Question about Kubik Digital Electronics Kubik Evo 8Gb Mp3 Player With Radio And Expandable Microsd/Sdhc Slot - Black
Organise playlist in different order for evo - Kubik Digital Electronics Kubik Evo 8Gb Mp3 Player With Radio And Expandable Microsd/Sdhc Slot - Black
How to put a playlist on a kubik evo
Try rebuilding the Music Index using the option under the Music Menu when the device is powered on
Apr 12, 2014 | Kubik Digital Electronics Kubik Evo 8Gb...
How do i create a playlist?
Creating a playlist differs from device to device. If for example you have an iPod, in itunes you can use File>New Playlist. You can drag tracks to the playlist and then sync your iPod. However if you have an MP3 player which supports drag and drop files onto the device, just create a folder called Playlist1 for example and add all the songs you would like in the playlist to the folder and play it as an album on the MP3 player. Hope this helps.
May 04, 2011 | Audio Players & Recorders
How can i use my i tunes with the evo?
You can purchase a program from market. It is called Isyncr . It allows you to sync playlists and albums from your computer. Here is the market link for that app.
https://market.android.com/search?q=isyncr&so=1&c=apps
Mar 28, 2011 | HTC EVO 4G Smartphone
I don't know how to save all my i-mac music into the Seagte hard drive? I've followed the instruction few times and download the software, but I just don't don't know how to save my i-tunes music into the...
open up Itunes in the top left hand corner select file from the drop down list select library then you will have options toback up to disc organise library export library import playlist and export playlist
hope this helps
Mar 22, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
On my Gogear Raga 2GB I can't make a playlist. (SA2RGA02). With WMP I can synchronise the music, but there's no playlist on the device. All the music is stored in different folders on the Raga and not in...
Sync all the songs you want onto the raga via 'songbird'.
Stay connected, then go to windows explorer, identify your device. Then in 'Music', make folders for your playlists. Manually transfer (drop and drag) your songs to the required folder/playlist.
When using the raga use the 'folder' option. Works as playlists.
grayza
Jul 10, 2010 | Philips GOGEAR SA6045 MP3 Player
I dont know how to put music on my ipod shuffle
1. open itunes.
2. make a SINGLE new playlist (name it, too).
3. add all the songs you want to that playlist,
I suggest you organise the songs as well.
4. connect the shuffle.
5. sync it with the playlist you just made
6. wait for it to be done, eject, and enjoy!
Oct 24, 2009 | Apple iPod shuffle MP3 Player
How to seperate music files. I would like to add individaul playlists. Instead of all songs grouped together and you have to shift through all songs to get to the one you want.
Hi shannitar,
You can try placing the music files in different folders. If your mp3 player supports playlists (which it should), then go to the folder where your music files are kept, use ctrl+ click to select those you want to add to the playlist IN THE DESIRED ORDER, then right click and choose "creat playlist". A .pla file (or any other extension) will be created, which you can now play on your mp3 player.
Oct 17, 2009 | GPX Audio Players & Recorders
3g nano ipod
you need to organise the playlist in the order you want.
First you need the mp3 files. Then use itunes to make a playlist and make the playlist the same order as the cd, or as you want it.
Mar 29, 2008 | Apple iPod nano 3rd Generation
My MP3 Hates THE OFFSPRING!!!
Your music is organised right? wink.gif That will solve your 1st problem.
Playlists will solve the second problem. My sister has some soundtracks which I don't really want polluting my player. Or browse your player by album to pull them up?
You can clear out playlists, go to the now playing view, tap the scroll strip to pull up the rating, and tap it again to show the current 'play order'. Bring up the context menu (right click) and go to remove... remove all.
I also have set my programmable key to "Add to playlist", much faster.
Nov 08, 2007 | Creative Labs Zen Nano Plus MP3 Player
Kubik Digital Electronics Kubik Evo 8Gb Mp3 Player With Radio And Expandable Microsd/Sdhc Slot - Black Logo
Top Kubik Digital Electronics Audio Players & Recorders Experts
richie46
ray gallant
Robin Brighouse
Robin Brighouse
Are you a Kubik Digital Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
