Question about Toshiba Satellite P105-S9722 Notebook
I just got a brand new Satellite Toshiba touch screen laptop yesterday for chritmas and its plugged in and charged over night but wont turn on unless its plugged in. Is this temporary? or is something
I turned it on before I was completely charged so I could register it, but I know you're suppose to let it charge before you use it- could that be why its not fully charging or is basically dead when its not plugged in and I go to turn it on? the battery light just stays orange.
  • Toshiba Master
  • 7,993 Answers
As long as the charge is not complete the battery LED remains amber.
Give the laptop the time to charge: it should take 3 to 4 hours it it is not being used, and 3 times longer if it is used.
You do not need to register immediately with Toshiba.
Posted on Dec 27, 2013
  • 253 Answers
SOURCE: Toshiba Satellite L25-S1216 - blank screen
Try to shutdown, remove battery, remove AC plug, Press and Hold Power button for 30 seconds, replace battery and AC adapter and test.
do you hear windows booting ( the startup sound) after a few minutes, if so there may be a monitor hardware problem
Posted on Mar 30, 2009
JaxPlanet
  • 922 Answers
SOURCE: For laptop: Toshiba Satellite A105: My battery
Start by trying another power outlet.
The power adapter should have its own light. If it doesn't light up then the adaper is bad. Kensington.com sells very inexpensive universal power adapters. You might also find a good deal on eBay.
If the adapter lights up then it may be your battery. Notebook batteries are only good for 2-3 years. If you let them sit for a long time without a charge they may only last 1-2 years.
Vote for this solution if it helps.
Posted on Aug 18, 2009
seanpwright
  • 2030 Answers
SOURCE: My Toshiba Satellite A10 S100 Laptop will not turn
It sounds like the power supply inside has gone bad. If its not under warranty it will most likely cost more to fix than its worth.
Try running it without the battery and just off the AC power....if that does the same..I'd say start looking for a new one.
Posted on Aug 27, 2009
Testimonial: "you solved my problems... thanks dude!"
RescueTechLA
  • 2653 Answers
SOURCE: my toshiba satellite m305ds4831 laptop will not
It's a motherboard hardware issue in all likelihood.
There is NOTHING you can do but update the firmware bios. The problem is that most bios firmware update programs require both ac and battery power at the same time :(
You can try to do it anyways by visiting Toshiba's support page for your model and downloading the firmware from there.
It probably won't fix the problem but it's still worth a shot....sometimes it works ;)
Posted on Nov 21, 2009
SOURCE: Toshiba Satellite L305-S5907 won't charge battery.
Thanks to avatar8.jpgJesse Lohse .
My battery is charging now. As per your say to remove the battery and check to see if the prongs are dusty or if it is blocking the main connector or anything else. So, i removed the battery and checked and it was quite dusty so i removed the lint and dust from it. Now it's starting to charge. Now it's at 19%.....Thanks you're the genius
Posted on Mar 22, 2012
Laptop shuts off when you unplugg it and wont turn on with out the charger
The battery can be replaced under warranty. Contact the manufacturer and they will process the replacement, usually cross-shipped for free with good manufacturers.
Mar 28, 2014 | Toshiba Satellite C55-A5242 Intel Celeron...
I have just brought a brand new toshiba satellite c665/000 laptop but once i'd got it home and plugged the charger in it doesnt turn on. The charging and power lights are on but nothing happening on...
Hi Idgetwidget,
I don't think its broken. What your'e experiencing could be because there is no Operating System[Windows] installed on your Laptop! You can download the Operating Systems from this Microsoft site.
Hope this helps.Thanks!
Please rate this answer.
Dec 12, 2011 | Toshiba Computers & Internet
Brand new bought yesterday laptop stuck in a dim screen mode when not plugged in
That is normal because the laptop is probably set to power save when the adapter is unplugged.
Dec 19, 2010 | Toshiba Satellite L305D-S5895 Notebook
Toshiba wont power on
try turning off and then remove battery and plug in a/c cord.turn back on..still nothing let me knowRICHARDM69
Aug 24, 2009 | Toshiba Satellite A135 Notebook
The battery wont charge
return your computer. there is a serious problem with either the charging system or the battery.
Aug 16, 2009 | Toshiba Satellite Pro P300 Notebook
Toshiba Satellite A105-S4064; can't get battery to charge
If you put strain on the jack (e.g. hang power adaptor from it whilst using or charging) then the socket on the mainboard can get hot due to poor contact and melt.
There is no way to fix this except to completely dismantle the laptop and fit a new socket - most likely a repair centre will charge you for a new mainboard.
Try another adaptor to see if that is the problem (broken wire in cord) - otherwise look closely at the socket in the notebook.
Aug 08, 2008 | Toshiba Satellite A105 Notebook
Toshiba Laptop wont work unless plugged in, i recently bought a new battery think that the battery was the problem and still it doesnt work unless its plugged in. please help me!
Go to CONTROL PANEL / POWER OPTIONS / POWER METER. Is the battery charged or charging?
If POWER METER says the battery is charged, you have a motherboard problem. Take it to a tech.
Do you have a voltmeter?
Remove the battery and check for voltage at the laptop's battery contacts, while it is plugged in. No voltage = charging circuit defect. A blown internal fuse or other motherboard problem. Take it to a tech.
Voltage OK or no voltmeter - take it to a tech.
A qualified technician should have a schematic and other technical documentation for your model It can be rather difficult (expensive) and hit-or-miss to locate possible fuses without the factory paperwork.
Good luck.
May 13, 2008 | Toshiba Satellite P105-S9722 Notebook
Battery problem
u try new power plug unit supply next i would try that or does battery show full charged but wont start then mobo has bad power chips on it they can redo them or u can buy new mobo to install in also cheak screen cond cables ect
Feb 04, 2008 | Toshiba Satellite P105-S6024 Notebook
Won't Turn On Unless Plugged In
What is the make/model of the laptop? It looks like the battery is not holding a charge. Have you tried to remove the battery and put the battery back in?
Hope this helps :) Kindly leave a rating. Thanks..
Nov 27, 2007 | Toshiba Satellite A105 Notebook
Toshiba Satellite P105-S9722 Notebook Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
