Question about Sony Net MD Walkman MZ-N710
How do i download instruction book from net? if i buy a generic power adapter will it charge the mini disc players battery by being plugged in?
How to download sony walkman MZ-N7 10 instruction manual? if i buy a generic power adapter will it charge mini disc battery by being plugged in? thanks
    President:
  • 1,285 Answers
Charger tips to small for dell laptop
A Dell Mini net book is a small and very portable laptop. The compact size makes it a good candidate for travel or just simply using around the house. Outdoor aficionados can get the most computing life out of a Dell Mini by finding a way to charge the battery outside. One method works when you are near a building while the other can be used for more remote outdoor locales
Things You'll Need
  • Extension cord
  • Solar laptop charger
  • Dell Mini power adapter
    • 1 Plug an extension cord into an available power outlet. Run the extension cord to where you are outside. Many homes also have exterior outlets. Use an extension cord that is designed for outside use. Plug the Dell Mini power adapter into the extension cord to charge the battery.
    • 2 Purchase a laptop solar charger. Solar chargers are available from several different manufacturers and may come in the form of a roll or be built into a case that closes up for travel. Depending on the charger, you may also need to purchase a Dell Mini power adapter. Some chargers work with a Dell Mini cigarette lighter adapter that is designed to plug into a vehicle's power port.
    • 3 Place the solar laptop charger in a sunny location. Open up the case if the charger is in one and roll it out flat or unfold it to expose all of the solar cells.
    • 4 Connect the Dell Mini power adapter to the power port on the solar charger. Connect the other end to the netbook. The adapter will regulate the charge coming from the solar panel and recharge the battery in the Dell Mini.
  1. Tips & Warnings
  2. Solar chargers offer less power than a wall outlet. They can be used to extend the battery life of a Dell Mini or to recharge the battery when the netbook is off.
  3. Some solar laptop chargers are relatively heavy. Take the weight into consideration if you are going to be backpacking or otherwise carrying it on your person.
Oct 23, 2011 | Computers & Internet
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
My screen is black the net book is not charging
It is very common with netbook. It could be your netbook's battery is not charging or your power adapter is broken. Try to remove battery, put power adapter to outlet, turn on netbook to see if it boots. If it works, then it is time to replace battery. If it's not working, then buy new adapater.
Apr 04, 2011 | Computers & Internet
How do i transfer songs from my pc to the mini disc
you have installed the Sony software (you don't have the driver... http://esupport.sony.com/LA/perl/swu-list.pl?mdl=MZN510 enter your OS and download, and you have the USB data cable or optical cable (optical is recommended)? plug AC adapter to mini. Open two windows of my computer. go to your music folder and copy / paste or click and drag to mini disc.
http://www.docs.sony.com/release/MZN510.pdf
see page 75
happy recordings
Feb 13, 2011 | Sony Net MD Walkman MZ-N510 MiniDisc...
How do I recharge the battery? This is a portable DVD player with a battery pack and the instructions say recharge battery before useing, so I put the battery in place and plug in the power cord and left...
Hello, You are doing it right! the battery should be charged with in the 24 hour period. There are two things to consider : One, is the possibility that the rechargeable battery has dried(due to wear and tear)and is not accepting the charge or The second possibility is that the power supply isn't working properly, therefore, not charging the battery.
It is possible to know at least if one of the two is working just by operating the DVD player while connected with the AC adapter. Turn the DVD on and play a disc, if the unit operates, this eliminates a defective power supply and only leaves a defective battery pack, if it doesn't work than consider the power supply defective and repairs are due. As to where to buy a replacement part is for someone else to answer. Good luck!
Oct 13, 2010 | Lasonic Televison & Video
I have a Dell Inspiron mini 10 . net book. Out of now where said something about windows and shut off ... now we cant get it to turn on, wont go past the inspiron load screen the little blue only goes...
tryt to do this
1.unplug the ac adapter
2.remove the battery
3.press the power for 30 secs
4.plug the ac adapter back in and after few secs try to turn it on
Oct 04, 2010 | Dell Inspiron Mini 10 Notebook
My TOSHIBA MINI NB205-n313/9 10.1 inch net book will not turn on
The laptop is not turning on?
Remove the battery and try boot the machine on AC power only. If the computer starts up turn it back off, reinsert the battery and try to boot the computer again.
If it still won't boot with the battery inserted then i suggest you send or take the computer back as there is a hardware problem.
Regards.
Sep 15, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Record on to mini disc
you can use optical cable / or mini plug to (Y) RCA jacks ...plug the optical cable to the back of a CD player or RCA jacks to your Reciever / Amp (output) to record
Aug 25, 2009 | Sony Net MD Walkman MZ-N505
Mini-DVD playback
two things:
1) connect the camcorder to your computer using a USB cable and play it through that, by the way, what computer is it?
2) you can finalize without the ac adapter - its a built in safeguard to ensure that there is enough power to allow finalization to complete
Jul 18, 2008 | Panasonic VDR-D100 DVD Camcorder
Car Charger and home charger
my car dvd melted around the edge while it was plugged to recharge in car bmathis7643@bellsouth.net
Feb 04, 2008 | Venturer PVS177W Portable DVD Player
Sony Net MD Walkman MZ-N710 Logo
227 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
