Question about Thermador UCV36A 36" Universal Cook 'n' Vent Downdraft Kitchen Hood
Snorkel with not retract
I have a thermador downdraft vent which will extend and operate without any issues. The arm which rotates and cause the vent to snorkel up appears not to advance far enough in rotation. Is there a simple adjustment?
2 Suggested Answers
alicantecoli
  • 22219 Answers
SOURCE: I have a 1989 model
check in the hood pipes for a rubber seal thats come adrift as something isloose or come apart allowing the hood to come too low so it passing the microswitch for the fan ,between teh tubes is a seal and suspect that one of these has collapsed allowing the hood to come down lower ,its a take it apart type job and see ?
Posted on Jan 17, 2011
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Thermador cooknvent downdraft CVS36R
this is the little circuit board in the switch that is defective here you will eed to replace it.
Oct 24, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Kenmore retractable vent keeps randonly going up and down , sometimes for 6-7 times before it will stop.How do we fix it?
I hope you have the $400 appliance insurance. I had the same problem in a new house purchase. First the downdraft wouldnt work, and then wouldnt stop.
It was a micro switch and motherboard issue. Took four visits by the (insurance paid for) techie to get and fit the right part. Good luck
Mar 08, 2014 | Kenmore 36" Telescopic Downdraft Range...
The vent downdraft keeps going up and down
This means that one of the limit switches by the motor has failed.
Apr 22, 2011 | Thermador UCV36A 36" Universal Cook 'n'...
Thermador Downdraft blower Fan Not Working
could have serveral problems / if under counter or in back of range . the last two i had the control buttons w wire harness needed replacement /another required the pc board in connevtion box ( under counter in right cornor. also look for poor connections in the power box .
Dec 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
My 7 1/2 year old Thermador CVS36RB Cook 'n' Vent won't retract
sears labor is 137 plus parts. that is something that would need to be looked at. it could be a few different things. if he is handy he can open it up to see if anything is misaligned or broken. the vent may even just be a little crooked and once straight may go up and down like normal
Nov 22, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Cook 'n Vent Downdraft Up/Down Mechanism Replacing
just the switch should be replacable. My vent has a screw at each end (philips flatheads - accessible only when vent is up) just under the top cap. Removing the screws and cap should give you access to the switch. Just make sure you cut your breaker off first.
Nov 15, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Thermador cook top with down draft ventalation
I would think you can. Most of the cooktops are 240v and the vents are 120v, so the vent may be feeding off of one of the cooktop's hot wires. My vent is fed from it's own receptacle but is harnessed along with the cooktop's 240v.
Oct 31, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Thermador downdraft does not stop going up and going down automatically
I had a similar issue with the Thermador CVS30R hood continually going up and down, and also issues with the fan starting.
The issue was found to be a loose control arm off the motor. The arm itself moved outward on the motor shaft which resulted in it missing the switches that control the hood up/down and fan start.
This was a somewhat simple fix. Make sure the hood is in the down position. Unplug the unit from power(important!). Unscrew the screw that connects the drive arm to the drive link. Unscrew the motor/control cover, then unscrew the 4 screws holding the complete motor/control unit on (2 Phillips-head screw on each end of the assembly). Pull the complete motor/control assembly out, be careful of wiring. Once out, push the drive arm on firmly onto the motor assembly and tighten the screw. When doing so make sure the 2 micro switch arms are not caught and are free to switch.
When placing the unit back in, ensure all wiring is clear from being caught and ground is reconnected. Put it all back together and done!
I found this link to be useful for a parts/configuration diagram:http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232629&diagram_id=194441#d194441
Jun 05, 2007 | Thermador CVS30R Kitchen Hood
Kitchen Ranges Logo
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
