Question about 60 series Diesel Power Service Manuals On-Highway
Parts diagram bd sander 7420 needed
See what washers /screws. Required
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Detroit Red Master
  • 1,632 Answers
Diesel rated
Posted on Dec 28, 2013
Where can i find a manual for my black & Decker deluxe dual action sander no. 7420
Many Black&Decker power tool manuals are available from their http://servicenet.blackanddecker.com/Home support site. If you search for the 7420 model number, the correct sander is the first one in the resulting list. The direct link to the 7420 sander page is http://servicenet.blackanddecker.com/Products/Detail/7420# . The link to the manual is on the right hand side of the page near the top. That is scripted link; the actual URL for the manual appears to be http://documents.dewalt.com/documents/English/Instruction%20Manual/592750-01,7420.pdf . However, that may change in the future.
I hope this helps.
Jun 08, 2015 | Sander Tools & Hardware - Others
The electric cable has got caught in the sander. How do I unassemble to remove the cable?
Hi Mark,
Hear is an exploded parts diagram for the sander:
http://www.powertoolspares.com/tool/makita/spares-and-accessories-for-9404/9404/spares/
Remove the three screws on the handle cover part 23 to expose the cable connection to the trigger switch.
Apr 28, 2011 | Makita 9404 4'' x 24'' Belt Sander
My Bosch 3107dvs random orbital sander stopped working. The screw that holds the sanding disk stripped the part that it screws into. I can't tell from the exploded parts diagram, which part I need to...
Drawing REF: http://www.ereplacementparts.com/bosch-3107dvs-0603310639-random-orbit-sander-parts-c-128_1044_1230.html
To remove the Dust Fan/Coupling Assy. I did the following: I disassembled the plastic housing, removed the Backing Pad Pos. 733 and Dampening Ring Pos. 51.
It seems the Star Washer Pos. 29 holds Bearing Pos. 30. onto the armature shaft and the Coupling Pos. 27 seems to be stuck in Bearing Pos.29. I used a 30mm long M7 hex-head bolt and 11mm ratchet turning clockwise (std RH thread) to pull the Coupling and Star Washer off. Luckily, there was enough thread left in the coupling to do this gear-pulling action with the longer bolt.
To remove the rest of the Fan Assembly I removed the 2 screws Pos. 43 holding the Brush Holder Assembly, Noted the position and removed the Spring Clip Pos. 32, then removed the Armature w/ Fan and Dust Fan/Coupling Assemblies. Firmly gripping the armature I was able to remove the Dust Fan from the armature by turning it clockwise (LH Thread).
Now that I have removed the parts and believe I will be able to reassemble them, I have ordered a new Dust Fan/Coupling Assembly.
I hope this helps someone else having a similar problem.
May 04, 2009 | Bosch 3107DVS Electric Sanders & Polishers
How to remove round sander for iron shaped one
You need to remove the allen head cap screw in the center of the base, then remove the washer, and pull the base straight down off the sander. If you can't get it to pull off, try gently rocking it a little as you exert pressure to pull it off.
Random orbit sanding base
With this sanding base, you can use the tool as a random orbit sander.
Fitting and removing the sanding base (fig. B)
- Place the sanding base (3) onto the spindle (10).
- Place the washer (7) onto the spindle.
- Insert the Allen screw (8) into the screw hole in the spindle.
- Tighten the Allen screw using the Allen key (9) supplied.
- To remove the sanding base, remove the Allen screw (8) and washer (7).
Fitting sanding sheets (fig. C)
- Hold the tool with the sanding base (3) facing upwards.
- Place the sanding sheet (11) onto the sanding base (3). The holes in the sheet do not need
to line up with the holes in the base.
Large detail sanding base
With this sanding base, you can use the tool as a detail sander or an orbital sander.
Fitting and removing the sanding base (fig. D & E)
For detail sanding, the pointed end should face forward as in fig. D. For sanding large areas,
the pointed end should face to the back as in fig. E.
- Place the sanding base (12) onto the spindle (10). Make sure that the legs of the base
locate into the tool.
You can also view the factory manual here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/479727-00,MS1000%20SANDER.pdf
Be patient, and good luck! Let me know if this doesn't solve your problem and you still need help!
Mar 08, 2009 | Black & Decker Black And Decker Cyclone 4...
60 series Diesel Power Service Manuals On-Highway Logo
83 people viewed this question
Top Detroit Red Vehicle Parts & Accessories Experts
Lawrence Oravetz
Gloria Vernon
Gloria Vernon
Level 1 Expert
Lucy Angela
Lucy Angela
Are you a Detroit Red Vehicle Part and Accessory Expert? Answer questions, earn points and help others
