I cannot play all the games on legends of darkness
It will not let me play my pc game legends of darkness game cd what can I do
    Sergeant:
  • 247 Answers
More than Likely the problem lies in your graphics card.... It may not meet minimum req for the game or your having driver issues. I would check your device manager to see if there are any issues. if running windows 7 just hit the start menu type in the search " Device Manager" Open it up and look at your display adapter and chip-set if it shows a yellow triangle there are issues. also if your display adapter says " Standard Windows adapter " then you need an up date. Please send me the model number of your computer and I will send you the link to download and install the correct driver. this should solve your issue.
Posted on Dec 27, 2013
4 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: my pc whines when i play a video or game or louder
A) Processor fan speeds up to cool the Processor.
Gaming, a video, and uploading requires more Processor 'power'.
A Processor has a Thermal Limit. A temperature it can reach, and no more.
Going past this thermal limit would burn the Processor up.
The Processor fan speeds up, to keep the Processor below this thermal limit.
(If the Processor temperature exceeds the thermal limit, the Processor is turned off. BIOS turns it off)
The Processor fan is usually one of two methods used.
1) A fan sitting on top of the Heatsink, which sits on top of the Processor's case,
Typical Heatsink/Fan combo,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3451342&CatId=493
2) A computer case fan in the front, that pushes air through a plastic shroud, which envelopes the Heatsink, sitting on top of the Processor.
Perhaps the fan's bearings are going out.
Bad fan bearings will let the fan shaft tilt to one side, and the fan's center hub will scrape on the fan motor.
This can cause a whining sound.
(Goes for examples 1 and 2 above)
Computer unplugged from power, Anti-Static Precautions observed, see if you can gently rock the fan's blades up, and down.
NO perceptible movement should be observed, nor felt.
If so this fan needs to be replaced.
If the inside of the computer is dirty, the added 'Gunk', (Dust, dirt, hair, you name it), will cause the fan blades to be unbalanced.
This will make the fan tilt to one side also.
Computer unplugged from power, Anti-Static Precautions observed, computer case open, use a can of compressed air for computers, and clean the inside of the computer out.
May require two cans.
May also require that you use Q-tips to disturb the outer layer of the 'Gunk', so that the can of air can remove it.
(Would also like to add:
The can of compressed air for computers comes with a plastic 'straw'.
The straw is attached to the nozzle of the can of air, when using it.
A Power Supply should have the inside of it's case cleaned also.
The cooling components for a Power Supply, are it's fan, and internal Heatsink's used inside.
http://en.wikipedia.org/wiki/Switched-mode_power_supply
[ Typical construction of a Heatsink is a plate of metal, with tall, thin fins protruding from it.
The plate of metal absorbs heat from whatever object it is placed against, and the tall, thin fins absorb heat from the plate of metal.
The tall, thin fins then radiate the heat away.
If a fan is used in conjunction with a Heatsink, (Such as a Power Supply, or Processor), the air flow from the fan helps to carry heat away from the fins ]
When the fan blades, center hub, and surrounding shroud are coated with Gunk, and the Heatsink's inside a Power Supply, their cooling capacity drops TREMENDOUSLY.
This causes the Power Supply to overheat.
Heat = Wasted Energy.
The Power Supply strains to keep up with the call for power, and eventually cannot.
Components inside the Power Supply fail, and the Power Supply fails.
(As in Kaput)
The Power Supply's case has ventilation holes, on the case side inside the computer.
The plastic straw of the compressed air for computers, is inserted into the top ventilation holes, and air is shot in. (One ventilation hole at a time)
The straw is aimed in a slightly downward fashion.
Then the straw is used in the lower ventilation holes, and then on the bottom ventilation holes.
HOLD onto the plastic straw with one hand, and the compressed air for computers with the other hand.
The straw can shoot off of the can of air's nozzle, and wind up inside the Power Supply's case.
This = NO
No go to the back of the Power Supply, and use Q-tips to get into the crevice where the fan blades meet the center hub.
Also on the edges of the blades, and the surrounding shroud around the blades.
You just need to disturb the outer layer of Gunk, so the air can remove it.
Shoot air past the fan into the Power Supply case also.
You won't get the inside of the Power Supply perfectly clean, but you will extend the life of the Power Supply greatly.
The inside of the computer, and the inside of the Power Supply, should be cleaned on a regular basis as needed.
Different scenarios require more frequent cleaning, or less frequent cleaning.
Only you will know, when you check inside your computer on a regular basis.
You can be the best housekeeper in the world, but even in pristine homes, and businesses, the inside of a computer, (And Power Supply), gets dirty.
(Carpet deodorizer can clog a computer too. It's a fine dust)
If the inside of your computer is kept pristine clean, and you have No fan bearing problems, then your Harddrive is on it's way out.
This explains the workings inside a Harddrive,
http://computer.howstuffworks.com/hard-disk.htm
(The Spindle motor's bearings are going bad )
Posted on Sep 20, 2010
Testimonial: "Thank you. All the information you gave me Im sure will be very helpful. Thanks again!!"
kornho
  • 781 Answers
SOURCE: PC IS NOT RUNNING ANY CD/DVD'S
janice, if you say the only change on your system was the installation of this game you may want to start troubleshooting by uninstalling your beloved game and retest playing cd/dvd.
if it works... your game may have been poorly made and may have affected the driver of your cd/dvd device.
is also possible your game may have come with other software (spyware/virus) that may have affected your computer. Uninstall game and run updated antivirus and antimalware software. you may want to reconsider the source of your games.
your game may have also come with other software to play cd/dvds that may have been installed and selected to be the default player of cd's and dvd's and may require especific configuration to play the cds or dvds.
to change the default program that plays dvd or cd.. go into my computer>tools>folder options>file type tab>select audio cd and click change under the detail section to change the program you open the file with. do the same for dvd.
if none of the above worked. try to revert your system to a previous date (when your devices were working) with system restore: (if using xp)
start>all programs>accessories>system tools>system restore.
Posted on Sep 26, 2008
  • 47 Answers
SOURCE: wanna have these games for free
the unlock codes.. are not 100% legal.. so i would suggest that u do not post those questions .... you can always look in google for torrents that have them
Posted on Jan 09, 2009
Is League of Legends better than Dota?
According to me, Yes! League Of Legends(LOL) is much better than Dota . I had played both the games. But I liked LOL much.
I love playing games and this is one of my favorite game and I don't think so I will never quit this game. This game is very exciting and characters available in the game is very attractive and powerful. I like to play an animated game and this game is perfect for me. My friend is using buy lol smurf account, they are providing services to their customer and I took services from there. It is very worth for me.
Jun 15, 2018 | Games Video Game Consoles & Games
Which site provides the best customer service for buying League Of Legends smurfs?
There are several websites available on Internet from where you can easily purchase or download Smurfs to play League of Legends.
This game requires smurfs to play. I personally prefer to buy lol smurf account because it will provide League of Legends accounts to your email address as soon as you compelete up their payment procedure.
Every account provided by them is of notch quality and they provide a very good customer services.
Sep 28, 2017 | The Video Game Consoles & Games
Which is the best site to create Smurf account for playing League Of Legends?
League of Legends is a multiplayer online battle arena video game which requires smurfs to play.
This game is interesting and popular because it is a fast-paced, competitive online game in which two teams of powerful champions have a battle with each other.
In order to play this game, you need to collect smurfs, you can buy league smurfs which provides provide League of Legends accounts to your email address as soon as your payment procedure is done.
Legends of darkness
Never played it, but I've ran into this issue with many other games. If you got the game legitimately, see if there are any patches available for download. If not, google/yahoo for what they call "unofficial patches." Vampire the Masquerade: Bloodlines was one heck of a game, but shot full of technical issues. The developers where tortured during the whole development process, so what could they do? But, there are a multitude of great patches for the game made by dedicated fans that fixed nearly all of the problems! :)
Mar 06, 2014 | Computers & Internet
Can not pickup glasses in Virus Island game in Legends of Darkness
exit the game, open up my computer, and go to C:\Program Files (x86)\On Hand Software\Legends of Darkness\virus\Data\Scripts\Objects\Objects\location_001\00101, in this directory you will find a file called glasses.xml, simply rename the file to glasses1.xml, and relaunch the game, because the game will no longer be able to load this item it will allow you to move on with your game, after you get past this i would recommend exiting the game, and going back to the above directory and renaming the file back to glasses.xml and then relaunching the game hope this helps !!!!
Nov 28, 2013 | Video Game Consoles & Games
How to play Donkey Kong 64 without Expansion pack
Donkey Kong 64 was one of only three Nintendo 64 games to require the Expansion Pak (the others being The Legend of Zelda: Majora's Mask and Perfect Dark), which provides 4 MB more RAM for enhanced graphics and more expansive environments, as well as to fix a game-breaking bug.We don't think that you can play this game with no expansion pack. I have tried to play perfect dark with no expansion pack and it was not all there then.
Mar 13, 2012 | Nintendo 64 Console
Need games for the first nentendo made. games called the legend of zeldo also zelda game boy color. need computer game called amber
Play Legend of Zelda here
http://www.flash-game.net/game/1887/legend-of-zelda.html
Zelda game boy color
This game is still has been in production and has not been released yet according to business insider news.
http://www.businessinsider.com/top-25-handheld-nintendo-games-2011-7
Game name Amber is not to be found. It can be a very old and rare game or the complete name is not provided.
Jul 15, 2011 | Computers & Internet
How to down load pc games using u torrent
Hi mate the best way to do want your after is go to mini nova find the file and download just make sure to read comments as there a good marker of file quailty most of the time you need to down load a program called daemon tools because when you down load a game its a iso file which is a raw disk file so if you try to install but game protection wont let you so you hafto to mount it in daemon tools very easy then install then when you want to play just click on your lick as its all ready mounted it tricks pc into thinking theres a cd in the drive hope this helps please rate thank you
Oct 18, 2009 | 2K Games Stronghold Legends for Windows
Dark crusade key into soulstorm when it asked and didnt work
Dark crusade and soulstorm are diffrent game's so will have separate cd key code's , the codes should be on the back of the booklet's that came with ya cd's . I have all the warhammer code's if you would like to try them my e-mail is pete.logan01@talktalk.net if you would like them contact me and il e-mail ya back asap.
Jun 12, 2009 | THQ Warhammer 40000: Dawn of War: Game Of...
Computers & Internet Logo
165 people viewed this question
David Payne
David Payne
