Question about Sony Playstation 3 (PS3) Console
Cannot get any thing on my tv with the playstation there are no inputs that work
I cannot get any thing from the play station on my tv at all did hook up to tv with hd cables. I also have dish network as well any help will be great
  • 32 Answers
Have you connected to two different TVs? If so did you connect to both with a HDMI cable?
Posted on Dec 27, 2013
J4XXN
  • 182 Answers
SOURCE: hooking up playstation 3 to tv
you need a ps3 scart lead. i think the one of the ps2 is the same but check. it should just hook up like a ps2. if you are having any problems with the picture hold down the power button when you start up the ps3 for 10 seconds this runs the optimal screen settings for the cable you are using. but if it is the first time you are using the ps3 it will auto start in set up mode. hope this helps
Posted on Jan 11, 2008
JSPCEXPRESS
  • 178 Answers
SOURCE: Playstation 3 on Sanyo Large Screen HD DT
It would be better if you went diretly threw a video source on the TV. Rn the wires from the PS3 to the tv and then select the source that it is connected to
Posted on Feb 10, 2008
SOURCE: Connecting PS3 to HD TV without HDMI input
Component video input. Red, Green, and Blue. Your system should have come with it, but I don't know, I'm a 360 user.
Posted on Jun 06, 2008
SOURCE: a slight feedback noise from speakers while playing playstation 3
probably your wires. any time speakers hum something is not connected properly or there is interference from another gadget nearby. Invest in some better wires and your problem should go away
Posted on Dec 18, 2008
SOURCE: Playstation 3 hook up problem
I ended up using the component in cable hookup and fiber optic digital audio instead of HDMI - works fine.
Posted on Dec 29, 2008
How do I hook up playstation 2
Find the inputs on the TV, usually on back panel, and sometimes there will be inputs on the side panel. Match up the connector from the PlayStation to an input on the TV, and plug it in. Plug the power cord into the wall receptacle and turn the Play station on. Using the remote for the TV , find and click on the button that says 'input' or 'source' Make note of which input is on for the TV, so you can find it again. Now scroll down the inputs until palystaion appers on the screen.
Jun 06, 2014 | Seiki Televison & Video
I just bought a 22"
The PlayStation2 has standard red yellow and weight RCA cords. These should correspond to red yellow and white inputs in a line on the back or side (or possibly front) of your television. IF you are hooking them into differently colored inputs, then that is the problem.
Also worth noting, your television may have multiple inputs. This means that the software on the TV needs to be set to read from the correct input. Search for a button on your remote control that says input, and attempt to cycle through the inputs until you find one that works. Make sure the PS2 is on while you do this, otherwise you wouldn't get a signal anyways.
Jul 23, 2011 | Televison & Video
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Hooking up & seeing a dvd player?
does the dvd have a coax output for coax antenna input on the tv? you can use that untill you can get the video input selection straight with the tv and a remote that supports rca's extra functions such as menu , tv/av button
or
also if there is a( wake-up) on/off timer in the tv menu , then you can also set it to come on with the video input instead of a tv station,set it a few minutes after the time it is when you set it( then just turn off the tv set after the time is set and you have exited the menu, then it will come on with the video input instead of a tv station)
otherwise you will need that remote that supports the video input selection on your tv
Jan 08, 2009 | RCA F20625 20" TV
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Jul 11, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
How Do I Hook This Thing Up?!?
See what audio outputs your tv has. See if your HTS has matching inputs. If it does connect them with the proper cable(s). Connecting to the tv should cause your HTS to work with anything you are watching on the tv.
May 15, 2008 | Durabrand STS92 System
If there is no picture on the TV screen: Back to top
  • Check that the input mode of the TV is appropriate for the connector in use on the PLAYSTATION®3 computer entertainment system.
  • There may be a problem with the cable in use. Try using another cable that is compatible with the PLAYSTATION®3.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
If that does not help try contacting sony at
1-800-345-7669 (SONY)
Mon - Sat 6:00AM - 8:00PM PST
Sun 7:00AM - 6:30PM PST
Best of Luck,
-Rel
Apr 20, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
Hi there!
Try replacing the Playstation cable. It may be faulty.
Regards, JUS004
Mar 31, 2008 | Hitachi 57G500 57" TV
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
