Question about Cell Phones
Samsung reset password - Cell Phones
How do you reset a simple Samsung phone that having a password
hi Malick.
see if this link helps you out,but if you do try this out do so at your own risk.
Samsung Phone Master Reset Code
or you could also try this one.
master reset code for all samsung mobile phones
and this one.
How do you reset simple Samsung phone Google Search
Nov 21, 2017 | Samsung Computers & Internet
Tip
I Forgot my Samsung Password - How to Reset Samsung Password
Most of our Samsung PC, laptop or notebook users often meet problem with Samsung password reset. Sure, easy to forgot password while troublesome to find ways to unlock Samsung password. Then I will share some methods for Samsung password recovery.
Method1: The most saving time and efficient way to reset Samsung password
Opt for professional Ainorsoft Windows Password Recovery software to recover our lost Samsung password. Now, we can login our PC within minutes and without losing our important data. The software does not require what version of Windows you are running or whether you have any technique computer skills. The followings are easy steps to unlock Samsung password.
Step1. Download the program from an accessible PC;
Step2. Burn the .iso file to a blank CD/DVD or USB Flash Drive;
Step3. Break forgotten Windows password with the burned CD/DVD.
Method2: Logon Samsung laptop from other accounts with administrator privilege
Such as Windows XP, Vista, there is a backdoor or default administrator accounts. If the account is accessible, we can refer to it to help us reset the forgotten Samsung password. Also, we can access PC with other accounts which own administrator rights, you can use them to login your PC and reset the lost password. Let's take Samsung Win 7 Laptop as example:
1. Logon Samsung Windows 7 laptop from the accessible account with administrator rights.
2. Start - Local Users and Groups - lusrmgr.msc in the Search box - ENTER.
3. Local Users and Groups - choose Users.
4. Right click the account needed to reset password, and then select Set Password.
5. Input and confirm the new password.
Method3: Samsung password reset with Ophcrack or Offline NT Password & Registry Editor
Ophcrack is free tool based on rainbow tables. It can recover alphanumeric passwords in seconds while not 100% work. We need download its free ISO image, burn it to a CD and boot from the CD. When program starts, we locate the locked user accounts, and proceed to recover the passwords.
Offline NT Password & Registry Editor can erase the Windows password by burning its .iso file to a CD.
Method4: Samsung password recovery with password reset USB or CD/DVD
The last method may not help us if we do not have it before we lost the password. But the password reset disk is important for us Samsung PC users. We should create the Samsung password reset disk once we set password for our PC. Take Samsung Windows XP as example to create a disk:
a. Start - Control Panel - User Accounts - account name locked.
b. Under Related Tasks, click Prevent a forgotten password.
c. Create a password reset disk by following the Forgotten Password Wizard.
Bypass Samsung password with the created password reset disk:
d. Click the username when we get to the Windows logon screen and then press Enter when password box appears.
e. Click use your password reset disk. The Password Reset Wizard starts and Next.
f. Insert the password reset disk, and then Next.
g. Type a new password in the Type a new password box and in the confirm box.
In the Type a new password hint box, we can type a hint to remind us the password if we forget the new password if we want to use one.
h. Click Next, and then Finish.
With the above four methods, we will be ease to reset Samsung password if we forgot Samsung password. And we also welcome the all readers share them with your friends. It will be helpful for them to unlock Samsung password instantly!
on Mar 10, 2011 | Computers & Internet
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
To factory reset the SDR-B74301
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
CCTV Networking Technical Support
Sep 18, 2017 | Samsung Home Security
Forgot my username and password for my samsung account on my galaxy s7 . I can't do anything on my phone. Can anyone help ? Its Sprint service if that helps .
Your username is your email address, how can you forget that? Do a Factory Reset and then set up a new account. Write the details down. However, read these links first.
  • How to find your Samsung Account ID and Password - YouTube www.youtube.com/watch?v=W9F7CS946zU
    • BY SAMSUNG CONTENT
    • 2 MIN
    • 939K VIEWS
    2014-09-18 · Video embedded · How to find your Samsung Account ID and Password ... Samsung Galaxy S3 Glas Wechseln Tauschen unter 20€ Reparieren ...
  • How to reset my Samsung Galaxy S7 to the factory default ... support.bell.ca > Bell Mobility This option lets you erase all of the content and settings on your Samsung Galaxy S7 and reset ... account password to ... How to reset my Samsung Galaxy S7 to ...
  • Forgot Password Samsung Galaxy Ace S5830 How To Hard Reset ... www.youtube.com/watch?v=Fy6pmlmTwP0
    • BY HARDRESETYOURPHONE
    • 2 MIN
    • 94K VIEWS
    2012-07-14 · Video embedded · Forgot Password Samsung Galaxy Ace S5830 How To Hard Reset ... Samsung Galaxy S7 vs iPhone 6S Water ... Samsung Galaxy Ace - Forgot Password - Hard Reset ...
  • I lost my samsung account password? - I forgot my username ... www.askmefast.com > Computers & Internet > Google > Account I lost my samsung account password? I forgot my username and passw ... I forgot my samsung account password on galaxy ace so please anybody help here ? ...
  • Remove an email account - Samsung Galaxy S7 - Sprint support.sprint.com > Support > Devices > Samsung Galaxy S7 32GB Remove an email account - Samsung Galaxy S7; ... Forgot my username. ... Forgot my username. Forgot my password. Sign up for My Sprint; Sign up for My Sprint;
  • What is my Samsung account username ... - Samsung Electronics www.samsung.com/us/support/account/.../faqs/usernames-passwords.html The email address you used when you created your Samsung account is used as your username ... > Profile > Forgot your ID or password?. Tap the Find ID tab, ...
  • http://www.bing.com/search?q=Forgot+my+username+and+password+for+my+samsung+account+on+my+galaxy+s7+&src=IE-SearchBox&FORM=IESR02&pc=EUPP_
    Jun 01, 2016 | Samsung Cell Phones
    Samsung GT-c3262 mobile reset password
    ImEI - 354910/05/043186/7 , 354911/05/043186/5 these are the imei nos in my phone samsung GT-c3262 what was the password for master reset
    Mar 06, 2013 | Cell Phones
    Password reset
    hi tom5162, You can reset all your settings by resetting your phone(By doing your data in phone will be deleted.....
    To reset dial *2767*3855# ,it will reset your phone to factory mode.
    To save your data, please backup your phone.....
    Thanks
    Aug 23, 2008 | Samsung U900 Soul Cellular Phone
    Samsung SGH-U600 lost password
    You should be able to reset by turning on the phone without the SIM card inside, entering *2767*2878# and waiting for the phone to reset
    Jun 01, 2008 | Samsung SGH-U600
    Cell Phones Logo
    55 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
