There are two kinds of pioneer color codes: pre 1999
P o w e r
Memory (+12v Constant)
Orange
Ignition (+12v Switched)
Red
Ground (-)
Black
Illumination
Yellow
Phone Mute
Yellow/Black
Power Antenna
Blue
S p e a k e r s
Right Front (+)
Gray
Right Front (-)
Gray/Black
Left Front (+)
Green
Left Front (-)
Green/Black
Right Rear (+)
Gray/Red
Right Rear (-)
Black/Gray
Left Rear (+)
Green/Red
Left Rear (-)
Black/Green
and 2000 or newer
Memory / Constant 12V(+)
Yellow
Switch / AccessoryRedGroundBlack
Illumination
Orange/White
Antenna RemoteBlueAmp RemoteBlue/White
Left Front (+)
White
Left Front (-)
White/Black
Right Front (+)
Grey
Right Front (-)
Grey/Black
Left Rear (+)GreenLeft Rear (-)Green/BlackRight Rear (+)VioletRight Rear (-)Violet/Black
Your ground wire is going to be black. Your normal wire colors are violet and violet/black, green and green/black, white and white/black, last but not least you have grey and grey/black. Those are your speaker wires. Solid blue is usually to power your antenna, and blue/white is for your amp turn on lead. Those two wires are approximately .5mV of power, and you can actually use either one to turn an amp on. Speakers: normally your solid color is positive, while the black stripe is your negative. As for which one goes to which speaker, left front is white, right front is gray, left rear is green, and right rear is violet. Hope this helps.
