Question about 2003 Isuzu Ascender - All Ascender models - Sportz SUV & Minivan Tents
Removing valve cover on a 03isuzu ascender
Valve cover leaking
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
You need a special socket to remove the bolts 10.00 at the part store. Also get a new valve cover gasket. Very simple job.
Posted on Apr 02, 2014
Valve cover leaking
you cant maybe use an open end wrench or possibly a rachett with extension and a swivel
Dec 27, 2013 | 2003 Isuzu Ascender - All Ascender models...
Valve cover won't come off
Follow the detailed procedure mentioned in the link below to remove replace VALVE cover:----
Click the link below:---
VALVE COVER GASKET REMOVAL GUIDE http://technoanswers.blogspot.in/2012/06/valve-cover-gasket-removal-guide.html
For more help on these issues,check the link below:---
Car oil leaks from valve cover gasket? http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Lexus RX: Tapping noise under Valve Cover At Low RPM? http://technoanswers.blogspot.in/2012/04/lexus-rx-tapping-noise-under-valve.html
---------- How to replace Timing Belt,Water pump And Valve Guides on Mitsubishi Montero http://repairhelpcenter.blogspot.com/2012/10/how-to-replace-timing-beltwater-pump.html
2000 Toyota Solara: Valve Cover Gasket Replacing? http://technoanswers.blogspot.in/2012/04/2000-toyota-solara-valve-cover-gasket.html
Valve Cover Keeps Cracking? http://schematicsdiagram.blogspot.in/2012/04/valve-cover-keeps-cracking.html
These details will help.
Thanks.
Nov 23, 2012 | 2006 Subaru Forester
Leaking valve cover gaskets - repair estimate $1000.00. Is it worth it?
no it is not worth that much, you can do it yourself for about 20-40 dollars (price of the gaskets)
follow these for better instructions go to www.autozone.com and register to become a member
this will give you access to their repair database there you can specify your car and get repair info.
Removal & Installation2.0L Spi Engine
  1. Loosen the clamp and disconnect the engine air cleaner to valve cover hose from the valve cover.
  2. Remove the two ignition wire separators from the valve cover. Position the spark plug wires aside.
  3. Remove the three valve cover bolts and remove the valve cover and gasket.
To install:
CAUTION Do not use abrasive grinding discs to remove gasket material; only use manual scrapers. Do not scratch or gouge aluminum sealing surfaces or oil leaks may occur.
NOTE Do not use any sealer with a silicone-type gasket.
  1. Install the three valve cover bolts and remove the valve cover and gasket.
  2. Install the two ignition wire separators from the valve cover.
  3. Tighten the clamp and disconnect the engine air cleaner to valve cover hose from the valve cover.
2.0L Zetec Engine
  1. Disconnect the crankcase ventilation hose from the fitting on the valve cover.
  2. Disconnect the wiring connector at the oil control solenoid.
  3. Disconnect the speed control (if equipped) and the accelerator control cable.
  4. Position aside the accelerator cable.
  5. If equipped, disconnect the speed control cable from the bracket and position aside.
  6. Remove the ignition wires from the spark plugs.
  7. Remove the bolts and position the upper timing belt cover away from the valve cover.
  8. Remove the valve cover.
  9. Fully loosen the ten bolts.
  10. Remove the valve cover and valve cover gasket.
  11. Inspect the valve cover for damage. Install new cover as required.
    CAUTION Do not scratch or gouge aluminum sealing surfaces or oil leaks may occur.
  12. Clean and inspect the sealing surfaces of the valve cover and the cylinder head. Both surfaces must be clean and flat.
To install:
  1. The valve cover gasket and the valve cover must be installed and the bolts tightened to specification within four minutes of sealant application.
  2. Apply a 0.1 inch (3mm) bead of silicone sealant in two places where the front camshaft bearing cap meets the cylinder head.
  3. Install the valve cover.
  4. Position the valve cover gasket.
  5. Position the valve cover.
  6. Tighten bolts in the sequence shown.
    Fig. The proper torque sequence for the 2.0L DOHC Zetec engine
  7. Install the upper timing belt cover bolts.
  8. Install the ignition wires.
  9. Connect the oil control solenoid connector.
  10. Connect the crankcase ventilation hose.
  11. Connect the speed control (if equipped) and the accelerator control cables.
  12. If equipped, connect the speed control cable to the bracket.
May 13, 2011 | 2001 Ford Escort ZX2
Valve cover is leaking oil on my 2000 1.9 TDI Passat. Have changed the gasket but still leaking badly. Have been told to change whole cover but VW want £120,00 Any ideas?
will try to help.if it's only the valve cover leaking,i'm guessing they sold you the rubber one that says ne rtv sealant needed. take your back off, try not to break the rubber seal when removing!clean the top of head where gasket goes. clean the valve cover really good!clean the grooves out that the gasket slides into. buy some blue trv glue, apply a thin coat to top of head, let it setup while you apply another thin coat to valve cover, let set 10mins. apply gasket to valve cover making sure to push the gasket into the grooves on valve cover. don't worry about neatness. let the valve cover set on a hard surface with the gasket against the hard flat surface[such as a garage floor,or clean driveway] after10 more minutes install the valve cover,make sure and take your time. place valve cover onto motor,than hand start each bolt to insure thay are going into the prope bolt holes. after you have each bolt hand started, start at center of valve cover snugging the bolts down to motor. do not crank down or apply excessive force when tightening those bolts. you should see some of that blue rtv glue coming out around the valve cover when applying torque to the valve cover bolts. only secure them snug at first. let car set for 15mins. start car and look for leaks around the cover, do not over tighten those bolts but you may need to look for a leak, go to bolt closest to leak and turn it 1/4 at a time until leak stops. but if you do this step by step, you'll not have a leak issue. you may have pinched the gasket when you replaced it. hope this helps and thank you for choosing fixya.com
Dec 27, 2010 | Volkswagen Passat Cars & Trucks
2000 740il smoke and oil leak.is it timing chain cover or is it valve cover problems?
All BMW V8 motor have leak oil problem on bad gasket in valve cover. When remove plastic cover where is "BMW" in to camshaft &valve cover,its leak visible where is ignition coil on sparkplugs.
Nov 10, 2010 | 1998 BMW 7 Series
Cause of oil in sparkplug tube?
1.your valve cover's spark plug chamber seal is leaking. Which requires removing the valve covers and replacing the gaskets and seals. 2. Excessive oil spills on to the valve cover and ignition coils when adding oil.
**This excess oil on the plug boots can cause the coils to short and eventually fail.
Apr 20, 2010 | 2001 Lincoln LS
Head Gasket?? Valve cover Gasket???
most likely it is the valve cover gasket. it covers the valve train where there is alot of oil to lube the top of the motor. if the head gasket was leaking it may have more signs of running poorly. also having coolant leaks also. so i will have to say valve cover gasket. now usally you may have a oil burning smell with it depending on the area of the lek but not always.
the valve cover can easily be seen when the hood is open. it is right on the top and where it meets the clyinder head is where the gasket is and the leak can be seen.
if you have more question please ask.
Nov 12, 2009 | 1997 Geo Tracker 2 Door
Replace Valve cover on 2002 Nissan Sentra
Are you sure the Valve Cover and not just the Valve cover gasket??
Any ways go to Auto Zone and pick up the Valve cover gasket, RTV Silicone selant, Gasket Scraper, and a can of Brake parts cleaner spray.
Disconnect the battery cable from the negative battery terminal, Remove the items which are in your way: Pull the spark plug wires off the spark plugs and remove them from their brackets, remove the PCV hoses, and remove the throttle cable from its brackets and position it out of the way.
Loosen the fasteners in this order, I believe there are 11 bolts holding the Valve cover down. Remove one bolt and count to the next 5th bolt and remove it and count to the next 5th bolt and remove it, do this till all the bolts have been removed on a circular pattern. Carefully remove the valve cover from the engine head.
If your just going to replace the Valve cover gasket,  Remove the gasket from the valve cover. Thoroughly clean the mating surfaces of the valve cover and the engine head. Use a gasket scraper to remove all traces of old gasket, and then use the Brake parts cleaner to clean any remaining oil from the surfaces.
If you bought a new Valve cover, Apply RTV silicone sealant to the gasket and engine head around the cutout areas of the valve cover. Note you still have to clean the heads on the engine. Lay the new gasket in the groove in the valve cover.  Reinstall the valve cover with its new gasket on the engine head. Tighten the bolts in the same order you removed it in. Do Not Over Tighten the Bolts that hold the Valve Cover down, you'll crush the new gasket and will get an oil leak.
Note: If the valve cover does not come off the engine head easily, use a block of wood and a hammer to bump it in an attempt to jar it loose. If absolutely necessary, you may slip a flexible putty knife between the head and the cover to break the seal.
If you purchased a valve cover gasket kit, don't forget to replace the small rectangular gasket and the spark plug seals as well while you have the valve cover off the car. You may buy some Brake cleaner to clean off all the oil which has leaked all over the engine.
DO NOT attempt to pry the cover off the head using a screwdriver or chisel. Be very careful not to introduce foreign matter into the engine. If you get anything (dirt, metal shavings, bits of old gasket) into the engine.
DO NOT over-tighten the valve cover fasteners. On the engine, the fasteners need only 17 to 34 in-lbs of torque.
Your A/C system has a leak in it. all system has a slow leak and common, You can get a re-charge kit at Auto Zone to save some money, but if your A/C needs charging again in 2 weeks or less then there is a larger leak due to a bad seal and is cheaper to have a A/C shop locate the leak and replace the seal that has gone bad.
Good luck and hope this help. keep me posted, be glad to help.
May 29, 2009 | 2002 Nissan Sentra
Leaks oil looks like from valve cover
You have to remove the spark plugs cables and remove the four nuts that you see when the cables are removed.
When the four nuts are removed, simply raise the valuve cover. When replacing the gasket, make sure you get the gromets as well. Those sometimes get worn or crack since they are more exposed than the value cover gasket. Make sure that you clean the cover from oil and replace the gasket with no use of silicon.
Good Luck.
Jul 20, 2008 | 1999 Toyota Camry
2003 Isuzu Ascender - All Ascender models - Sportz SUV & Minivan Tents Logo
59 people viewed this question
Top Napier Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Napier Vehicle Part and Accessory Expert? Answer questions, earn points and help others
