Question about Crosley Cr704 Turntable Am/fm Radio Record Player CD Mp3 New Spare Np
Shaky sounding records
Just received my Cr704 for Christmas. Records sound shaky when I play them. Is there anything I can do to fix this?
  • 1 more comment
  • freddyfox Dec 27, 2013
    Hi Grant Aaron, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Do all the records you play have the same unwanted "shaky" sound. could you elaborate on "shaky" please.
  • Grant Aaron
    Grant Aaron Dec 28, 2013
    The music sounds "ringy" or "vibrate-y", as if every vocalist is a sheep. It'
  • Grant Aaron
    s almost like the record is dragging, or not quite turning fast enough.
    Sergeant:
  • 236 Answers
Some things to check:-
Is anything preventing the turntable from rotating smoothly, this would cause a judder.
Perhaps the records are sliding on the turntable, a rubber mat will cure this.
Ensure the record player is on a level surface.
Posted on Dec 27, 2013
Testimonial: "I placed a rubber mat from an old turntable under the record and it's having the same problem. I have placed the machine on several different surfaces and experienced the same problem."
  • 1 more comment
  • freddyfox Dec 28, 2013
    From what you describe it does sound like a speed issue with the turntable.
    I meant to add, have you checked that the stylus is seated correctly and there is no dirt on the tip. I assume that other functions like the CD etc sound OK?
    Can you try switching the turntable speed controll back and forth between 45 and 33 1/3 a few times, it may just seat the belt drive a little better, worth a try.
My Studio Standard by Fisher stereo system's audio keeps breaking up.
Could be a defective volume control. After 20 years, it would not be surprising
Apr 10, 2013 | Fisher Studio Standard Am/fm Synthesizer...
Record skipping despite new needle
It could be something to do with the turnatable's platter. Is the matt that the record sits on faulty. Does the platter wobble up and down with no record on it? If you can see this happening you might need to check the platter out. If it's a belt driven the belt can come out of position causing such problems. Also objects can get stuck inside the platter. Especially if you have small children in the house!!!
Feb 28, 2013 | Crosley Cr704 Audio Shelf System
Crosley cr704
I suggest you return it to the place of purchase, this is a manufacture fault.
May 26, 2012 | Crosley CR704 Shelf System
How can i fix my jta-460 from playing records slow
Check the RPM switch on the turntable is on the correct speed for the record you want to play. Otherwise it could be a belt problem internally.
Feb 13, 2012 | Jensen JTA460 Turntable
Toshiba VCR. It records OK but playback is black, white shaky
What do you mean by "records OK"? It sounds to me like you are not getting a signal to record. I had this problem before, as well. There are two things I recommend you try. The first is that (if you are trying to record over-the-air tv, you will need a digital television converter box connected directly to the vcr. If you already have one and are sure that it is connected correctly, you may also try an RF modulator. When I got my new vcr, it wouldn't work at first. I eventually found out that I would need an RF modulator in order for it to work on my tv. I hope these suggestions help. Good luck! Sincerely, Der Strom
Apr 26, 2010 | Aiwa HV-MX100 VHS VCR
I have a Cobra camcorder.It came with 2 memory cards, one that records 16 minutes, and the other that records about an hour and a half. I put the chip in that had more space and went to use it at my...
first see if the card has any device for locking on it ...than if you can put it on the computer ...just do it and format the card ...(go to my computer ...find it ..right click on it ...and format ...) try to see if the card is ok in the camera after that ...
if the camera have formatting memory unit in the menu ..u can use even from there ...
Dec 24, 2009 | Cobra Digital DVC960 Digital Camera
Crosley CR704 record player wont work, HELP!!!
Make sure the switch on the back for line in, is off! I had mine on and it would not play. Switched it off and all works fine!
Aug 01, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
Logitech Quickcam Chat - No audio
Try testing it, last time I checked skype has a test section, its hard to find, but its there. You just talk into the mic and skype records it. Then play back.
It is possible the mic isn't working.
Before you consider taking it back, make sure you follow the instructions to the letter.
Dec 25, 2007 | Logitech Quickcam Chat Webcam
Crosley Cr704 Turntable Am/fm Radio Record Player CD Mp3 New Spare Np Logo
348 people viewed this question
Top Crosley Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
Andrew Taylor
Andrew Taylor
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
