Question about Sansui Televison & Video
I just got the tv yesterday (Christmas) and i had started up the tv then my xbox and the screen on the tv wdnt black and now my tv isnt showing any picture for my cable or game system. Tv is a Sansui Sled2490A
  • 6 more comments
  • Gabriel Scheidt
    Gabriel Scheidt Dec 27, 2013
    Also i can here audio and change channels and input settings but no visiual .
  • jason Dec 27, 2013
    If you shine a light at the screen while it is playing something , Can you then see a shadow image in the screen ?
  • Gabriel Scheidt
    No it is just a luminated black screen
    and you can't see a tv menu ?
    also have you tried unplugging it for a little bit ?
  • Gabriel Scheidt
    I have tried unplugging it and waited 2 hours for that. Also the screen is just completely black. I am going tommorow for a replacement any way.
    If unplugging don't help voltage testing will need to be done to determine
  • Gabriel Scheidt
    Ok thanks for the help.
likha
  • 790 Answers
SOURCE: Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Posted on Oct 02, 2007
  • 668 Answers
SOURCE: TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Posted on Jun 18, 2009
  • 12 Answers
SOURCE: 42 inch ilo tv black picture sound only
If the fuse burned out the the tv would not turn on at all. When the tv is on is the back light still on? If its not its probably the back light that needs changing. If its on then its one of the circuit boards.
Posted on Jun 21, 2009
  • 7 Answers
SOURCE: tv turns on for a second, then image and sound disappear
Sounds like a power board problem.Does the tv return to stand by?Red led
Posted on Jul 11, 2009
SOURCE: I have a 46 inch sanyo lcd 1080p that is only 2
I'm having the same problem with the same TV. I called around to repair shops and I guess it's fixable. Haven't taken it in yet but I was told it most likely is a bad module. But this seems to be a really common problem with this television
Posted on Feb 26, 2010
We bought a new fan for our xbox 360 on sunday and yesterday while playing Modern Warfare, the screen went completely black. We tried different tv's, but the screen stays black. We can hear noise like...
possibly unrelated. try testing the connections to the tv and the x-box. if thats solid then try removing the fan unit to see if it is the culprit.
Dec 02, 2009 | Microsoft Xbox 360 Console
The picture doesnt show but I hear the sound.
Don't worry the HD feed from the xbox 360 has a gain limiter
So the chances are more likely that either your Friends xbox has
the HD setting off or the TV has defaulted to standard video in.
If you get a black screen or a mesage that says no single .
But if your getting strange color on your set with the HD on
then we need to investigate this " Microsoft is liable!" for
damages caused by their console. Ill look in to this and
follow up. The xbox has broken connection under the poorly
soldered G.P.U. and will need to be re-flowed to the main
board to corrects this problem but that's a secondary priority
right now.
I'll check this out for you and follow up.
Rob
Oct 03, 2009 | Microsoft Xbox 360 Console
I hear sound on my TV but the screen isnt showing anything i trued to different cables and it still doesnt work...i even tried hooking it up to the TV but nothing
Try overheating the xbox-->Put some towels around it and leave it on for 30 seconds.turn it off and turn it back on again.It works for lots of people :)
Jul 25, 2009 | Microsoft Xbox 360 Elite Console
My new xbox just got it for christmas is freezing
Right, lay your Xbox360 down dont keep it upright, try installing COD4 to your hard drive then once installed go into you game library and click on cod4 and click play from hard drive ( and if you dont know how to install games to the hard drive make sure your xbox isnt on automatic start when a disc is inserted and put the disc in and when it says play cod4 press Y and then click install to hard drive) hope this helped....
Feb 07, 2009 | Microsoft Xbox 360 Console
NOO black xbox 360 screen and sound do not work and only day 4
Check to make sure all your cable is plugged in all the way, and if you are using the HD cable, that it is switched appropriately (regular TV to "TV" and HDTV to "HDTV"). If all that is well, call Microsoft, your system is under warranty and they will RMA it.
Dec 30, 2008 | Microsoft Xbox 360 Console
Whats Wrong With My Xbox 360?
it has to be on the wrong plug in ins or on HDTV. if you need more help my email is: dracohackess@yahoo.com i got one on christmas to i sorta like SOFTLY boped it and it booted up. sorry bout it
Dec 27, 2008 | Microsoft Xbox 360 Elite Console
Screen Problem! Need Serious Help!!
MS recommended and a repair is wise if this is a constant issue. Some people tackle this problem by opening up their Xbox 360 and finding the problem themselves. Those who do report a small magnet that holds the disc in place, loose or not connected. They simply glue this back on; however, opening the Xbox 360 renders the warranty invalid, therefore future repairs may be denied and a fee may be placed.
Dec 20, 2008 | Microsoft Xbox 360 Console
Xbox original not showing color screen
Put the xbox on another tv. If it is in color then, the AV inputs may be bad. If that is the case, you may need to buy an AV-UHF/VHF converter, or plug them into a VCR.
Aug 17, 2008 | Microsoft Xbox Console
My xbox 360 is showing green
no red lights, no previous error msgs, and video output on the box has just died. playing halo yesterday and mid-game the colours went askew (like a green overlay) with horizontal banding, backing out to the dash solved nothing so after a reboot there was simply no video. troubleshooted the tv and cables and its definately the box.
http://forums.xbox-scene.com/index.php?showtopic=625804
Nov 11, 2007 | Microsoft Xbox 360 Console
Televison & Video Logo
74 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
