Question about 2004 Mustang Factory Wiring Diagrams
Belt diagram for 1997Eldorado V_8
Serpentine belt diagram
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Ford Master
  • 1,632 Answers
It is printed on the radiator cover plate
Posted on Dec 28, 2013
How to replace a serpentine belt on a 2010 Kia Forte?
kia forte drive belt - Kia Forte Forum : Sedan / Koup / Forte5 Forums
www.forteforums.com/.../kia-forte-2-0l.../40769-kia-forte-drive-belt.htm...
Dec 19, 2013 - 8 posts - ‎3 authors
im trying to replace the drive belt on a 2010 kia forte ex 2.0l and was wondering if someone could get me a diagram of the belt routing as well ... Squeal in serpentine belt area even after replacing ...
Nov 8, 2014
Serpentine drive belt -very frustrating-
Jun 17, 2014
Recommended mileage timing chain change SX
Mar 23, 2014
Serpentine belt removal on a 2.4L. Anyone?
Aug 11, 2013
More results from www.forteforums.com
images for serpentine belt diagram on a 2010 Kia Forte
Jul 03, 2014 | 2010 Kia Forte
How to change serpentine belt 1998 plymouth voyager 3.0 engine
draw a diagram of how the belt is on now
there is tension pulley which fits a 3/8 ratchet
release the tension on the belt and remove it
install the new belt using the diagram you drew
Nov 11, 2013 | Cars & Trucks
Serpentine belt diagram for a 2003 Chevy unpalatable 4.3
Pop the hood of the car and locate the serpentine belt routing diagram. The diagram on the 2003 Chevrolet Impala is on top of the fan shroud. The diagram will be a picture of all of the accessory pulleys and how the serpentine belt is routed among the pulleys. This diagram will give you the exact direction for routing the new belt onto the pulleys. If you cannot find a serpentine belt routing diagram, take a notepad and pen and draw out the exact routing diagram of the old belt across the pulleys.
  • 2 Locate the serpentine belt tensioner. It is located below the alternator on the left front side of the engine. The tensioner on the 3.4 liter, 3.5 liter and the 3.9 liter engines will require a 3/8 ratchet to release the belt tensioner. The 3.8 liter engine will require a ratchet and a 15 mm socket for the belt tensioner. Rotate the belt tensioner clockwise to loosen and remove the belt from the belt tensioner pulley.
  • 3 Slide the old belt from the belt tensioner pulley. Remove the belt from the remaining pulleys and pull the belt from the engine compartment.
  • 4 Route the new belt across the crankshaft pulley first. The crankshaft pulley is the big pulley on the bottom of the engine in the center. Then route the serpentine belt across the remaining pulleys as directed by the serpentine belt routing diagram. Leave the belt tensioner pulley for last.
  • 5 Rotate the belt tensioner clockwise again to relieve the tension and slide the new belt across the top of the belt tensioner pulley. Release the belt tensioner and the belt will tighten up as the tensioner applies pressure to the belt. Make sure the new belt is properly seated in all the pulleys.
  • 6 Crank the engine and inspect the belt again to make sure that it stays seated in the pulleys.
  • Read more: How to Replace a Serpentine Belt on a 2003 Chevrolet Impala ' eHow.co.uk http://www.ehow.co.uk/how_6120665_replace-belt-2003-chevrolet-impala.html#ixzz1Yi6QLAjb
    Sep 21, 2011 | 2003 Chevrolet Impala
    Need to change the alternator on a 2001 sunfire,2.4 engine,how do i do that?
    Things You'll Need:
    • Battery terminal wrench
    • Serpentine belt removal tool
    • 3/8-inch ratchet
    • 3/8-inch metric socket set
    1. Turn off the engine and place the transmission in park (automatic) or first gear (manual). Engage the parking brake and open the hood. Disconnect the negative cable from the battery terminal using the battery terminal wrench.
    2. Remove the serpentine belt by inserting the end of the serpentine belt tool into the square hole on the belt tensioner and rotating the removal tool clockwise. Unplug the alternator's electrical connector. Remove the bolt holding the positive voltage cable to the alternator using a 3/8-inch ratchet and a metric socket. Remove the positive voltage cable from the alternator.
    3. Remove the alternator bracket bolts using a metric socket connected to a 3/8-inch ratchet. Remove the alternator from the car. Place the new alternator in the mounting brackets and reinstall the mounting bolts using a 3/8-inch ratchet connected to a metric socket.
    4. Reinstall the positive voltage cable on the alternator and tighten the retaining nut using a 3/8-inch ratchet and a metric socket. Plug in the alternator's electrical connector. Compress the serpentine belt tensioner using the serpentine belt tool. Reinstall the serpentine belt according to the belt-routing diagram located under the hood.
    5. Reconnect the negative cable to the battery using the battery terminal wrench. Start the engine and verify that the alternator works.
    Oct 29, 2010 | 2001 Pontiac Sunfire
    Change serpentine belt on 06 sienna
    1. 1 Check to ensure the Sienna's engine is cold, then make sure the Sienna is in park, the ignition is in the off position and the key is removed from the ignition to prevent any possibility of the engine engaging during the serpentine belt replacement.
    2. 2 Open the hood and locate the serpentine belt routing diagram sticker on the side of the engine casing. Study it for a moment before removing the existing belt. It is essential the new belt be installed exactly as the diagram indicates.
    3. 3 Find the tensioner pulley, the main pulley that controls the serpentine belt, and fit a 1/2-inch socket wrench over the self-tensioner on the outside of the pulley.
    4. 4 Pull the wrench to the left to move the pulley forward, which loosens the belt, then remove the belt.
    5. 5 Compare the old serpentine belt with the new, replacement belt for length, width and number of grooves on the belt's underside. Be certain the replacement belt is the right part.
    6. 6 Fit the new belt on to each pulley according to the serpentine belt routing diagram on the manufacturer's sticker, or according to the drawing made prior to removing the old belt. Fit the new belt on to the tensioner pulley last, again applying pressure on the pulley's self-tensioner with the half-inch socket wrench to loosen the pulley.
    7. 7 Release the pressure on the self tensioner and allow the tensioner pulley to ease back into place, thereby tightening the new serpentine belt with the appropriate tension.
    8. 8 Remove the wrench and close the hood.
    Thank you and good luck,
    Lee
    Aug 26, 2010 | 2006 Toyota Sienna
    Replace a serpentine belt correctly
    if no sticker under the hood to show the route. go to the auto parts store and ask for a belt diagram. if the don't help, try your local repair shop. best of luck.
    Aug 06, 2009 | 1994 Jeep Grand Cherokee
    Need diagram for routing of the serpentine belt on 98 ZX2 Yes having problem threading the belt correctly needa an detailed diagram kind regards
    Go on the Dayco belts web site. They make serpentine belts and a pretty good data base of belt diagrams for any vehicle they make a belt for.
    Feb 02, 2009 | 1998 Ford Escort
    2004 Mustang Factory Wiring Diagrams Logo
    56 people viewed this question
    Top Ford Vehicle Parts & Accessories Experts
    xxxxxx xxx
    Thomas Perkins
    Thomas Perkins
    Colin Stickland
    Colin Stickland
    Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
