Question about BOSS AUDIO SYSTEMS Car Audio & Video
Volume change on 650au boss radio
I cant figure out how to change the volume or the bass on the radio panal itself
mana666
  • 38 Answers
SOURCE: MX5021- Remote pod station w/volume, bass and treble control
yes
Posted on Dec 04, 2007
  • 231 Answers
SOURCE: Subwoofer help
hard to tell whats causing this .Just curious make sure speaker wires going to subs are POLARIZED meaning positive from amp is with positive at woofer and NEGATIVE is with negative at woofer.When these are crossed and when volume is raised you will hear the bass cancell each other out..
Posted on Dec 07, 2007
Lachrymosa
  • 16 Answers
SOURCE: help! no bass sound, low volume
You might want to try using a different size of the earpieces that come with it, and make sure they're inserted fully into your ear. They come with three different size earpieces because people's ears are shaped differently, and having the right size can make a HUGE difference in the sound. If it's done right, it should basically feel like you've just inserted an earplug into your ear.
If that doesn't help, and you've tried another pair of headphones to verify that it's not a problem with your sound source, I would guess you were unlucky enough to get a defective pair.
Posted on May 11, 2009
  • 51 Answers
SOURCE: bass goes off when i turn up the volume
You need to install a heavier gauge wire to your amp and a capacitor. It works fine at low volumes because there is enough wattage from the battery to power the bass output of the amp but at higher volumes the amp does not have enough power.
Heavier gauge wire supplies more poer, and a capacitor stores a reserve of wattage for the amp to use so that it does not run out while blasting your tunes.
Posted on Jun 03, 2009
  • 102 Answers
SOURCE: BOOM BOOM BOOM
The Bose engineers in their "infinite" wisdom developed a $300 radio with no, that is NO, tone control. This means the only way to tune bass response is to reposition the Wave radio itself. If you put it in a corner of a room, it will produce the most bass. If it is only against one wall, not so much bass. To reduce bass response to a minimum, you would have to suspend the device from a wire in the middle of the room. Good luck. I would never buy a radio without a tone control; I literally inherited by Bose Wave Radio and use external speakers which do have tone controls.
Posted on Jan 02, 2010
Volume goes up by itself
First, check your software firmware version and see if there is an update. If available read your manual how to do a firmware update using your USB port, if you don't have a manual, check Bose.com for their online manual and firmware updates. I had a different problem but the firmware update solved it. Another tip to increase the depth of your bass, while doing the adaptiq process, cover your bass speaker with a pillow, this will make your bass more deeper. You need a second person to cover your bass module with a pillow. in this way, the adaptiq process cannot hear the bass sound and it will increase the bass. You might need to do this several times until you get the desired bass sound. If you have not setup using adaptiq, your better off not using adaptiq, the sound is much better. Hope this helps.
Nov 18, 2013 | Bose Lifestyle V25 Theater System
Volume is really low on my HP ProBook 4440s. how can I fix it?
Are you shure all volume controls are set on max? Bass / treble or some kind of equalizer or enhancer turned on? If it's still too low, use a Boss Porta Pro headset, buy external speakers or connect to a stereo system.
Aug 11, 2013 | HP Computers & Internet
Cant seem to get the bass bumping louder
Not sure what product you have installed but, if this is an aftermarket amplifier then, you may need to adjust the gain at the amp.
Sep 28, 2012 | Boss Car Audio & Video
Volume control of peavey bass guitars
Sorry but your post did not provide enough info. Are you having a problem with the volume control. Do you need a wiring diagram. What model Peavey bass do you have. For instance, the Peavey bass I have has active electronics ans requires a 9 volt transistor radio battery to power them.
Jun 22, 2010 | Peavey Millennium Bxp 5String Bass Guitar
Amp slow to kick bass in.
it sounds like you havnt got the memory live conected on your hea duit or it is conected to an ignition live this is no good it needs to be conected to a permenent live to ensure the memory has power at all ties of it coulb be that the amp needs adjusting for low volume use
to set up a sub you turn up the volume to the required level then adjust the amp acordingly hope this helps ben
Oct 11, 2009 | Alpine MRP-M650 Car Audio Amplifier
Symphony radio goes soft and looses bass at high volume
all that is, is the speapers cant handle the sound
Jul 08, 2009 | 2004 Audi A4
Sony radio cdxgt210
Use the main control knob. The one that turns your volume up and down. If you press it in it should go through bass, treble, fade, balance, and sub. Then use that same knob to adjust it by turning it left or right.
Jan 20, 2009 | Car Audio & Video
BOOM BOOM BOOM
Jun 10, 2008 | Bose Wave Radio
Car Audio & Video Logo
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
Jerry Umali
Steve Sweetleaf
Steve Sweetleaf
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
