Question about Alcatel Cell Phones
How do I space between words on my Alcatel phone?
I cannot space between words when texting. How do I do this?
I can not recieve text messages on my alcatel one touch
Troubleshoot issues related to text messaging on your ...
support.sprint.com/...text-messaging...ALCATEL-One...
Sprint CorporationUnable to send or receive text messages; Displaying error codes or network messages when you try to send a text message ... A soft reset reconnects your Alcatel OneTouch Retro to the Sprint network. ... been able to text, contact Sprint Customer Care for further troubleshooting. ... Under My Products, click on Edit Products.
Troubleshooting Basic Phone Functions ' Brightspot Support
Dec 20, 2015 | Alcatel One Touch Fierce
How do I delete miss spelled words when texting on alcatel onetouch flip phone
you have to catch it as you are writing it and hit the clear button
Feb 15, 2015 | Alcatel Cell Phones
How to text
Space bar is the '0' button. To get to normal alphabet, you have to hit the asterisk button on bottom left 3x quickly.
Apr 03, 2014 | Tracfone Wireless Alcatel A392G
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
How do you add a space on the slide phone when texting..i just started to text but not sure where the space button is
On the keypad, press the # sign located on the lower right corner of the phone. This has a LOCK icon and the word SPACE in it. That is the space button when in text mode for your phone.
Oct 31, 2009 | LG CHOCOLATE VX8500 Cellular Phone
How to space in between your texting words
Should be one of your bottom keys like the * or #. The key should say space on it in italic I believe. Please respond and vote if helpful. Thank you.
Oct 15, 2009 | Samsung Smooth SCH-u350 Cell Phone
How do you space between words on an older razor phone?
To put a space in between words in a text msg or text body, you hold down the *STAR button. The space key looks like this ( __ ) and it is on the *star key on the old Razer
Sep 02, 2009 | Motorola Mobility RAZR V3
Cell Phones Logo
37 people viewed this question
Top Alcatel Cell Phones Experts
Gene
D. E. Hev
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
