Question about Danby DDW1899WP Portable Dishwasher
Water not drains,Danby Portable Dishwasher
Last day, my portable Danby dishwasher stop draining water. I remember that, when I start a program it was first draining the water inside. Now it makes the sound "click" ( I think it comes from the relay or other electronic component in the control panel) But nothing happens. After a few minutes it start washing cycle. And when it comes to draining again I can hear the same one "click" from the control panel but no drain. It waits like 5 min and gives error signal on 4th led,to the right (it's blinking fast) and makes beep signal. I checked the hose because it causes the similar problem before but now it seems ok. I can pull the water out by myself(sucking with my mouth) I checked the filters and they seems ok. Any help please... Thank you
  • 5 more comments
  • Mehmet
    Mehmet Dec 28, 2013
    I checked the drain way from inside of the machine to the all the way output. I blow out all the way through. There seems nothing blocks the pipe. I think some sensor may cause it but I am not sure.
  • Luke
    Luke Apr 10, 2014
    I have the exact problem. The machine fills up, washes but doesn't drain. Did you ever find a solution??
  • Mehmet
    Mehmet Apr 12, 2014
    Yeah I did it. It's beacuse of the drain pump. I found a broken glass part there but I am not sure how did it get there?
  • Mehmet
    Mehmet Apr 12, 2014
    I made a youtube video for it. I
  • Mehmet
    Mehmet Apr 12, 2014
    I will upload it soon. You can check it out.
  • Mehmet
    Mehmet Apr 12, 2014
    https://www.youtube.com/watch?v=zycvHxzC...
  • Luke
    Luke Apr 13, 2014
    You are the best Mehmet! Thanks so much for posting! I found some glass and a piece of plastic in my pump. Easy fix once you know what to do. Cheers!
The water from my Danby DDW1899WP Portable Dishwasher was not draining either. Check out the original post's comment section for an update. Mehmet fixed his problem and posted a video. I followed the instructions and also found glass and some plastic when I removed the drain pump. Easy fix once you know what to do! Thanks Mehmet!
Posted on Apr 13, 2014
  • 6 Answers
I had the same problem and found the drain blocked at the outlet as it goes into the sink.
Posted on Dec 27, 2013
  • Mehmet
    Mehmet Dec 28, 2013
    I checked the way from inside of the machine to the output. I blow all the way through. Nothing blocks the way.
Falling Down
  • 67 Answers
SOURCE: Danby DDW1802W Cycle Problems
The fill valve is probably stuck in the full position. It's at the bottom of the tub and looks like a small tube with a cap on it. You should be able to move the cap up and down easily.
Posted on Nov 30, 2007
SOURCE: Danby DDW396W won't drain
If you remove the cover, you will discover that there are two motors inside. The larger one on the right runs to fill the machine and spray the water during washing. The smaller one on the left drains it. Oiling this motor, or manually actuating it by spinning the wheel between cycles may solve your problem.
Posted on Jan 26, 2008
SOURCE: my danby countertop dishwasher won't drain
the problem has not been resolved. does not drain.
Posted on Jan 18, 2009
SOURCE: Danby Dishwasher stuck in drain cycle after wrong soap use
There might be water in the overflow sensor. I unloaded the dishwasher and lifted the front so the dishwasher rested on its back. There's a narrow gray tube that runs down from the bottom right of the door. The tube runs into a white piece of plastic with some wires coming out of it. There is a rubber plug that covers a nipple on the plastic. Pull the rubber plug off. Mine was quite tight. Tip the dishwasher back onto its casters to drain the water from the overflow. Check to see if the dishwasher functions normally, then put the rubber plug back on.
Posted on Jan 10, 2010
  • 160 Answers
SOURCE: I have a problem where
It sounds like your motor is stuck in the reverse position. It could also be in your timer. I would suggest calling a qualified technician for the one. Just because the parts are pricey and depending on how much a new dishwasher cost. Atleast get a diagnosis so you can know if its worth fixing or buying a new one. If you have anymore questions please feel free to comment me back.
Posted on Jun 05, 2011
Danby portable dishwasher ddw1899wp starts taking in water and then stops working with pre-rinse light blinking. Please help me on this issue. Any answer would be much appreciated.
If the water level sensor does not electrically shut off when the level needed is reached, the pre-rinse cycle will error out thinking that the level has not been reached. That sensor is a float device and probably needs to be replaced...
Dec 28, 2012 | Danby DDW1899WP Portable Dishwasher
Drain pump wont stop
Hello there and thank you for choosing fixya
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged. or may
be bad and needs to be replaced.
Also if the cycle timer is going out this may cause the drain to continue so i would havethat checked out as well ok?
Hope this helps
Best regards Mike
Aug 04, 2011 | Danby DDW497W Portable Dishwasher
My portable dishwasher wont drain all the way. it has water that comes out but not all
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Aug 23, 2010 | GE 24-7/8" Convertible Portable Dishwasher...
Dec 10, 2009 | Danby DDW1805W Designer Series...
Kenmore portable dishwasher not working
is the buzz sound when you ask it to drain or ask it to fill with water? or is the buzz sound when it is trying to wash? IF it is when you ask it to drain either you have something stuck in your air gap causeing no drain or there is something in your pump I would check the easy stuff first by checking the air gap this is if it is buzzing when you ask it to drain. let me know what is the senario.
May 29, 2009 | Kenmore 17252 Free-standing Dishwasher
Danby DDW399W dishwasher - drainage and spin arm problems
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
heatman101
Nov 19, 2008 | Danby 22 in. DDW396 Free-standing...
My portable danby is stuck on the Drain cycle
take bottom front panel off to expose bottom tray and you will probably find it full of water. disconnect from electricity and mop water out and machine should work. if fault reoccurs then you have a leak
Sep 25, 2008 | Danby DDW1805W Designer Series...
Danby DDW1899WP Portable Dishwasher Logo
384 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
