Question about Video Game Consoles & Games
Error code 103-2006
Wont let me connect to the internet have wifi and it was successful but the connection to the internet failed
Nou Wifi vervbindung
Posted on Mar 30, 2016
My innotab max keep giving an error message 404 which mean not connected to the internet but it is
I too have a InnoTab MAX children's tablet with same issue. Power cycling it, leaving cartridge plugged in/then out, have power plugged in then not, forgetting WiFi connection and re-linking after verifying WiFi is fine from other devices, also standing beside the wireless router all have been fruitless.
Having spent an hour on it last night and almost that long tonight - it's going back to BestBuy tomorrow. If I resolve the issue I'll pay what I did.
Dec 25, 2015 | Toys
Unable to connect to the Internet Confirm the Internet settings of the wii console. Error code 50299.
Go to internet options on your Wii settings, select internet, and then connection settings. Once that is done you will be able to see the wifi connection. Click the wifi connection and delete it. Try to reconnect the Wii to your wifi router and you should have success connecting to the internet. If it doesn't connect repeat the steps listed above.
Dec 31, 2014 | Nintendo Wii Console
Why wont my huawei y530 connect to any wifi
Hi
First, make sure your WiFi is turned by going to settings> Wireless & Networks" If it is on then you will see a list of networks within range, each of which you can tap on to connect to it.
To connect to a WiFi network, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your phone will remember the settings until told to forget them.
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code.
Cheers
Nov 27, 2014 | Ascend Huawei Y530 - Unlocked, Black, 3G,...
How do I connect to my wifi
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them.
Cheers
Nov 17, 2014 | Polaroid 7" Internet Tablet Android 4.0...
When I use the wi-fi connection with the LAN cable provided and run the connection test, all of the tests are successful except for the Viera connection. It is saying the connection failed 006. How do I...
Viera has a set-top box in the TV and the lan wifi router can be connected to cable plant for internet. TV can also send out programs on the set-top box to other wifi receivers. Error code 006 is server failed, Panasonic had a fix on jan11, 2012.
Feb 11, 2012 | Computers & Internet
My grandson has a DISXL and is trying to set it up for the internet. I am getting error code:051110-1. It is also asking for a security key. I need help.
do you have wifi? If you don't have wifi it wont connect. Plus if you do have wifi you prob. put a sec code in to block outsiders. so you need that same code to access your wifi
Dec 30, 2010 | Nintendo Toys
How can I connect my dsi to the internet
It will then search for wifi signals. If it's protected, you obviously need the key. Anyway, choose one, put in the key and whatnot, and it will then attempt to connect. If it was successful, it will say so. If not, it will tell you and five you an error code. This means some security of the wifi you're trying to use prohibits you from using it. If you are admin for the wifi, you can input the error code in Nintendo.com to find out what to do to open the connection up to allow you. After that, you can access the DSi shop, the Internet after downloading the Browser, or use Internet in games
Aug 25, 2010 | Nintendo DSi Black Console
Can't resolve a W010 connection error
Let put all not IP Address in Obtain. I put all IP ADDRESS manually. Usually this will cause to your internet connection drop. I encounter your problem before but i use DUAL WAN or 2 Internet Provider.
And i hope it's the same problem to me.
Aug 29, 2009 | Actiontec GT704WG Wireless Router...
Wireless router wont connect
Hey mentalmc,
I had this problem at least once a month. Try these things out.
1. Make sure any WEP codes are entered EXACTLY as it is for your router.
2. Set up your router so only your PC connected to it can change any settings.
3. Turn off your PC while trying to connect via PS3 WiFi. The good ole Win update likes to download without you knowing it sometimes.
4. If all else fails, call Sony cause you may have a bad WiFi antenna or motherboard.
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
Http error $code$
i've gotten that a couple times when trying to connect via the internal modem, a simple reset usually fixed it. If your wifi settings are messed up make sure your wifi switch is on, ensure it is enabled in com manager too. Also, try removing the wireless network via the software and adding it again. if all that fails do a hard reset. If that fails you are pretty much out of luck. I had two MDA's.... they both slowly got **** as months went by and i constantly had to reload the firmware, you may want to consider a different model
Jun 11, 2008 | T-Mobile MDA
Video Game Consoles & Games Logo
862 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
