Question about Zephyr Typhoon AK2100 Kitchen Hood
AK2100AS only top speed works. All other speeds do not work. Any suggestions? Any parts need to be replaced? Where to find the part
All other functions are fine
2 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: Zephyr typhoon AK2100 Kitchen Range Hood
its the relay inside that controls which speeds the hood works at this connects to the switch speed control
Posted on Jun 01, 2008
All speeds work but all too fast
the mixing speed was attained by the use of a potentiometer ( variable resistor ) that would have controlled the power into the board or from the board to the motor
it would be under the speed setting knob
maybe the resistor in use is not the right one and is not reducing the voltage sufficiently to do the job
Nov 08, 2015 | KitchenAid K45SS Classic Stand Mixer
SPEEDOMETER QUIT
You may need another speedometer. The speed sensor sends a signal to both the speedo and the odometer. So if the sensor fails, both meters would stop working.
The speedo gets power from the same circuit as the warning lights.
Jun 27, 2013 | 1993 Toyota Pickup
Motor noise
It has been my experience with knocking kitchenaid is one of three reasons all related to the speed control of the mixer1 speed control board adjust speed screws2 speed Phase control board, needs replacing3 The motor governor behind the speed control board needs replacing
Speed board = $9.00Phase Board = $20.00Governor = $10.00Your time + one week for ordered parts asnd one hour to remove and replace.
all work is performed at the rear of the mixer and you need only a phillips #2 screwdriver, a pair of needle nose pliers, an 11/32 open end wrench (you will need this to adjust your speed control board after new install) and that's it. easy work all remove and replace. Oh! make sure that you pit some thermal paste behind the phase control board to avoid burn out.
But!!! before you buy parts and do all that, try adjusting the speed contol board first. Go here for a parts list for your model.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KV25G0X&siteCd=KAD&userType=Servicer
then go here for instructions on tuning the mixer speed.
http://www.youtube.com/watch?v=pUo_ZU5xh3o
if after you tune it you still get the knocking then use the parts list to order parts. two good parts sources are goodmans.com and mendingshed,com, they are reliable and have the parts in stock.
Aug 26, 2012 | KitchenAid KV25G0X Stand Mixer
Washer will barley agitate or spin and make a
Try high speed only (cycles like cottons, heavy duty, etc. This happens when the low speed on the motor is not working. If high speed is working for you, the olny way to make the lower speeds work is to replace the motor.
Your part number is WH20X10019 and it's expensive...
Oct 20, 2009 | GE WBSR3140DW Top Load Washer
Washer does not work at regular speed, it works on other setting
Since the machine works in two of the three speeds the problem points to either the timer or the switch that sets the speed.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Go to the control panel category and see their diagram and list of switches and parts.
These aren't that difficult to replace but they aren't inexpensive.
Sep 14, 2009 | Kenmore 15864/15862 Top Load Washer
Yamaha ybr 125 top speed
Hi les
Not much to start with here unfortunatly mate. A free flow muffler will help top end speed, change the factory airbox to a K&N style pod air filter, other than that, hugging the tank at top speed :) If you do change these parts, you may also need to increase the main jet size to richen up the mixture for better tuning of the motor with the better flowing parts. This bike has a top speed of 100kmp and produces 10 hp, so you may only expect to get at best less than 1 extra neddy, and perhaps another 5 km/hr.... I suggest upgrading to a bigger machine of you feel the need for speed :)
If its 125's you are into, test drive a Honda CBR 125R 6 speed fuel injected 13.4 horsepower, and good for 120km/hr
regards robotek
Jul 10, 2009 | 2006 Yamaha Ybr 125
Speedomer not working
vehicle speed sensor located on the top of the rear axle.
Mar 23, 2009 | 1999 Dodge Dakota
Blower fan stops working and then starts again
My suggestion is replacing your wiring going to the resistor which is acdelco part number PT1231. I have had the problem of speeds 1,2, and 3 intermittently working while 4 always worked. Afterreplacing this part, all of my fan speeds work all of the time.
Mar 21, 2009 | 2004 Chevrolet Colorado
How do I replace a bad(??) ABS speed sensor?
I cleared this by replacing the sensor mounted on top of the rear differential housing.
Jun 06, 2008 | 1999 Mazda Pickup
Jun 01, 2008 | Zephyr Typhoon AK2100 Kitchen Hood
Zephyr Typhoon AK2100 Kitchen Hood Logo
82 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
Tom Chichester
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
