Question about Dell Inspiron 1525 Notebook
My dell inspiron 1525 has a built in disarray mic but computer does not detect it??I've tried downloading the sigmatel driver but it says object not found. The webcam center does not give me any options for audio source and only the line-in options appear in the recording devices and when I plug one in it doesn't work but it does on my other computer T-T I really want these mics to work( the built in ones) please help!!
    Problem Solver:
  • 5 Answers
Uninstall and reinstall the audio drivers. That should fix it. Also check in Audio/Sound properties in Control panel under Recording and check if the Array mic is detected and set as default. Try downloading "http://ftp.us.dell.com/audio/R171786.exe"
Posted on May 21, 2009
I did what meanees told me to do "Uninstall and reinstall the audio drivers. That should fix it. Alsocheck in Audio/Sound properties in Control panel under Recording andcheck if the Array mic is detected and set as default. Try downloading"http://ftp.us.dell.com/audio/R171786.exe"
Posted on Jul 21, 2009
No more mic
  • Hi, the best "option is to perform a System Restore," select from Control Panel or the "Accessories (System Tools) in the "All Programs," Start Menu. Select the (Date of recovery prior to the change); at least a day before to make sure the "Restore" will not miss any changes on the day of the change. Follow all the instructions "carefully," be patient, and "DO NOT RUN!" any programs during or after the System Restore is complete! The computer will "restart," system restore is still making corrections. "I Hope for the best, rating the solution is appreciated, thanks.
May 01, 2010 | Dell Latitude D410 Notebook
Dell Inspiron 1525 on board mic not working in win 7
download the driver from the maunfacturer site it will work when it is installed
Oct 13, 2009 | Dell Inspiron 1525 Notebook
I want realtek for my laptop dell insprine 1525
Try this one: http://downloads.zdnet.com/abstract.aspx?docid=922747
May 30, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525
The best thing to do is to download the updated drivers from support.dell.com. When you go to that webpage there is an image link there that would say driver downloads. just click that and it would ask if you would like to enter your service tag or if you want to just choose the system model. one you have entered. choose the appropriate operating system and click on the plus sign right beside the audio item. There you will be able to find the sigmatel driver for your audio.
for a quick link try to go to this address: http://support.dell.com/support/downloads/format.aspx?c=us&l=en&s=gen&deviceid=8907&libid=3&releaseid=R218148&vercnt=2&formatcnt=0&SystemID=INS_PNT_PM_1525&servicetag=&os=WLH&osl=en&catid=-1&impid=-1
download the file and install it. Hope this helps.
May 26, 2009 | Dell Inspiron 1525 Notebook
The built in mic on my dell inspiron 1525 does not work
Have you checked to see whether the correct settings have been selected for the microphone in the Control Panel>Hardware>Audio Devices page? Once you see which driver works (i.e., which one responds to your voice), right-click and set that as the default. Or you can try to set up the Speech Recognition program under All Programs>Accessories>Ease of Access, and try the different microphone settings till the onboard one responds to your voice. Perhaps the SigmaTel driver has been updated since you bought the laptop--go to the Dell Download site and download the sound driver for it, see if one of these helps!
Apr 10, 2009 | Dell Inspiron 1525 Notebook
The Internal Mic In My Dell Inspiron 1525 Isnt Picking Up Sound??
You need to set the internal mic as the default input device. To check this Right click on the sound icon next to the time and select Recording properties. In the Recording properties right click on Arrey Microphone and select set as default. If this does not help. Uninstall and reinstall the sound drivers. To uninstall the sound drivers click on start and type DEVICE. Open device manager from the results and then look for sound devices. Click on the Plus sign next to Saound and audio devices. Right click on the SigmaTel entry there and select uninstall. Put a check on remove this driver from the computer. Once done restart the computer and go to support.dell.com and click on Drivers and Downloads. Enter your system service tag and download the Sigmatel audio drivers and install them. Check if the MIC works after the restart. If the Arrey microphone is set as the default and you have uninstalled and resinstalled the drivers and it does not work in MSN try recording with the Windows sound recorder and see if it works there. To open the sound recorder click on start and type SOUND. Open sound recorder from the results. Incase the mic does not record even in the recorder it could be bad or have a loose connection. If in warranty call/chat with the Dell technical support. If the warranty has expired consult a local computer guy.
Mar 29, 2009 | Dell Inspiron 1501 Notebook
Sound not coming after formating system
try different drivers, the correct driver package will definitely install.
have you tried this one?
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&cs=19&l=en&s=dhs&~mode=popup&file=245332
if it doesn't  work check the audio card manifacturer website
it shoulb be a SIGMATEL STAC 92XX C-Major HD Audio
Feb 18, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Dell Inspiron 1525 Notebook Logo
446 people viewed this question
Alun Cox
