Question about Kodak EasyShare DX6490 Digital Camera
I'm trying to use a new 4MB SDHC card in my Kodak DX6490 and it won't format. I work on a Mac platform. The only answer I found looked like a pc solution
  • 864 Answers
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Posted on Aug 27, 2010
Kodak camera won't format sd card
Your older camera can only use 2GB or less standard SD card. It can not be used with the new 4GB or higher SDHC cards. Fortunately, 2GB cards are relatively inexpensive these days, and may be found on Amazon if your local store no longer carries them.
Dec 06, 2011 | Kodak EasyShare CX6230 Digital Camera
My camera akodak easy share, DX6490 Has 2 sanDisk 128mb that Ibought with the camera in 2003 Works fine. The new sandisk cards 4gb say they need to be formatting. The camera keeps repeating it needs...
If you've tried to format the cards in the camera and it failed, it's probably because the cards are SDHC cards instead of SD. With a camera as old as yours, SDHC cards hadn't come out yet.
Aug 18, 2011 | Cameras
Purchased new memory card. camera screen said to format card, camera will not format card please isnsert another. new card is kodak 8gb sdhc. it works in a different kodak camera
The DX6490 works with MMC and SD cards. While an SDHC card will fit into the slot, it is electronically incompatible and will not work. Some Kodak cameras can use SDHC cards, but the DX6490 is not one of them. You need to go with SD cards, 2GB and smaller.
Feb 19, 2011 | Kodak EasyShare DX6490 Digital Camera
How do I format a 4MB SDHC card for this camera
"SD and MMC flash memory cards marketed by Kodak, Kingston, Sandisk, PNY and other flash-memory card manufacturers will work with the EasyShare C643. The digital camera supports standard MMC cards and SD (secure digital) cards, but not SD High-Capacity (SDHC) or SD Extended Capacity (SDXC) cards."
Read more: Compatible SD and MMC Cards for a Kodak EasyShare C643 ' eHow.com http://www.ehow.com/facts_7590028_compatible-cards-kodak-easyshare-c643.html#ixzz1BijGdWKF
Jan 21, 2011 | Kodak EasyShare C643 Digital Camera
It will not format a 4gb SanDisk SD card
Your 4GB card is actually an SDHC card. The DX6490 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to go with SD cards 2GB and smaller.
Nov 28, 2010 | Kodak EasyShare DX6490 Digital Camera
I have a DX6490 Kodak camera and just purchased 4GB SDHC sandisk card but camera keeps 'saying' it needs to be formatted but it doesn't format it when I go thru the menu to try.
The DX6490 is designed to work with SD cards. While SDHC cards will fit into the slot, they will not work. You need to use SD cards 2GB and smaller.
Aug 16, 2010 | Kodak Cameras
What is the sd card compacity limit for the DX6490. I have a 8 gigbite sd card and it just keeps asking me to format it. After formating it i put it in a card reader and it still has the pictures i put on...
The DX6490 accepts SD cards, which top out at 2GB. Cards bigger than that are technically SDHC cards. While SDHC cards will fit into SD slots, they will not work. SD cards will work in SDHC devices, though. So, you're limited to 2GB.
It's a hardware thing, which no amount of firmware updating can change.
Feb 24, 2010 | Kodak EasyShare DX6490 Digital Camera
Bought 4gb memory card for dx6490 but it wont format..is there a way to make it work
The DX6490 is only compatible with SD/MMC up to 1G.
It is not compatible with SD/SDHC Cards.
Pls. use the recommended SD card and the problem should be solved.
Dec 14, 2009 | Kodak EasyShare DX6490 Digital Camera
Kodak EasyShare DX6490 Digital Camera Logo
294 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
