Question about Kitchen Ranges
Lamona HJA 2450 chimney cooker hood lights blew and will now not work with new bulbs although extractor fan works fine.
6 months old
  • 1462 Answers
SOURCE: Light blown then fan doesn't work!
take out switch assemby and check if the track of the pcb is blown - caused by the bulb goiung. you can often repair by soldering in wire links. bet you have 12a fuse in system - should be 3a. track has blown instead of the fuse
Posted on Mar 31, 2007
  • 1314 Answers
SOURCE: F60 SS Cooker hood
short in light switch
Posted on Dec 30, 2007
  • 171 Answers
SOURCE: WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
  • 203 Answers
SOURCE: baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Posted on Nov 22, 2008
manhandy
  • 146 Answers
SOURCE: Bulb blew on Whirlpool cooker hood and new ones fail.
well is there a switch you might want to check that out.
Posted on Jul 05, 2009
I have a 19'' polaroid tv dvd combo that will not power on at all and it is just a few months old.
If only a few months old it should be in warranty? If a 19 inch it may not be cost effective to repair if you have to pay to get it fixed.
SD TECH
Apr 26, 2012 | Televison & Video
Changing from newborn to three months old. removed head hugger but do i need to put the booster cushion part in?
Good Afternoon
At three months old your baby is not ready to have the headhugger removed. You should remove the lumbar support cushion from the bottom of the headhugger to provide additional space now that baby is 3 months old, but replace the headhugger without the additional lumbar support cushion. The headhugger is designed to protect vulnerable neck and spinal muscle in a side to side collision and should not be removed until baby can confidently sit up unaided - this is normally between 6 and 9 months old.
Sep 08, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
No power and it only 5 months old
I would phone the supplier and request an under warranty repair as it is not 12 months old yet.
Feb 25, 2011 | RCA 191409 Microwave Oven
A bulb blew in my tecnik cooker hood and neither the lights of the fan will work? is there a fuse somewhere that I need to change?
In case you are still looking for an answer. The same happened to me.
I found a 3-amp fuse which I changed, and now it's ok.
I removed the chimney casing and located the electrical connection into the wall. You'll find a fuse unit within the switch which swings out.
Hope this helps.
Dec 08, 2010 | Rangemaster Kitchen Hood
Our monitor (less than six month old) won't power up.
This is 2005 model, 3 year warranty. 6 months old?
http://www.amazon.co.uk/LG-Electronics-L1915S-LCD-Monitor/dp/B00076V8TY
You will need to open it up, first thing to look will capacitors int ehpower supply, main AC fuse.
http://s807.photobucket.com/home/budm/allalbums
Please verify if it is only six month old, otherwise, take it back to where you get it from.
Apr 06, 2010 | LG L1915S 19" LCD Monitor
No Picture on LG Tv. it is only 3 months old. I
The flashing may indicate a failed power supply. Or a bad backlight tube.
Only 3 months old? Any warranty?
Considering its age I would say a defective part or poor assembly is to blame.
Feb 05, 2010 | Gateway FPD2185W 21 in. LCD Television
Bulb blew on cooker hood and I replaced both. Light still won't work and neither will fan - both working fine until bulb blew.
hello. I can assist you. begin by going to the electrical panel for your home. You will be looking for the circuit breaker or fuse that controls this hood. Chances are the actual problem is that the fuse blew, or the circuit breaker kicked off. To reset, replace the fuse with a new one of the same amperage, or turn the breaker on and then off and then back on again.
Nov 18, 2009 | Televison & Video
My dvd player says no disk when there is on in it it is not even a year old
HI, if this unit is less than six months old, it should be returned immediately. the optical lens assembly has failed. it may be a possible manufacturing defect if the unit is only 3 months old. if its more than 3 months old, you will be responsible for this replacement of the optical lens assembly unfortunately.
Jul 15, 2009 | TruTech PVS12701 Portable DVD Player
Kitchen Ranges Logo
300 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
