Question about Hampton Bay 24002 Ceiling Fan
Just installed a heller ceiling fan with remote, it works fine from the remote but the light nolonger works from the light switch
If I turn on the light stich on the wall I ahve power to the ceiling and the remote will active the light and or the fan as it is supposed to, however, the light switch on the wall will not light the light, ie I can only turn on the light from the remote. Its almost as if the remote sensor unit is set to normally off rather than normally on, however I can see a switch to change the setting
    Master:
  • 993 Answers
Check if there is an remote or manual switch selector in fan assembly
Posted on Jan 21, 2015
    Genius:
  • Hampton Bay Master
  • 1,617 Answers
All the switch on the wall does is turn the power on/off. You have to do everything from the remote with the wall switch on.
Posted on Dec 27, 2013
Buffalo12980
  • 625 Answers
SOURCE: Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Posted on Aug 22, 2007
SOURCE: Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Posted on Sep 05, 2007
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
SOURCE: Older Model Hampton Bay Ceiling Fan: The Redington II w/Remote Control
Ironically, i am having the same problem with TWO different Reddington's in my house.
One is brand new, just hung a few weeks ago, the other is about 3 years old.
The new one -- the lights are stuck in a constant dim, bright, off, dim bright off, and the fan wont turn at all.
The old one, the lights wont come on and the fan will only spin slow.
Both failed within a day or two of each other, and this is driving me nuts.
I thought it might be the remotes, so I took both remotes and pulled the batteries out of each, but that didnt do anything.
If anyone else is having this problem, please post.
Posted on Jan 13, 2008
SOURCE: Hampton Bay Classic Collection 52" remote ceiling light/fan
rechecked wiring, but blue with blue, white with white, etc., now lights work with remote,but fan only works with wall switch - so why doesn't fan work with remote,if lights work the remote & receiver must be ok?
Posted on Jun 04, 2008
All 5 ceiling fan remote sensors not working
Check that the remote is working. Do this by using a digital camera and point the sender at the lens . If it is working you will see a blue/red dot on the viewer screen. It will move when you move the remote. You cannot see the beam but the digital camera can and shows it up on the view finder.
Mar 24, 2013 | Hunter Ceiling Fan Light Remote Control
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
I have a brand new Kichler Ceiling Fan/Light installed in new home. This one for the M-Broom came with Remote UC7206T. The function which controls Fan and Fan speed works fine but I cannot the Light...
Something that may work (based on my experience). Shut off power to the fan (the circuit breaker). Remove the battery from the remote and push all the buttons just in case one is stuck. Reinstall the battery. Turn the CB on. Check operation using the remote.
Dec 29, 2012 | Kichler Lighting 300106OBB Ceiling Fan
Monte Carlo ceiling fan and light not working
Even a brief power outage can cause amnesia in the receiver. You can try disconnecting power at the source and spending a few minutes removing the battery from the wall-mounted remote and pressing all buttons to eliminate the 'stuck button' problem. Reinstall the remote battery and reconnect main power to the unit. Test operation.
Lastly, there always is the possibility that some gremlin changed your original control setup.
Jun 23, 2017 | Dryers
I just installed a 52"
yes this is because the dimer is giving the light less power.you just need to change the switch to a single switch then your dimer will work right all the time. good luck
Aug 12, 2011 | Hunter 52" Ceiling Fan With Light And...
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Hunter ceiling fan. Lights and fans turn on and off by themselves.Both fans are on the same wall switch and are operated by separate remotes.
I just installed a 2nd hunter fan model 23811 that also seems to be controlled by grimlins. If the power is left on, the light and fan randomly turn on and off. And no, it is not due to fans being on the same frequency. It appears to be an issue with the control module. I'm contacting Hunter.
Jul 26, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Sep 07, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Hampton Bay 24002 Ceiling Fan Logo
215 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
