio Players & Recorders
What does TOC writing mean on my sony mini hif-fi
TOC(Table of Contents) Information referring to, for example, the table of contents, total numbers, total names, playing time, time, date, data position etc. When a new recording is made on the MiniDisc, the new information is updated.found this on a web site
Sep 14, 2009 | Sony DHC-MD333 Shelf System
TOC ERRORa
Aug 19, 2009 | Sharp MD-MS702 Personal MiniDisc Player
Sharp MD-MS702 Personal MiniDisc Player Logo
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
