Question about Electrical Supplies
Engine wont keep running
Engine stops running after about 1 hour of run time
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Check low oil shut off sensor... look for a yellow wire coming out of the block... if you disconnect it and it works... make sure you always check your oil
Posted on Dec 28, 2013
My car keeps cutting off everytime i stop. it will start right back up but then will cut off when i stop again
had a similar problems with my saturn, at lights and stop sings i would get a low idle and almost like it was about to stall.
1- the delar will tell you it may be an altornator problem, this is most likly not it.
2- SPARK PLUGS, i changed mine and my engine ran a lot smother and less "almost stalling" (also wont hurt to change your spark plugs.
3- fule injectors and filter may be clogged and dirty. Replace both.
all of this you can do by your self with less then $200 and and about 3 hours for every thing. Take your time plan out your route and ask the guys at your local car parts shop for more advise.
***** MAKE SURE YOU DISCONECT THE BATTERY WHEN DEALING WITH FULE AND ELICTRICITY*****
Sep 12, 2012 | 2006 Saturn ION
R6 engine starts then runs and if u keep it running it wil run fine but if it stops wont restart again when u pull the choke its as if it is about too run but wont any ideas
Hi, sounds like fuel, however try testing the temprature of all four exhausts while the engine is running, poss spark plugs are fuel contaminaed. Care should be taken as the exhaust pipes close to the engine become extremely hot, but 1 exhaust not as hot as the others would point towards a fuel starvasion or a fould spark plug
Aug 12, 2011 | Yamaha YZF-R6 Motorcycles
Carb adjustments/ rule of thumb
Assuming that the adjustment screws 'H' and 'L' have slotted heads, turn both CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on. Turn H CW until the engine starts to speed-up, but still 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW for fairly smooth running, yet allows the engine to 'follow the throttle'. Adjust idle speed so that the chain stops turning, but the engine keeps running.
May 21, 2010 | Husqvarna Chain Saw 20" Bar
Hard to start, and wont idle long.
Check the air cleaner and muffler for plugging first. Turn both jet needles CW to stops (lightly), then back out each CCW 1-1/2 turns. Turn the idle speed screw CW about 1/2 turn. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on and adjust the H needle CW til the engine speeds up somewhat, but is still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and allow to idle. Turn the L needle CW until the engine runs fairly well, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops moving, but still allows the engine to keep running. Hope this helps!
May 10, 2010 | Garden
1996 astro van stopped running
Sounds like dirty gas and the fuel filter is clogged...try changing the fuel filter...some are under the car, but most are mounted against the firewall in the engine compartment.
Apr 19, 2009 | 2005 Chevrolet Astro
1985.5 PORSCHE 944 digital clock (changing time)
There are three buttons, let's call them 1, 2, and 3, from left to right.
Clock
Time setting
A. 12 AM, PM or 24.00 h
With the clock in the time readout mode, keep
button (2) depressed for 4 seconds -12 AM, PM
or 24.00 flashing. After pushing button (1), either
a 12-hour (AM + PM) or a 24-hour setting
program can be selected. If you only want to
change the display mode, push button (3). The
clock then returns to its normal timekeeping
function.
B. Hours
Push button (2) a second time - hour display
flashes. Set hour by pushing button (1). After
pushing button (3)*, the clock returns to the time
readout mode with new hour setting.
C. Minutes
Push button (2) once more - minute display
flashes. Set minute by pushing button (1). Upon
pushing button (3)*, the clock is started -
accurate to within 1 second.
Stop watch function
The stop watch can only be set in motion if the
clock is in its normal timekeeping mode and not
during setting operations.
A. Push button (3) - 00:00 display appears;
B. Push button (1) - stop watch is on;
C. Push button (1) a second time - watch stops.
(Additional times can be added by pushing button
(1) again - stop watch keeps running. Push button
(1) once more to stop timing.)
D. Push button (2) - 00:00 display appears;
E. Push button (3) - normal timekeeping mode.
If button (3) is pushed during operation A and
B, the setting procedure must be restarted
Apr 17, 2009 | 1985 Porsche 944
1999 Ford Windstar. engine stalls.
You know, lookinig at this problem more, you have more possibilities of what may be wrong:
  1. Your idle speed may be incorrect
  2. Fuel filter may be clogged or water and impurities in your fuel system
  3. Possible damaged coil pack or wires
  4. Emissions sytem components faulty (a sensor, catalytic converter, muffler, etc.)
  5. Faulty or incorrect gapped spark plugs
  6. A vacuum leak at the intake manifold or vacuum hoses (check the hoses for cracks or damage)
  7. Fuel injection or engine control systems malfunction (ECM)
This should keep you busy....at least with the easy stuff to inspect.
Mar 17, 2009 | 1999 Ford Windstar
1995 Nissan 240sx will not keep running.
hi
you need to replace your battery.since the alternator is supposed t o charge the battery. y dont you start your vehicle, have it run for 1 hour or go on an hours drive, come back home, turn it off,after five minutes start the vehicle..see if it starts.if it does not, that means your battery is dead.
hope this helps
kind reagards
RAhUL_hunk
Mar 10, 2009 | 1995 Nissan 240SX
Motorcycle engine stalls when cold.
fresh battery, turns over but wont start. 1995 gixxer 1100. chone on full then half then almost none still wont start.
Jan 09, 2009 | 2004 Sym Husky 125
Electrical Supplies Logo
22 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
