Question about Rotary Drills
Milwaukee loktor has no power
The drill will start, stop, no problem. It no longer has any power, even after purchasing a new battery.
    Champion:
  • 304 Answers
Maybe the brushes need changing.
Posted on Feb 03, 2014
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: hello their!! i have a
Could be quite a few things from the switch to the brushes. Milwaukee I believe now has a 5 year warranty on their tools so I would recommend taking back for warranty service. Let me know if not and I would need the model number so I can look at the parts and try to come up with something.
Posted on Jan 25, 2009
  • 104 Answers
SOURCE: stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
Posted on May 23, 2009
comax
  • 154 Answers
SOURCE: milwaukee 18v battery
No, it's showing that the battery is either not taking a full charge or the charger is not charging the battery properly. Find a Milwaukee service center, they will check them and most likely replace one or the other.
Posted on May 28, 2009
rowdy45176
  • 2176 Answers
SOURCE: Milwaukee heavy duty hammer drill only works when
could be loose connection at the switch or brush holders. You can go to Milwaukeetools.com to download a breakdown for this tool.
Posted on Aug 15, 2010
My Milwaukee m12 sawzall won't run. The fuel lights flash it runs for a second than stops. But once I get it running it runs till the battery runs out. I
New armature + carbon brushes are much cheaper then replace a battery , if the tool give a sharp sound it have a problem with the armature ( it is a frequent problem by Milwaukee but also Panasonic on the Johnson made armatures that have both brands because of the latest winding technique more power but a problem heat dissipation and thermal runaway in the long run.
The older Johnson armatures have no problems with the build up inside heat but have only some less and power worn collectors by many operating hours
The best option is the cheapest decision first replace the armature only if the tool sounds sharp and not smooth anymore thats the decision and its the best choice if you are thinking that the battery has no capacitance anymore it will have longer life armatures have a lifetime between 2 and 3 years if daily use but can be shorter but no longer for the battery that will stay much longer there is with Li Ion no memory effect to fear Many people are mistaken in the fact that the anchor can be the problem of a rapidly emptied battery.
If the armature has no problem the switch could be give the problem too but is relatively more expensive to replace.
remove the brushes and make a measuring on both brushholders for the dc voltage that its not faltering without the load of a bad armature
Oct 05, 2016 | Milwaukee 2611-20 18V Cordless M18 High...
I charge my batteries but when I use them they go dead very fast
Your batteries no longer hold charge as deeply as they once were capable. Typical symptom of rechargeable batteries. You need to replace them.
Jan 07, 2011 | Milwaukee Tool Milwaukee 48 11 2830...
My 28v milwaukee batteries do not last any time and they are only a couple of years old
Unfortunately even rechargable batteries have a limited lifespan. Two years is good, if you get three years out of one you're doing very well. Lifespan is determined by how much you use then, how many recharges you put on them and how far down you drain them between charges. The more power you take out of a battery before charging it back up the better. Also, there are no repairable parts inside a battery and no way to recondition them once they're worn out. Sorry, not what you want to hear, but the only fix is to buy a new battery.
Sep 09, 2010 | Milwaukee Tool Milwaukee 48 11 2830...
Is anyone there? need Dewalt help
Here is DeWalt's marketing thing on the subject.
http://www.dewalt.com/us/cordless/powerrating/
Unit Watts out (UWO) is their rating for the (presumably sustainable)maximum power output at the chuck of the drill. You can read about it..their explanation is basically technically correct.
Yes, max torque is related. The maximum power in a permanent magnet DCmotor system occurs at half the maximum speed when the system is loadedwith half the maximum torque.
1hp = 746 watts, DeWalt's DC900 36V drill is claimed to be 750 watts,close enough so let's call it 1 HP ok? Their max RPM is 400. So 200 RPMis the half-way point.
1HP = 200RPM*Tmax(in-lbs)/(24*5252)
Tmax = approx 630 in-lbs
The equation I used is known equation for relating power (HP) to RPMand torque (in ft-lbs..I added in the factor of 1/12 to account for thein-lbs to ft-lbs conversion).
By the way DeWalt make some bold claims about other manufacterers' drills.
For example they claim the 18V Lok Tor by Milwaukee puts out 390 UWOcompared to their DC988 model listed as 420 UWO. Yet I have readinformation from Milwaukee's own independent tests that claim the LokTor drills faster 2 9/16" self-feeds AND more self-feeds per batterythan that very DeWalt model.
This was posted on Milwaukee's Tool Talk forum (when it existed). Ibelieve the Milwaukee official said that DeWalt averaged 7.2 secondsper hole while the Milwaukee averaged 6.4 seconds per hole. I make beoff slightly but I do remember it was around a 1 second difference.Plus the Milwaukee apparently drilled 28 holes per batt where dewaltwas 25.
Feb 22, 2010 | Dewalt DC925 Cordless Drill
Can I fixed my old 18v milwaukee battery. Jack
what is wrong with it? If it is dead usually there is nothing that can be done, if it is melted you can try cleaning the contacts and looking for a loose connection. Let me know and I will try and help
Nov 19, 2009 | Milwaukee Tool Milwaukee 48 11 2830...
Won't charge fully
If your warranty has expired, you're best off buying a new drill. Replacing batteries will quickly add up to the cost of a new drill.
I know they cost a lot more, but, if you want something that will last a lot longer, look at a Milwaukee, DeWalt, Makita, Bosch, Hitachi for your replacement. Milwaukee actually guarantees their LiIon batteries will last 1,000 charges or longer.
May 24, 2009 | Black & Decker 14.4v Cordless Lithium...
Hello their!! i have a new milwaukee rotary hammer drill. i was using it today and for some reason i could push the trigger and it would pause for for about a half second before the drill started... the...
Jan 24, 2009 | Drills
Drills Logo
Top Rotary Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Rotary Drill Expert? Answer questions, earn points and help others
