Question about Dryers
Dryer will not run unless the start button is held in
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 32 Answers
There is probably a problem with the centrifugal switch, which is built into the motor. There may also be a loose wire which should be connected to the switch. If the switch itself is bad, it will probably require a new motor, unless you have access to a good "tinkerer" who might fix the switch.
Posted on Dec 27, 2013
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
  • 958 Answers
SOURCE: Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Posted on Sep 14, 2008
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Series 90 dryer will
You have a broken belt.
Posted on Mar 10, 2009
tomsat69
  • 214 Answers
SOURCE: Kenmore-110.73952101 start button won't work unless its held down
It sounds like you need a start switch located on the motor To replace this you will need to get the 2 screws off where the harness plugs into the motor MAKE SURE THE POWER IS OFF :) Ask you locat parts placeGood luck:)
Posted on May 08, 2009
maddogsteve1
  • 18 Answers
SOURCE: dryer won't stay on unless I hold the start button down. When I let go of the start button, it stops.
most likely the evenheat board is bad, but it could be the motor relay, get under the console and check the trouble shooting wiring diagram. there are several checks you can do to narrow it down.
Posted on May 25, 2009
Kenmore dryer wont run unless the start button is held down
the button has broken and needs to be replaced. Contact a local repairman or the place you bought it from
Aug 04, 2016 | Kenmore Dryers
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
Dryer will not stay running unless start putton is held in. Model 110.72972101
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 13, 2010 | Kenmore 72972 Gas Dryer
Asko T700 dryer does not heat up, and start button does not work unless held down.
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 07, 2009 | Asko T700 Electric Commercial Dryer
May 05, 2009 | Kenmore 73952 Gas Dryer
Start button won't stay on. Keeps going off. No heat when held
Which model dryer is this? It could be that the element is faulty which is why it won't run unless you hold the button in or the electronic control board is faulty or the button is faulty if it's not an electronic model cheers.
Mar 26, 2009 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
