Question about Toshiba Satellite Computers & Internet
Toshiba satellite P755-S5120 won't boot after windows screen stays black
  • 1003 Answers
SOURCE: toshiba satellite with windows xp will only show black sreen and wont let windows xp repair
AvioriX is right your operating system is gone.
if u dont have restore disk get a windows xp program disk from walmart or target or office supply store and load operating system from it.(this will only load windows xp.) but will bring computer back up
Posted on Jan 15, 2008
kikoksky
  • 119 Answers
SOURCE: Toshiba Satellite don't want boot from CD
try doing this.. go to your bios and change the boot sequence and select the dvd/cd as the first boot option.
let me know what happens
Posted on Jun 13, 2008
SOURCE: Toshiba satellite A205-S5847 booting problem
Check your GraphicCard. Have you tried downgrading to XP and can you tell if you facing same problem?
Posted on Jul 26, 2008
  • 30 Answers
SOURCE: Computer won't boot Windows Vista. Screen goes black with cursor arrow.
In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
in both the cases system will work .
Posted on Mar 25, 2009
  • 1705 Answers
SOURCE: toshiba satellite wont boot up windows just black
While your laptop is trying to start up, press the F8 key several times. This should give you several start up options. Select start in safe mode.
This will load a stripped down version of windows. Click on Start - all programmes - Accessories - System Tools - System Restore (This for XP, Vista and Win7 slightly different) and select a restore point priort to when the problem started.
Posted on Jun 28, 2010
Dropped laptop, broke the screen, replaced it.Turned it in, "reboot and select proper boot device or insert boot..." Pressed F2,F8,F12,del, doesn't work. I have Toshiba Satellite P755. Please help me.
take it in for a proper diagnosis
It is possible that when you dropped it , you have jarred the hard drive and it is now not reading the disc hence the request for the boot /reboot request
Jul 08, 2016 | Toshiba Computers & Internet
Automatic on toshiba p755
Not sure what system you are talking about. If you are saying that your Toshiba is automatically powering on then you may have a feature called wake on LAN enabled. Press the key at power on to go into your setup menu, look for the wake on LAN (sometimes called magic packet) feature under power control and disable it.
Feb 11, 2014 | Toshiba Satellite P755-s5120 Core I7 Pc...
How to reset toshiba bios
Just before it tries to boot press F1 or Esc and when it loads the bios select default. Press F10 and that's it. Basics are reloaded.
Nov 13, 2013 | Toshiba Satellite P755-s5120 Core I7 Pc...
How to factory reset my Toshiba satellite laptop P755-S5120, core i7, 64bit plese help me.
Go to BIOS setting through the Bios setting Key eg F2 and click on file then select set to Default.
Oct 04, 2013 | Toshiba Satellite P755-s5120 Core I7 Pc...
My Towhiba Satellite p755-s5120 laptop will not boot after I installed a BIOS update.
Big mistake. You NEVER upgrade bios unless it is absolutely necessary. It is basically a dangerous procedure because very often the upgrade does not take or work properly and you are left with a paper weight.
You have learned this lesson the hard way and now you have to deal with it.
Your cmos is corrupted - if you can go back to the original bios, great. If not, go shopping! (Of course, you can always get a new mo bo but with the cost of parts and labor, it will not be cost effective.) And stay away from HP - their service sucks big time since they will only provide assistance during warranty period. After that they refer you to forums or advise you to get another computer - an HP of course!
Sep 16, 2017 | Toshiba Satellite P755-s5120 Core I7 Pc...
My toshiba satellite p755 keeps shutting down
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Nov 04, 2012 | Toshiba Satellite P755-S5385 15.6 Intel,...
If I want to add more memory beyond the 8gb max from the MFR, will it work?
You cannot add more RAM that the recommended max. specified by the manufacture.
If you could install more than it 8Gb, either the laptop won't work OR it cannot access more than 8Gb of RAM.
Sep 04, 2012 | Toshiba Satellite P755-s5120 Core I7 Pc...
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
Computers & Internet Logo
29 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
