Question about Samsung RB1955VQ Bottom Freezer Refrigerator
The bottom freezer is not getting cold - Samsung RB1955VQ Bottom Freezer Refrigerator
Can feel cold air coming out of bottom of freezer but it is not cold inside
Do you see ice buildup on the back of the freezer wall about half way down?
Dec 28, 2013 | Whirlpool GS6NBEXR Side by Side...
The freezer is working OK but the bottom is not getting cold enough? Is these something bloacking the cold freezer air from going to the bottom.
If there is anything blocking the cold freezer air going down to the bottom refrigerator is the setting on your freezer control. Try to set the control on the freezer to warmer position. and you may get more cold air going down to the bottom refrigerator. Try that and hope it 'll work for you. If you want to know why, send me a comment and I'll explain to you. Have a nice day, God Bless.
Jul 28, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Top refridgerator does not get cold but the bottom freezer works fine
Most of these have a fan that blows the cold air for the freezer into the refrigiator section. If the fan quits running you will experience your problem.
May 08, 2009 | Refrigerators
Fridge not cold enough, Freezer ok
The refrigerator gets its cold air from the freezer section through ducts and damper control. Check for blockage.
Apr 27, 2009 | Candy CPCA240FFK Bottom Freezer...
Wont get cold
check to see if there is excessive frost build up inside of the freezer on the back panel. If so you may have a defrost problem or your fan motor in the freezer may be bad. Open the drawer to the freezer and see if the fan comes on when you push the light switch. What brand is this unit?
Apr 01, 2009 | Refrigerators
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Samsung RB1955VQ Bottom Freezer Refrigerator Logo
41 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
