Question about Maytag Neptune MCE8000AY Electric Dryer
The upper cabinet of the Maytag MCE8000AY Electric Dryer heats up, but the air isn't blowing out the vent. I can't find a filter to check or where the top cabinets vents to the outside vent. Anyone help??
    Sergeant:
    Champion:
  • 214 Answers
You must remove the screws from the door and the hinges there are 8 screws 2on the top hinge 2 on the bottom and the other side also.After that the door lefts up and toward you.Once the door is off the panel around the door should come off then there is a shroud infront off drum remove 4 5/16 screws off then then cheak for lint obstruction or piece of clothing around the blower housing.Hope i helped:)
Posted on May 18, 2009
Blowing cold air
This model dryer has two heating elements, one for the top and one for the bottom, I suspect that the bottom element is burned out. If you want to attempt it yourself then I can send you a service manual that will walk you step by step through the whole dryer.
Dec 11, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Our dryer heats for awhile, then shuts off. If we let it cool down,it will turn back on for awhile., then get hot, then turn off again
Check to make sure vent/air flow is not restricted.
Try to start dryer soon after it stops. If it hums and does not start, motor is cutting out.
If you touch the motor you will find it to be 'very hot' Touch only for 3-4 seconds.
Oct 18, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Lower dryer has no heat for drying. Upper dryer continues to work with heat. Can it be fixed?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 03, 2010 | Maytag Neptune MCE8000AY Electric Dryer
Lower dryer tumbler will not heat up, upper dryer part works fine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 05, 2010 | Maytag Neptune MCE8000AY Electric Dryer
The dyer blows cold air - no heat
PROBLEM WITH THE HEATING ELEMENTS, THEY ARE PROBALLY BURNED OUT, CHECK THEM YOU WILL HAVE TO PULL THEM OUT AND CHECK WITH A METERN TO SEE IF THEIR OPEN, BUT I WOULD SAY THATS IS THE PROBLEM
Apr 26, 2010 | Maytag Neptune MCE8000AY Electric Dryer
No heat coming from dryer
Double check the circuit breaker for the dryer (Electric Neptune). Turn it off, then turn it back on. Its possible that the breaker may have tripped for some reason, but wasn't able to trip all the way.
Does the interior of the dryer get warm at all? You could have a 1 of multiple heating elements that has shorted. If no heat at all, the likely a heating element has opened up. Unplug dryer from wall (turn off circuit breaker first!). Use a ohm meter to measure and check continuity of the heating elements.
There may also be a sail switch in the air path of the dryer. The purpose of the sail switch is to keep the elements turned off until there is enough air blowing through the dryer. This helps prevent fires, as well as shrunken denim.
Jan 04, 2010 | Maytag Neptune MCE8000AY Electric Dryer
I have a maytag dryer model number is mce8000ay
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Dec 23, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Magtag neptune mce8000ayq
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
fggfs
Sep 22, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
89 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
