Question about Simpli Home Amherst Collection Entryway Bench in Dark American Brown
Cam locks that came with bench are broken. We need more so how do we get them?
While attempting to assemble the bench all the cam locks broke. How can we get more?
How to replace a broken timing belt for a 1998 daewoo lanos?? Would there be any head damage?
yes it is quite possible that valves are bent if the cam belt broke or teeth stripped off of old belt, which unfortuneately means removing the cylinder head and getting it repaired (valves replaced and possibly guides) see some of my other posts for cam belt timming marks locations etc...
depending what motor is in your vehicle twin cam or single?
stevenhurc_14.jpg and if its twin cam you usually need cam locking tool for cam gears.
Apr 20, 2011 | Daewoo Lanos Cars & Trucks
Stearing wheel horn assembly wire to th stearing colum is disconnected
The wire on the steering wheel should have a plastic peg on it. The column where the wire goes should have a notch for the peg to turn into. If one of these is broke they will not stay together.
Sep 22, 2010 | 1993 Chevrolet S-10 Blazer
Error F93 lock out of the oven how do i reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 30, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
I get a code f90 when trying to either lock the oven door or attempting to clean the oven
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Jun 26, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
What dose f90 mean
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@$##%^
Jun 20, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Code f90 indicated
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%#
May 26, 2010 | Kenmore 47153 Stainless Steel Dual Fuel...
F93 error code
unplug the range.
wait 1 minute.
wait 2 minutes.
Apr 24, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
How much for a cam shaft and timing belt replacement parts & labour approx.
Did the cam break? Or are you just changing the belt? If the cam broke, you will have more damage than just the cam, the rods, valves, pistons could all be shot. Just the belt is no big deal, a shop will charge about $180, get a couple prices, find a shop that doesn't have broken cams on their bench,(bad sign). Hope this helps.
Mar 13, 2010 | 1991 Mazda 323
I have 03 land rover freelander and the intake cam has broke at the timming gear twice now wondering if there is a common prob with this and a fix it is the v6 and its on the front bank
the cams are fragile too big a job to describe in full . bet it broke after cam belt change should never use power tools to undo cam pulley bolts all the bolts should be undone only when engine is locked with correct locking kit to avoid strees on cams new bolts should be fitted on re assembly to correct tourqe setting while cams are locked hope this helps you
Jan 22, 2010 | 2003 Land Rover Freelander
F93 fault code
unplug the range.
wait 1 minute.
wait 2 minutes.
Oct 04, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Simpli Home Amherst Collection Entryway Bench in Dark American Brown Logo
325 people viewed this question
Top Simpli Home Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Simpli Home Furniture Expert? Answer questions, earn points and help others
