Question about Philips LaserMFD 6020 (LFF6020)
The printer message on the screen is saying that I should Put A 4 in manual tray
Paper is in the printer but message on LCD screen Put A 4 in manual tray
    Problem Solver:
  • 33 Answers
Check printer settings and see from witch tray the printer is set to print. the settings mus be the same on the printer and on the computer.
Posted on Dec 27, 2013
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Hi, Bizhub c450: i have a problem on scanning over the rear tray if i put paper inside message will appears close section properly but there is no other error code appearing on the screen.
When you say the rear tray what do you mean, ON the document feeder tray or raising the document feeder up placing the document on the big glass. Never heard of a rear tray?????
Feb 04, 2015 | Konica Minolta bizhub C450P Laser Printer
Paper jams and burn
Lets try the following
  1. If there is no paper, load a new stack of paper into the paper tray.
  2. If there is paper in the paper tray, make sure it is straight. If the paper is curled, you should straighten it. Sometimes it is helpful to remove the paper, turn the stack over and put it back into the paper tray.
  3. Reduce the amount of paper in the paper tray, and then try again.
  4. Check that the MP tray mode is not chosen in the printer driver.
  5. If the LCD shows Paper Jam message and you still have a problem
Or try
  1. Pull the paper tray completely out of the machine.
  2. Use both hands to slowly pull out the jammed paper.
  3. Press the cover release lever to open the front cover
  4. Slowly take out the drum unit and toner cartridge assembly. The jammed paper may be pulled out with the toner cartridge and drum unit assembly, or this may release the paper so you can pull it out of the paper tray opening.
  5. Put the drum unit and toner cartridge assembly back in the machine.
  6. Close the front cover.
  7. Put the paper tray firmly back in the
Or leave a Voice mail we'll check what we can do
Jul 26, 2014 | Canon Genuine Oce Imagistics Fx3000...
Printer stuck in a startup loop
1. Power on the printer
2. Remove the the ink cartridges from the printer
3. Unplug the power cable from the back of the printer (Do not power off the printer prior to unplugging the power cable).
4. Press and Hold the "6" and "#" on the number pad of the printer. While holding those two keys replug the power cable to the printer.
5. The printer should power on and give the message on the LCD "Install print cartridges". Install the cartridge and close the lid.
6. The printer should give the message on the LCD "Insert Black cartridge". Install the Black cartridge and close the lid.
7. The printer should give the message on the LCD "Used Black cartridge". Load a couple of plain paper in the paper tray and press the OK button. Keep pressing the OK button until the LCD says "Aligning print cartridges"
8. The printer will auto-align the cartridges and the printer should be in a ready state.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Nov 20, 2012 | HP Office Equipment & Supplies
How do i print 6 3/4 return size envelopes on a sharp 2600n
You have to select the Manual Feed Tray by touching the picture of the copy machine on the LCD screen. That will then show you the paper trays. Touch the paper type soft key for the Bypass/Manual Feed Tray and then select envelope. then press ok a couple of times till you are back to the main screen. Put your envelopes face down on the Bypass/Manual Feed Tray. If you are printing from a computer do the same thing after you go to printing preference/properties.
Oct 20, 2011 | Sharp MX-2300N Color Copier
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
I HAVE LASERJET 4 PLUS. WHEN I GIVE JOB FOR PRINTING THE PRINTER DISPLAYS A MESSAGE AS PC LOAD LEGAL. PLS HELP ME IN SOLVING THE PROBLEM
The document you're trying to print is formatted for legal size paper, and the tray contains only letter size. if it's a legal size, put legal paper into the MP tray, or override the setting and manually select "letter size" in the printer dialog box.
Apr 04, 2009 | HP LaserJet 4 plus Printer
My printer c5280 keeps saying please reinsert or lower photo tray
If it is asking for photo paper you should be able to hit ok on the screen and then it should go to the default screen and be ready to print.
Jan 17, 2009 | HP Photosmart C5280 Printer
Brother printer mfc-7420 will not print
Manual feed is a by-pass tray (not the paper tray,)
in this particular model it looks like one of hte slots in the front. put a paper in and see if it grabs it.
you should be able to cancel out the job by pushing stop/cancel?
1-check the tray to make sure the paper size is correct
2-make sure it is set for tray not bypass
Jul 30, 2008 | Office Equipment & Supplies
Xerox Phaser 2135
Try to isolate the problem. You said that the printer is Displays Tray 4 I/F Error Power Off/On. Put paper only on the Manual Tray (Tray 1), just to force the printer to print from that Tray. If the paper pass all the way through the machine, then you know that there is no paper inside the top portion of the printer. Now repeat the same thing with Tray #2,#3, and any other Tray but not #4. If the printer works fine with all the other Trays, probably Tray 4 is the problem or the whole drawer. Check switching another Tray with Tray 4.
Sep 10, 2007 | Office Equipment & Supplies
Philips LaserMFD 6020 (LFF6020) Logo
32 people viewed this question
Top Philips Office Equipment & Supplies Experts
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
