Question about Tablets & eReaders
Tablet manual output x2 - Tablets & eReaders
Downloads?
recommending searching Amazon for your tablet cover and keyboard. Very successful for me (X2)
Mar 03, 2015 | Tablets & eReaders
Setting on charger for a Polaroid tablet, 6V, 12V, Help
Not sure of the model number of your polaroid tablet you have. Generally the adapter should be an AC adapter for 220V or 110V depending on country. It is unlikely you will have to select 6v or 12v. If you are unsure charge the tablet through the USB cable connected to a computer. It might take a bit longer to charge and make sure the computer is connected to mains charger to avoid drain on computer (laptop, etc) battery.
If you have a 7" tablet then I am assuming it is a PMID705. See manual on this link.
http://www.southerntelecom.com/upload/polaroid/pmid705/PMID705_User_Manual_20121210.pdf
The manual says it is a 5v DC output connector for the adapter. Not sure why you are asking the question. If in doubt send email to polaroid support on the address at end of the attached manual.
Sep 19, 2014 | Polaroid 7-in. Internet Tablet - Other
Not connected to wifi and too many pattern attempts
Hi, you can try resetting by following the below steps. It works for most tablets.
1 turn off the tablet
2 press and hold the power button and keep tapping the volume down button at the same time.
3 it should take you to recovery screen. Go to factory reset by using volume button and select by using either the center button on the tablet or the power button if there is no center button.
please reply if it helped
Mar 24, 2014 | Digital Reins 9" Inch X2 Android 4.2.2...
My daughter has a dell latitude x2 tablet. We
Hello dbessey,
High temperatures can cause a computer to shut down, this is done to protect the system from over heating and damaging components. Its possible the battery or some sort of power issue could be the cause, but its hard to know for sure. Its more likely an issue with a fan or vent, possibly even the heatsink that draws heat away from the processor and other components inside the tablet. Check to see if any vents are blocked or clogged with dust, can you hear any fans running? If not then maybe a fan has failed. Is the laptop used in a very dusty or smoky environment? If so there may be excessive dust and tar build up inside the tablet that is keeping it from cooling properly. The best thing to do would be to see if its still covered under a warranty and if they'll fix or replace it. If not, most repair centers will give it a once over and roughly diagnose the issue for free, if they need to take it apart to get a better look a small diagnostic fee may be involved. Personally I don't charge for anything that takes me less than 30mins to diagnose.
Hope this helps, and good luck.
Please leave feedback if you found this to be helpful, thank you.
Feb 16, 2010 | Dell Latitude XT2 Tablet PC
Acer travelmate C110 & Acer projector X11602
Hi Andrew,
you can try changing the output of the travelmate, to VGA Or External Device.
ensure you have the correct output lead from computer to projecter. Then on your keyboard you should have a button that changes the output. i.e numerical 5-6-7 or 8. usually says LCD/VGA et,c.
failing this try altering the output in the systems bios setup.
you can enter this by pressing F2 Or esc at bootup.
if your unsure, and none of this helps, i,d suggest visiting acers site. and downloading the user manual(s)
Mike @ Compurepair.
May 22, 2008 | Acer TravelMate C110 Tablet PC
Tablets & eReaders Logo
27 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
