Question about Water Heaters
Leaking water water leak during wash cycle
My water heater has a leak only when it is turned on.
it could be a leak around an element if it is an electric heater.
Jun 04, 2014 | Suburban Direct Spark and Electric Water...
Leaks
The fitting at the top need to be looked at. Use tolit paper wipe around all the fittings and drain lines over head check the popoff valve next if you got a plastic drain valve. Replace it with a 3/4 nipple and cap or a ball valve full port and hose adapter turn gas valve off and use up the hot water I had a valve break during replasment cool water is better. Use pipedope on fitings
Apr 12, 2014 | AO Smith ECT-52 50 Gallon ProMax...
It occasionally leaks water - maybe a quart, leaves a puddle in the middle of the floor and I can see that it came somewhere from the heater, but not where because it is not leaking from anyplace. I have...
Here are a few tings to look for:
When COLD WATER comes into the heater, it might cause sweating of the Cold water line, if the humidity is high in the house? This is usually in summer time only-- when the humidity inside the house is higher..
Another possible place, is the relief valve:
If you have a check valve or two in the system, that ends up trapping all the COLD water in the tank, as it goes thru its heating cycle, -- the Cold water expands, and has to be relieved-- Thus the relief valve will spit out a puddle of water keeping the pressure at a safe level.
(However-- usually the system has a drop pipe coming out of the relief valve-- so likely you would have said that the puddle was at the bottom of the drop pipe-- and you probably would have suspected it..)
However-- Do these suggestions give you some ideas of where the water puddle is coming from ?
Tell us more-
Mack B
Jan 17, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Leaking water heater, the spout on the side is dripping water all over the basement floor.
You can try fixing this problem by putting a garden hose cap over end of valve.
Cap has a washer.
If leak is bad, you need to replace drain valve.
If the valve is brass, then drain water heater and put a wrench on valve and unscrew.
Buy replacement brass valve from plumbing supply or Lowes-HomeDepot
If the valve is plastic, then expect it to break off when trying to remove.
If it breaks off, then you can carefully drill out the stem, and then burn it out with a torch and use a 3/4" pipe nipple to try to cut a new thread.
If water heater will not drain ... put washing machine hose on water heater valve - run water hose between washing machine hose and outdoor spigot and turn on water for 10 seconds to break open clog inside water heater.
Oct 25, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have a Bosch tankless propane water heater 125fx. Yes, I know it's ****, we replaced the igniter switch last year. Then struggled with ordering parts to repair a water leak. During the leak, it was...
There is likely an onboard relay stuck in the open position.
This is a gas appliance and should be serviced by an authorized BOSCH repair center to avoid potential catastrophe.
Thanks!!
Aug 06, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
I have a propane hot water tank that in discharging the hot water out the relief valve (Champion energy saver series)
possible problems not knowing age of unit the
control valve could be sticking open allowing gas to continue to flow until high limit is reached and shuts down valve another possible problem with the newer style back flow preventer being install by water companys the rapid heating and expansion of the water over pressures the water system causing releif valve to pop open and reclose most water heater manufacters are recommending instalation of an expansion tank to allow the growth in volume of water somewhere to go is valve constantly leaking or only during heating cycle if you could supply additional information does unit only leak when heating
or is steam expelled when releif valve opens
t-stat not opening gas valve sticking partially open
bad high limit bad pressure releif valve no expansion tank to allow for thermal expansion if steam is present and unit is boiling water inside replacement of water heater for safety concerns,would be reccomended if only water and pops couple of times water temp not over 140 degrees after most hot water has been used out of tank and is reheating most of capacity probably lack of expansion tank as the releif valve is the final safety device on a water heater is of great concern
the temp control gas valve or high limit are supposed to shut unit done long before the safety limit of releif valve is reached
Dec 11, 2009 | Water Heaters
Rheemglas Fury DV leaking?
Rachel,
I don't know if you have resolved your issue by changing the T&P relief valve. However, if you have replaced it and it appears to have resolved the problem ... it will most likely be only a temporary resolve. And what has happened, it that the water that was being relieved via the T&P valve is now unknowingly leaking / being relieved by a toilet or some other means.
The reason of the leak in the first place is that the most likely the water purveyor has recently installed a DCV (dual check valve) at or within the water meter location. Not knowing where you live, but we are in NC and these DVC's are being installed all over the country.
Basically, your home's plumbing system used to be an "open system" and not it is a "closed system". In earlier times, when the water heater cycled it heated the water, which cause the volume to thermally expand ... and the water was pushed backwards through the meter and it did not allow the water pressures to build. However, with the DCV installed ... now when the water heater cycles and expands water, with no place for the excess water volume to migrate, it now causes a hydraulic effect within the closed system ... which causes the water pressure to become elevated, ultiamtely being relieved at the T&P ...
Here are a couple of links from Watts ....that will help.
http://www.watts.com/pro/divisions/watersafety_flowcontrol/learnabout/learnabout_thermexpansion.asp
http://www.watts.com/pro/divisions/watersafety_flowcontrol/support/support_DETsizing.asp
Locally, we have been on the Cross Connection / Dual Check Valve crusade since early in 1991. We concur that the check valves warrant installation. However the Buidling / Plumbing Codes are not up to speed with truly what is going and how much damage to personal property is occurring with failed water lines ... both inside the home and outside.
Best, Gary H.
Hestand Associates / hestassoc@aol.com
Dec 24, 2008 | Water Heaters
Water Heaters Logo
14 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
