Question about Frigidaire Dishwashers
Frigidaire Dishwasher showing error code PF with 'hi-temp wash' and 'no heat dry' lights flashing
Dishwasher stalled during rinse cycle with flashing error code CL. When I couldn't resolve it, I tripped the circuit breaker. After that, dishwasher continuously flashes error code PF along with flashing 'hi-temp wash' and 'no heat dry' lights. Dishwasher remains non-response. Model # FDB949GF, Serial # TH92954023.
My Frigidaire Gallery dishwasher has the code "PF" flashing and door latch is not working. Any suggestions.
PF code on Frigidaire dishwasher
Since the PF indicates a power failure, it has most likely lost electrical connection before the control board and this is the most likely place for this to occur. Frigidaire dishwasher (PLD4375RFC0) seems to complete wash cycle but often has power failure (PF) code during the dry cycle.
the latch must be fixed for it to work a broken latch will cause this problem Frigidaire Gallery dishwasher has the code PF Google Search
also we need to know what model it is to recommend a part
Feb 03, 2018 | Frigidaire Dishwashers
LG dishwasher LD1419W2 which would not fill -error code IE. I replaced the inlet hose complete. Now it has the error code FE and the water overflows onto the floor when in wash cycle. Peter
Try resetting by:
turn off dishwasher
trip circuit breaker to remove all power to unit
wait 30 seconds
restore power
start dishwasher
the drain pump should start and drain all water then start a cycle. Good luck
Nov 14, 2017 | LG Dishwashers
Electrolux dishwasher tripping on drying cycle
Good Afternoon friend, thank you for your post!
From my understanding your Electrolux dishwasher is tripping your circuit breaker during the cycles. This could be a wiring issue within your dishwasher and you may need to have a professional technician come out. The technician will have the appropriate tools needed for pinpointing the issue within your dishwasher. Best of luck! -Matt
Feb 11, 2015 | Electrolux Dishwashers
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 18, 2015 | Kenmore Dishwashers
Dishwasher trips out after running for a while
When you say "trips out" do you mean the circuit breaker trips? If so the breaker in the electrical box may be bad. Also do you have anything on that circuit pulling high amps when the dishwasher is running? Also when does it "trip out" during a pump cycle or when the heating element cycle starts?
If the pump does not work at all then the pump may have went out. If it happens when the heating element cycle starts then it may be the circuit is overloading or the breaker is bad.
Oct 14, 2014 | Smeg Dishwashers
I get an Er code 5 on our Dishwasher and it keep restarting in the rinse mode
Thank you for your post, friend!
I see you are having trouble with your Frigidaire dishwasher and you are receiving error code "5". However, it appears "5" is an invalid error code. May I have you model number please? Typically you can locate your serial tag on the inside wall on the left hand side. With this information I can better assist you with pinpointing the issue.
In the meantime, let's attempt resetting your dishwasher. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes. -Matt
Sep 18, 2014 | Frigidaire Dishwashers
Why does my Fisher and Paykel DD605SS stall part way through wash cycle?
I'm not sure of this, because the manual does not have an error with a E. I can fine error F4. It says it encountered a faulty temperature sensor or element. If the heating element burned through the night you circuit breaker tripped (Sure it was not the ground fault circuit breaker?), then the dish washer can't heat the water, so the program can't continue. The program stops (waits) till the chosen temp is reached. If the water stays cold the program can't go on.
So also check the heater in the machine. I hope you are aware everything in the machine runs on high (or at least dangerous) voltages, so be careful not to work in the machine when it is still connected.
Jun 15, 2014 | Fisher and Paykel Dishwashers
Viking dishwasher VUD040 keeps tripping the circuit breaker during drying cycle
Are you sure the breaker is big enough to carry the Amps needed to start the drying cycle. You know that due to inductance it takes almost twice as many amps to start a motor as it does to run it.Find out how many Watts it uses and divide it by 120VAC and it will give the maximum amps it will draw. See if the breaker is high enough amp for it. A 25 Amp breaker should be efficient. I hope this helps you and if I can help you in anyway in the future let me know.
Mar 12, 2014 | Viking Dishwashers
My Frigidaire electrolux dishwasher model # FDB2310LCC0 trips a pf code 40minutes into the cycle and it is not the circuit breaker. how do i correct this problem?
Good Morning Doria, thank you for allowing me to assist you!
Typically PF means power failure and you should be able to start a cycle. Unplug the unit or flip the household circuit breaker. Wait about ten minutes and then turn the unit back on. If the error code continues to display, I would suggest contacting a professional to accurately diagnose and repair it.
Best of luck!
Oct 07, 2013 | Electrolux Frigidaire Professional Series...
PF, high temp wash and air dry lights blinking. Reset main breaker but no help.
Hello babe_dog01 - PF typically appears in window when dishwasher is first installed, or when power has been interrupted. HI-TEMP WASH, SANITIZE and START/CANCEL backlighting will also flash. To clear, touch START/CANCEL pad or resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Since you have already done so and it was ineffective contact a professional to move forward accurately. Dishwasher could possibly be experiencing a communication error, wiring failure or faulty control board.
Jan 05, 2013 | Frigidaire FGHD2433KF Builtin Dishwasher
Dishwashers Logo
202 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
