Question about Black & Decker Power To Go Cordless AC/USB Power Supply (CPI20XB) 20-Watt Power Supply
I want to resister it!!!!!! - Black & Decker Power To Go Cordless AC/USB Power Supply (CPI20XB) 20-Watt Power Supply
    Master:
  • 678 Answers
You want to do what???
Posted on Jan 01, 2014
2004 vy commodore. What is temp sender unit resistance?
it is a variable resistance that changes with the coolant temperature
when it is cold ,that is the highest resistance and when it boiling ,that is the lowest resistance
It is the variable resistance that gives the readings on the gauge.
Jun 18, 2015 | Cars & Trucks
How to check for spark, harley springer
Ignition Coil Primary Circuit Test
Remove the coil. THEN set your ohmmeter scale to RX1 and place ohmmeter leads on the primary coil windings A (front of coil) to B (middle of coil), B to C (front of coil) and check for primary coil winding resistance which normal resistance range is 0.5-0.7 ohms. If primary resistance is not within this range check out test results below.
Ignition Coil Secondary Circuit Test
With the ignition coil removed from the motorcycle and the ohmmeter set to the RX1K scale place the ohmmeter leads on the secondary coil windings B (middle terminal) to
R (rear secondary terminal/socket), B to F (front secondary terminal/socket) and check for secondary coil winding resistance which normal resistance range will be 5.5-7.5K ohms. If secondary resistance is not within this range check out test results below.
Test Results
A low resistance value indicates a short in the coil winding which requires coil replacement.
A high resistance value might indicate that there is some corrosion/oxidation of the coil terminals requiring the coil terminals to be cleaned and the resistance test then repeated and if after the test is repeated the resistance is still high after the terminals were cleaned the coil must be replaced.
If there is an infinite ohms or no continuity) resistance value the coil is open and must be replaced.
May 03, 2014 | 2003 Harley Davidson FLSTS Heritage...
Resistance on elliptical acting weird
1) tight the bolts tension for magnet and clean very well. and proof..if the fail
2) go to test the magnet, use again the magnet from your refrigerator magnet, for attraction and repulsion. If do not pass the TEST replace the magnet in any Hardware such home depot, etc.
God bless you
Aug 27, 2012 | Proform Nordic Track Elliptical Resistance...
What are the different resistances on exercise bikes?
There are three main types of resistances, the fan resistance used to provide resistance with air they push as you pedal. The second type is the belt resistance which uses a belt that runs through a brake providing resistance for the exercise bikes. The third type is the magnetic exercise bike which provides resistance which can easily be adjusted while riding the bike.
Aug 09, 2012 | Exercise & Fitness
Give me 5 problem about resistance
1. Civilian European citizens that sabotaged the occupying German armies (by changing street-signs) and who assisted Allied soldiers to smuggle them to Great Britain were "The Resistance".
2. Ohm's law: To make a current flow through a resistance there must be a voltage across that resistance. Ohm's Law shows the relationship between the voltage (V), current (I) and resistance (R), namely V = I times R.
3. Trying to walk into a cinema while the viewers of the previous showing of the feature are trying to vacate the facility is an example of resistance.
4. Any two-year-old child that says "no" to everything is an example of resistance.
5. A lady who overindulged in Christmas feasting, and now is trying to put on her "skinny-jeans" is the best example of resistance.
Jan 10, 2011 | Computers & Internet
What is the resistance for heating elements on rheem ruud E10-18-G need to be tasted at
You can calculate the resistance if you know the volts and watts or amps.
Resistance = volts / amps
Resistance = volts squared / watts
Resistance = watts/ amps squared
Mar 08, 2010 | Ruud Heating & Cooling
Diagnostic Code P2074 on 2007 PT cruiser-can't find on OBD list.
P2074-manifold Pressure/throttle Position Correlation
CORRELATION - HIGH FLOW/VACUUM LEAK
When Monitored: Engine Running, during all drive modes.
Set Condition: If vacuum drops below 1.5 Hg with engine RPM greater than 2000 RPM
at closed throttle.
POSSIBLE CAUSES
VACUUM LEAK
HIGH RESISTANCE IN MAP (K7) 5 VOLT SUPPLY CIRCUIT
RESISTANCE TO GROUND IN MAP (K7) 5 VOLT SUPPLY CIRCUIT
MAP SENSOR
HIGH RESISTANCE IN (K1) MAP SIGNAL CIRCUIT
RESISTANCE TO GROUND IN (K1) MAP SIGNAL CIRCUIT
HIGH RESISTANCE IN (K4) MAP GROUND CIRCUIT
PCM
TP SENSOR OPERATION
HIGH RESISTANCE IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT
RESISTANCE TO GROUND IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT
TP SENSOR
HIGH RESISTANCE IN (K22) TP SIGNAL CIRCUIT
RESISTANCE TO GROUND IN (K22) TP SENSOR SIGNAL CIRCUIT
HIGH RESISTANCE IN TP (K4) SENSOR GROUND CIRCUIT
Mar 27, 2009 | 2007 Chrysler PT Cruiser Touring Hatchback
Hitachi 43fdx11b
Hello Hitachi,
By me, brown,black,gold gold is one ohm, namely 1 for brown, black for zero and the rest for quality!
TOMMIX
Jul 15, 2017 | Televison & Video
Width problem
Sometimes you will need to reinforce the whole circuit with new soldering metal as well. Mass produced circuitry sometimes uses very little of the stuff or uses soldering metal of poor quality.
Apr 09, 2007 | LG Studioworks 563N 15" CRT Monitor
Black & Decker Power To Go Cordless AC/USB Power Supply (CPI20XB) 20-Watt Power Supply Logo
22 people viewed this question
Top Black & Decker Computers & Internet Experts
Outback Jack
Outback Jack
Are you a Black & Decker Computer and Internet Expert? Answer questions, earn points and help others
