Question about Hyundai HY2000si 2000W Portable Inverter
Where is the oil drain plug
I can not locate the oil drain plug to see why it is leeking oil on the floor. Maybe the plug is open
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Hyundai Master
  • 1,727 Answers
You need to open it up...do you have to mix the oil and gas ??? then it cant leak oil...
Posted on Dec 28, 2013
2001 land rover dis.11 v8 leeking fluid on garage floor. Oil change guy said it doesn't look like oil. what else could it be?
To find out if it's oil get a oil leak detection kit. The kit contains a dye, light and glasses. Simply put the dye in oil fill location run and drive vehicle. Park vehicle shine light on new marks if they glow you have a oil leak if not it could be transmission fluid
Aug 09, 2017 | Land Rover Cars & Trucks
Why would have a water leak from the bottom of the dishwasher or the right side down by the floor between the dishwasher and the wall to the left side of sink? Leak happenns when running the faucet or...
You could have a leek in the trap under the bench, (the drain plug)
Check the trap is tight,
Check the drain pipe is connected to the sink correctly
Maybe the water is leaking through the bench (there might be a gap / hole in, or on, the side of the bench) some sika sealant could fix this.
Hope this helps, don,t forget to rate or add a comment
Feb 10, 2014 | Kenmore Dishwashers
Oil is leaking from the drain plug. The plug is closed but why is it leaking?
Sounds like the drain plug is somehow staying open even though it is in the closed position. The cap is just to keep stuff from going in not coming out. I would either replace the drain valve or just get a brass plug and put that in it
Dec 25, 2012 | Cub Cadet Street Sign- tractor lawn riding...
2008 FLSTC WHERES THE DRAIN PLUG FOR 6-SPEED TRANNY OIL ??
Hmm, that's a good since I haven't seen a six speed up close yet. I work with the older bikes. But, one the five speed, the drain on the Softail was a small pipe plug that uses a Torx wrench. It is located just below the right side chrome cover where the clutch cable goes in. The drain will be there or underneath the tranny but more than likely where it has been on the five speed.
Good Luck
Steve
Aug 14, 2010 | 2000 Harley Davidson FLSTC Heritage...
Oil leek by the oil filter
maybe the filter was put on loose. have seen this many times
Nov 25, 2009 | 2004 Infiniti QX4
How do I change my own oil ?
You need to lift the car , open the drain plug from under located on the oil pan , let it drain for about 10 minutes , remove the filter , replace the filter with new seal , put back the drain plug with new washer , then put the oil in the engine as per your manual for quantity. Start the car for couple of minute , shut off , check the oil level and adjust accordingly to reach he correct level. I would put less oil than specified so that you do not have extra oil and then you can top it. After that is done lift car again to make sure that there are no leeks around the drain plug or filter
Jun 27, 2009 | 2003 Jaguar X-Type
How do I check the gearbox oil level on a 2.1 manual
not too familiar with this model , but from experience with other makes, theres usually a fill level plug near to the drain plug (they usually look the same)that if removed whilst filling it will spill oil from it thus telling you that the correct level is achieved, hope this helped
regards
dave
Jun 26, 2009 | 2003 Jaguar X-Type
Oil and water on floor near upright freezer
Possible you have a sealed system problem, although you state it is working now. Maybe an overflow from drain pan is why there is water again.
Apr 26, 2009 | Kenmore Freezers
Side by side frig
Sounds like your defrost evap. drain maybe plugged.. you didnt say what type and model it is.. Im assuming a sxs
take off back panel and find the drain hole to see if plugged... try pouring hot water down to flush after you check for blockage
& ice
Dec 01, 2007 | Refrigerators
Hyundai HY2000si 2000W Portable Inverter Logo
Top Hyundai Electrical Supplies Experts
john h
fred_therese
Are you a Hyundai Electrical Supply Expert? Answer questions, earn points and help others
